Blackview SE60 Auto Lock Smart Lock IP54 Waterproof BHMA/ANSI Grade 3 App/Fingerprint/Passcode Unlock
Blackview SE60 Secure Every Day, Smart in Every Way Fingerprint Unlocks Daily, One-time Codes Always Ready Why Choose Blackview SE60? No.1...
Blackview SE60
No.1 Matches up to 99% of Doors with Round Holes
No.2 Elite Security with Top-Tier Quality
No.3 Highly Convenient with 5 Modes of Entry
No.4 Superior Ruggedness with IP54 Rain Resistance for Any Weather
No.5 Quick and Easy Setup and Take Down
Door by Door, The Sure-Fit Explorer
Seamless Security, Key-Free Comfort
Compatible with Up to 99% of Round Hole Doors
Tailored for 99% of US residential round hole doors, SE60 smart lock seamlessly fits in homes, apartments, offices, and garages, providing users with unparalleled peace of mind and eliminating the hassle of carrying keys.
Hush-Hush Protection, Absolute Reliability
Embrace Timeless Elegance
Vintage Design
Built with a zinc alloy outer shell, SE60 smart lock is durable and dependable. Its antique bronze accents add a touch of vintage elegance, making it both versatile and practical, with low maintenance expenses.
& No Peeling
Premium Strength, Maximum Security
BHMA/ANSI Grade 3
With its durable zinc alloy outer shell, brass cylinder, and 304 stainless steel latch, SE60 is built to withstand substantial external impact and pressure, ensuring top-tier security protection while preserving the lock's appearance for years to come.
Zinc Alloy Shell
Higher Corrosion Resistance↑
Brass Cylinder
Improved Wear-resistance↑
304 Stainless Steel Latch
Superior Impact Resilience↑
Resistance
Anti-Prying Door Design
When attempted forced entry occurs, SE60 is secured by an iron backing on the exterior side of the door, ensuring it's not easily compromised.
Every Way, Your Way with Ease
Tap, Unlock, Welcome!
App Unlock
Thanks to Wireless BT 4.2, you can effortlessly unlock your door from within a 10-meter range using an app, even when you're tied up. It's a convenient way to grant access to visitors or couriers without stopping your current tasks.
Touch, Enter, Secure – Effortlessly
50 Set Fingerprint Quick Unlock
Step into a world where safety and simplicity coexist; SE60 redefines access control, recognizing your fingerprint with a simple touch, granting effortless entry to your home or office while enhancing security and eliminating the need for keys.
More Storage↑ 150%
Up to 50 Set
Higher Sensitivity↑
0.6s Unlock
More Stable↑
Accuracy: 99%
False Accept Rate↑
<0.01%
All-around↑
360°Recognition
Husband
Wife
Child
Elder
Privacy & Convenience at Your Fingertip
50 Set Passcode Unlock
By utilizing password access, you can set your preferred password and distribute it to family and friends with ease. The silicone buttons offer fingerprint-resistant security, ensuring the confidentiality of your password.
More Storage↑ 150%
Up to 50 Set
Fingerprint-resistant Silicone Buttons
Privacy↑
0.3s
Faster Response↑
Delete Passcodes via App
Convenience↑
Anti-peep Passcode Protection
Improve password protection - entering random numbers to deter unauthorized access.
Anti-crack Passcode
Upon five failed attempts to enter an invalid password, the lock system of SE60 will deactivate for 90 seconds.
Friends
Babysitter
AirBnB
One-Time Codes for One-Time Needs
Offer a one-time code to your delivery person, repair service, or pet sitter. It's set to expire 5 minutes after creation, which is really practical.
Neighbor
Plumber
Delivery person
Repairman
Tutor
Pet sitter
Spare Keys, Solid Security
Two Physical Backup Keys
In emergencies where fingerprint and password unlocking are unavailable, backup physical keys serve as an alternative solution, offering significant convenience and security. Additionally, backup keys can be duplicated by professional locksmiths.
Elderly unlocking
Battery depletion
Technical breakdown
Fire emergency
Unlock Your Day. One Touch Away
One-Tap Unlock/Lock
After a day's work or when preparing for the morning rush, all it takes is pressing the button behind the door to effortlessly unlock or lock, ensuring quick and convenient access.
Locking the Way, Brightening Your Day!
Auto Lock
Simplify your comings and goings with SE60's auto-lock, automatically engaging the lock within 10 to 99 seconds, ideal for those moments when you're overloaded or hurrying out.
Auto Lock
Activate auto-lock to banish the worry of leaving your door unlocked. In seconds, it's locked automatically, keeping your home safe and secure.
Stays Unlocked
For quick entries and exits, just switch off the auto-lock on SE60, and your door won't lock when you leave.
Privacy Always First
Advanced Encryption
With cutting-edge encryption technology, SE60 ensures top-notch privacy protection, guaranteeing the security and confidentiality of all your personal data.
Advanced Encryption Chipset↑
BK3431Q
Boost Frequency
64MHz↑
Hush-Hush Harmony
Silent Mode
In moments of rest at home during the evening or when silence is key, put your SE60 on silent mode, which ensures the door lock functions quietly, avoiding any disturbance to those around you.
Bye-bye, Battery Woes!
Up to 10 Months of Usage Time
With 4 AA batteries, SE60 boasts a battery life of up to 10 months. Its easy-to-remove design also simplifies battery changes, making it a very handy choice.
* Battery are not Included. * Battery life results are based on 10 door open-and-close
Stay Aware, Recharge, Keep Secure
Emergency Unlock with Type-C Port
As the battery depletes, the app sends a notification. If it reaches a critical level where normal unlocking is impossible, the Type-C port provides emergency access. Using a portable charger, you can successfully unlock, ensuring your peace of mind.
Top-Tier Drill-proof Protection
Boasting a durable zinc alloy lock shell and a 304 stainless steel bolt, SE60 provides long-lasting durability and steadfast security.
Tough in Any Weather
No matter the weather, SE60 smart lock offers IP54 rain protection, ensuring ongoing security for your household.
All-Season Reliable
No matter if it's a freezing -4°F or a blistering 140°F, SE60 smart lock is designed to endure harsh temperatures, providing constant protection for your home.
Guarding You for Decades, Not Just Days
With 100,000 locking and unlocking tests conducted, SE60 proves its lasting efficiency over 20 years of operation.
Fit & Go. Effortless from Start to Finish!
Quick, Easy, Secure
Effortless Installation and Disassembly
Get your smart lock installed and operational in a snap - just 15 minutes, no pros needed.
Easy Setup in
15 Minutes
Easy Removal in
5 Minutes
Simple for Starters
Model | Blackview SE60 |
Fingerprint | 50 Set |
Passcode | 50 Set, 6-10 Digit |
Dummy Passcode | Support 16 Digital |
One-time Code | Yes |
Local Administrator | 3 Set |
Battery | 4*AA Batteries(Not Included) |
Waterproof | IP54 |
Auto Lock | Yes |
Low Battery Alarm | Yes |
Silent Mode | Yes |
Network | Wireless BT4.2 |
Operating temperature | -4°F to 140°F |
Certification | BHMA, FCC, ROHS |
