Blackview BV7300 6.67-Inch 90Hz Display Helio G81 6+256GB 15000mAh Night Vision Camera Camping Light 4G Ruggedized Cellphone
£206.00 £168.00
✔Built-in Dual 800LM Super-bright Camping Lights
✔Sony IMX376 20MP Night Vision Camera
✔15000mAh w/ 45W Fast Charging
✔6.67" 90Hz Refresh Rate Display w/ Corning® Gorilla® Glass 5
✔MIL-STD-810H & IP68 & IP69K
Capacity: 6GB+256GB
6GB+256GB
Color: Black
Yellow
HURRY! ONLY LEFT IN STOCK.
Frequently Bought Together
Total price:£406.00 £307.00
Description
BV7300
Dual Camping Lights, Night Vision Cam
Light Your Way Ahead with Pure Delight
Built Tough, Styled Smart
Designed not just for endurance but for style that stands out, BV7300 which features a reinforced frame and textured back provides a secure grip while adding an element of rugged chic. Each curve and contour make it not common but a visually appealing companion along your field work or outdoor adventure.
Yellow
What Makes BV7300 Stand Out?
No.1 More Comprehensively Improved Ruggedness from Inside to Out
Beyond the Standard: Tougher, Stronger, Better
No.2 Enhanced Safety with Dual Versatile Camping Lights & 20MP Night Vision Camera
Day and Night, Peace of Mind
No.3 Super-large 15000mAhmAh Battery Back in 45W Fast Charging to Last Longer
Charge in a Flash, Power to Last
No.4 Smoother Operation with Up to 18GB RAM 256GB ROM, and Octa-core G81
Power to Play, Speed All Day, Lead Your Way
No.5 More Personalized Interaction from Stock Android 14-Based DokeOS 4.0
Your Style, Your Needs, All Satisfied
Forged Tougher, Always Safer
From its outer shell to internal components, from ports to speakers, and from materials to adhesive sealing, BV7300 is designed to maximize its waterproof, dustproof, and drop-resistant capabilities, ready to deliver reliability and protection far beyond standard peers.
Leading IP68 and IP69K
Waterproof and Dustproof
Desert or Washer? Worry-free
Navigate torrential rains? Battle dust storms? Clean off the day’s work under a high-pressure hose? Just go ahead and face the water and dust! Boasting both IP68 and IP69K ratings, BV7300 offers dual shields against the elements and will remain in good condition.
Small aperture and fine mesh design to prevent water droplets, dust, and other small particles enter
Apply adhesive around the ribbon cable to seal any gaps
Adhesive sealing with water-repellent backing to create a tight seal
High-density adhesive used to around the edges of the display
Use liquid silicone to achieve IPX7 waterproof
Use TPU to interfere with the housing to be IPX7 waterproof
Coated with a nano-layer to provide waterproof protection
Outer casing made of PC and TP to be anti-static and dustproof
Non-woven fabric with a dense fiber structure that can trap fine dust particles
*Waterproof up to 1.5m deep for 30mins.
Underwater Camera
Dive In, Shoot Clear
You can take crystal-clear photos and videos below the surface, whether you’re snorkeling, swimming, or exploring underwater adventures. Snap vivid shots without worry, turning your water escapades into lasting memories.
*Supports underwater photography up to 1.5m.
MIL-SPEC- 810H Certified
Durability Redefined
Upgraded from MIL-SPEC 810G to 810H, BV7300 can withstand and survive, even when dropped, submerged, or exposed to extreme temperatures. Be it scorching deserts, freezing arctic tundras, or torrential downpours, this device will be your reliable partner along your outdoor trips or work.
The standards achieved include but are not limited to:
Rain
Sand and Dust
Vibration
Shock
Acceleration
High Temperature
Low Temperature
Humidity
Altitude
Immersion
*Drop resistant up to 1.5m. Actual performance may vary depending on factors such as the surface material, angle of impact,etc.
Unparalleled Shockproof from Every Angle
Stand Tall Drop after Drop
Crafted with unparalleled toughness to handle all that life throws your way, BV7300 is durable enough to endure shocks, drops, vibrations, and even submersion. An indispensable and perfect companion for adventurers or outdoor enthusiasts.
Reinforced shell, thickened frame, and extra-thick corners reduce impact force.
Raised impact-resistant corners as a buffer zone to absorb shock.
45-degree optimal impact angle after After hundreds of thousands of experiments.
Aluminum alloy frame reinforced with screws to minimize disassembly risks.
Energy-absorbing structure to enhance its shock resistance when dropped.
Unaffected from -20℃ to +60 ℃
Chill or Heat? Ready for It
Wherever your adventures take you, from frost-covered peaks to sun-baked deserts, this phone which has remarkable temperature resistance from -20°C to +60°C promises it will stay by your side to provide you with normal and good function.
Durable Corning® Gorilla® Glass 5
Front and Back, Never Crack
Made of Corning® Gorilla® Glass 5, the screen of BV7300 is up to 4 times more drop-resistant than their peers made of common glass. Plus, it ensures super clear visibility whether you’re caught in a sandstorm or navigating rocky terrains.
4 x Drop & Scratch-resistance ↑
Customized Shortcut Button
Click, Go, Access
With just one click, double clicks, or long press, you can effortlessly access the function or app you prefer, like opening the flashlight, SOS, and more.
Screenshot
Open the Flashlight
Open the Underwater Camera
Open Game Mode
Start Sound Recording
Open PTT
Open SOS
Dual Super-bright Camping Lights
Shine Brighter, Camp Better
Featuring two built-in camping lights with 800 lighting beads, BV7300 redefines clarity and illumination. Whether you’re setting up camp or navigating the dark, BV7300 always lights up your way ahead.
  • 800LM Bright Illumination↑
  • Up to 5.8hrs of Continuous Illumination in Extremely Bright Mode
  • 800 Lighting Beads
User-friendly Control
Adjust According to Your Need
You can open the camping light either from the tool bag or from the shortcut button. It has 3 lighting modes, 3 brightness levels, and customizable lighting duration for different needs.
  • Lighting Mode
  • SOS Mode
  • Quick Flashing
    Mode
  • Three Adjustable Brightness Levels
All-in-one Lighting Solution for
Various Needs
Light up Your Night Activities from Camping to Fishing
  • Illuminate to Observe Surroundings Around
  • Set a Cozy and Enjoyable Ambience with Additional Brightness
  • Light up Fishing Spot and Attract Fish
  • Repair Broken-down Vehicles at Night
  • Illuminate the Road Ahead While Riding in the Dark
  • Help Night-shift Workers Perform Tasks More Accurately
Keep You Safer in the Dark
  • Detect Dangerous Creatures in Advance
  • Provide Bright Light to Fend off Animals
  • Avoid Stepping into Pits and Traps
  • Use SOS Mode in Emergencies to Get Yourself Spotted
  • Illuminate to Remind Others of Your Location
  • Locate and Navigate in Pitch-dark Environments for Rescuers
Provide Extra Convenience Both Indoors and Outdoors
  • Used as a Backup Light Source When Power Fails Indoors
  • Fill Light for Photography in Low-light Area
Triple-camera Setup,
Capture Clearly
Day or Night
  • Front Camera
    32MP
    (f/2.2) 1/3.1’’
  • Main Camera
    Samsung®
    ISOCELL JN1
    50MP
    (f/1.8) 1/2.76’’
    Night Vision
    SONY IMX376
    20MP
    (f/2.0) 1/2.8’’
50MP Samsung® ISOCELL JN1
Main Camera
Brighter Beauty Even in Low Light
Boasting a state-of-the-art 50MP Samsung® ISOCELL JN1 main rear camera, BV7300 offers unparalleled clarity, color accuracy, and detail capture, transforming every shot into a masterpiece, regardless of the conditions. Each photo, seemingly still, is vividly alive.
  • 4-in-1 Pixel Binning
    Tech Improve image brightness especially at night
  • Inter-scene HDR
    Balance shadows and highlights
50MP
Gorgeously Detailed
Luminously Beautiful
4-in-1 Pixel Binning Tech
Darkness redefined. With 4-in-1 Pixel Binning Technology, it transforms 0.64μm pixels into 1.28μm pixels, capturing 400% more light for stunningly bright night shots.
  • 400%
    More Light Sensitivity
  • 4-in-1 to 1.28μm
    Super Pixel
32MP Front Camera
Click and Gain Every Detail
Fear your selfies can’t capture your true beauty? Housed with a 32MP front camera, BV7300 snaps much more sharper and clearer selfies and video calls. No matter where you are, shoot v-logs with clarity.
F/2.2
Large Aperture
5P
High Light Transmission
Dark Night? Fear No More
In low night or totally dark nights, you can capture crisp-clear and detailed images effortlessly. From low-night shooting, wildlife observation to filed rescue, it always gives you sharp and clear photos.
Detailed Surroundings of Wildlife Activity
Clear Terrain Features
Fish Movements with Clarity
Check the Safety of Campsites
Filed Rescue During Earthquake
1080P 30fps Video Recording
Capture, Remember, Every Shot
You can bring cinematic quality to your videos with 1080p ultra-high resolution. Perfect for you to record amazing mountain peaks, torrential falls, or other memorable moments.
Beauty Mode
Enhance your photos with smart facial recognition technology that subtly perfects your features.
Portrait Mode
Blur the background and highlight the subject, help you stand out in every shot.
Panorama Mode
Move your phone consistently from left to right to capture spectacular landscapes or buildings.
More to Love
Pro
Adjust camera settings like a photographer for well-composed shots.
Mono
Avoid the interference of color and reveal the purest beauty.
Face Fill Light
Enhance your features to ensure you always look your best, day or night.
Underwater
Camera
Allow you to capture stunning, quality images and videos beneath the surface, perfect for adventurers who want to bring more from their aquatic journeys.
15000mAh Long-lasting Battery
Play, Work, Explore Without Limits
Boasting a 15000mAh mega battery, BV7300 keeps you powered up from dawn till dusk, and beyond without frequent recharging. Once charged fully, enjoy days of fun.
Game
18hrs
Video
16.5hrs
Website
28hrs
Calling
56.5hrs
Music
32.5hrs
1368hrs
45W Fast Charging
10 Minutes Charge, 20% Power Surge
The 45W fast charging on BV7300 boosts the battery in less time and gets back to what matters most. On the go or in a rush? No more waiting around.
Intelligent Power Saving Mode
Adjust, Longer Use
You can switch freely between performance mode and battery saving mode, thus extending the battery life by up to 5 hours.
5hrs Longer
Daily Use ↑
Intelligent Charging Protection
Smarter, Longer Usage Time
When the battery reaches 80% at night, the system will automatically stop charging and smartly decide whether to continue or not based on the actual condition later. This prevents overcharging, thereby extending battery life.
7W Reverse Charge
Pocket-Friendly & Reliable Power Source
BV7300 is more than a rugged phone; it’s a portable power bank as well, ready to recharge your other devices, from earbuds to smartwatches, ensuring you stay connected and entertained on and on.
6.67-inch Immersive HD+ Display
Larger Screen, Better Viewing
Experience stunning visuals with BV7300’s 6.67-inch immersive display. From watching videos, working with documents to view maps or data on the go, its large and super clear display just brings your content to life.
Screen Size
6.67-inch
Resolution
720*1604
Brightness
700 nits
Screen-to-body Ratio
85%
Panel Type
HD+ IPS
Dynamic Refresh Rate
90Hz
700-nit Brightness
Brightest Sunlight? Fear Not!
BV7300 boasts a dazzling 700-nit display, ensuring stunning clarity and vibrant visuals, even in the brightest sunlight. Perfect for outdoor enthusiasts or anyone on the move, never miss a detail again!
90Hz Dynamic Refresh Rate
All Interaction as Smooth as Silk
BV7300’s 90Hz dynamic refresh rate keeps your every scroll, swipe, and interaction as smooth as silk. Whether you scroll social media or play intensive games, it just offers crisper details, reduced motion blur, and an overall enhanced viewing experience.
60Hz
HD Video Playback or
General Use
90Hz
Scrolling Through Social Media,
Playing Intense Mobile Games
Smarter Energy Management↑
Longer Battery Usage Time↑
Eye-friendly Modes
Every Tap and Swipe, Eye First
Reading Mode
Mimic the warmth of a paperback and transform your screen into a digital book that’s easy on the eyes, anytime, anywhere.
Night Light Mode
Intelligently adjust the screen color to amber and allow you to read or look at the screen comfortably in dim light.
Dark Mode
Help conserve battery life and ensure a soothing viewing experience simultaneously with three modes: Enhance, Moderate, and Gentle.
Dual Box Speakers
Feel the Beat, Feel Alive
Want to experience an immersive musical feast? Equipped with dual box speakers, BV7300 provides powerful and immersive sound effects that allow you to revel in every note, deep bass or crisp treble.
No.4 Smoother Operation with Up to 18GB RAM, 256GB ROM, and Octa-core G81
Octa-core MediaTek
Helio G81
Incredible Power, Unimaginable Efficiency
Powered by the robust Octa-core MediaTek Helio G81, BV7300 allows for seamless multitasking, powerful gaming, and peak efficiency, all within a durable design.
Up to 18GB RAM
Amazing Speed, Always
With up to 18GB RAM, BV7300 enables you to smoothly run multiple applications simultaneously without slowing things down or frequently turning off background apps to free up memory. Never miss a beat, no matter how demanding the task.
Up to 18GB RAM=6GB RAM + 12GB Expansion
256GB ROM +
2TB TF Expansion
Massive Storage, Maximum Freedom
Constantly worry about lacking space because of your obsessing over saving videos or installing apps? Thanks to its 256GB ROM and 2TB expandable storage on BV7300, you are offered enough space for files, episodes, games, and more.
1TB More TF Expansion
≈221.6K+
More Photos ↑
≈26.4K+
More Short Videos ↑
≈400K+
More Songs ↑
Atomized Memory 2.0
More RAM, More Possibilities
Intelligently allocating RAM to avoid slowdowns, it can help free up to 9% additional capacity for running more background apps or tasks, significantly boosting the overall performance of your device.
9% More RAM Available↑
Smart Pre-Loading
One Step Ahead
Smartly anticipating the apps you’re about to use, this feature pre-loads them for instant access, reducing loading times and keeping you one step ahead in every task.
8,500mm² Integrated Cooling System
Stay Cool, Stay Ahead
Imagine your phone becomes really hot after an extended period of use. Quite annoying, right? The 8,500mm² heat dissipation area on BV7300 can help it stay cool and maintain optimal performance even during intensive tasks.
8,280mm²
Cooling Graphite
220mm²
Cooling Silicone
Constant Temperature at 40℃ in CPU-intensive Games
Model
BV7300
Color
Black, Orange
Dimension
186.2*85*24mm
Weight
528g
OS
DokeOS 4.0 Based on Android 14
Display
6.67-inch HD+PS ,720*1604 Resolution.
Corning® Gorilla® Glass 590Hz Dynamic Refresh Rate
CPU
Octa-core MediaTek Helio G81, Up to 2.0GHz
RAM & ROM
6GB RAM& 256GB ROM.LPDDR4x+EMMC5.1
TF Expansion
Up to 2TB TF Expansion
Battery
15000mAh; 45W Fast Charging
Front Camera
32MP
Rear Camera
50MP(Samsung® ISOCELL JN1)
20MP Night Vision (SONY IMX376)
Speaker
Dual 1712 Box Speakers
Rugged Rating
IP68 &IP69K& MIL-STD-810H
Navigation
GPS+GLONASS+Galileo+Beidou
Card Slot
Dual; 2'SlM/1*SlM +1*TF Card
Glove Mode
Support
NFC
Support
Dual 4G VoLTE
Support
Wi-Fi&Bluetooth
Dual Bands: 2.4G/5.0GHz,802.11 ab/g'n/ac, BT 5.3
Network Connectivity
2G Band:850/900/1800900(B2/B3/B5/88)
3G Band: WCDMA: B1/B2/B4/B5/B8
4G Band:
LTE_FDD:81/B2/B3/B4/B5/B7/B8/B12/B13/B17/B19/B20B26/B28A/B28B/B66
LTE-TDD:B40/B41/B38
Specification
Design
ProductBV7300
OSDoke-OS 4.0 ( Based on Android 14)
ColorBlack, Yellow
Weight528g
Dimensions186.2*85*24mm
Screen
LCD panelHKC/BOE
ICFT8057S/ILI9883C-C0T0BHA
Panel TypeIPS
Display ResolutionHD+
Screen Size6.67 Inch
Screen Resolution720*1604 20:9
Screen to Body Ratio (%)85%
Viewing angle (H/V)Full angle
PPI/DPIPPI: 263
Refresh frequency 90HZ
GlassCORNING® GORILLA® GLASS 5
Connectivity
WIFI 802.11a/b/g/n/ac
Bluetooth V5.3
2G2/3/5/8
3G WCDMA: B1/B2/B4/B5/B8
4G TDD: B38/B40/B41
FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B19/B20/B26/B28a/B28b/B66
Hardware
CPUMediaTek Helio G81(MT6769V/CB) Octa Core
CPU Clock Cortex-A75 @ 2.0GHz*2, Cortex-A55 @ 1.7GHz*6
GPUARM®Mali-G52
RAM6GB
RAM TypeLPDDR4X
ROM256GB
ROM TypeEMMC5.1
TF Card SlotYES
Max TF Card Capacity2TB
USB24pin TYPE-C
Camera
Front Camera 32MP
Front Camera SensorGC32E1-WA1XA
Front Camera Aperturef2.2
Rear Camera 50MP main camera
20MP Night Vision
Rear Camera Sensor Samsung® ISOCELL JN1 + SONY® IMX376
Rear Camera Aperture f1.8/f1.8
Rear Flash Yes
Video 1080P 30fps Video Recording
Power
Battery Capacity 15000mAh, 45W Fast Charge
Max Charging Current3A
Additional Tool
Camping Lights Dual 800 lumen (LM) LED, Up to 5.8hrs of Powerful Illumination
Multi-media
Video .3pg .mp4 .avi .mp4, .3gp .3g2 .3gpp…
Audio mpeg 3gpp raw WMA ALAC…
ImagePNG JPG GIF…
Features
NavigationGPS+GLONASS+Beidou+Galileo
Motor Flat motor
SensorsG/P/L-sensor
GyroscopeYES
MagneticYES
Air pressure sensorNO
HallNO
CompassYES
FingerprintYES
RGBYES
NFCYES
HotkontNO
Coulomb CounterNO
Wireless ChargingNO
Sim-Card TypeTwo nano card
FMYES
OTGYES
Earphones Jack TypeTYPE-C
Accessories
User Manualx1
Power Adaptorx1
USB Cablex1
Hand strap/Hanging ropex1
NOTE
