Blackview WAVE 6C 6.5" SC9863A Octa-core 2+32GB 5100mAh Massive Battery 4G Smartphone
$139.99 $99.99
WAVE 6C Surging WAVEs, Unlimited Joy 9.7mm Slim & 191g Light Samsung® ISOCELL 4H7 8MP Rear Camera Capture Every Brilliant Moment...
Capacity: 2GB+32GB
2GB+32GB
Color: Black
Blue
Purple
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Frequently Bought Together
Total price:$229.97 $159.97
Description
WAVE 6C
8MP
Rear Camera
Capture Every
Brilliant Moment
5MP
Front
Camera
3 Brand-new
Eye-catching
Color Gradients
Stand Out with
Color Gradients
Smart-K Box Speaker More Pleasing to the Ear
6.5-inch HD+ Display Stunning Views on A Bigger Screen
Octa-core SC9863A Smoothly Respond to Each Task
Up to 1.6GHz
2GB RAM+ 2GB RAM
=Up to 4GB RAM
32GB ROM +
1 TB TF Expansion
DokeOS 4.0 Go Based on Android 13
Personality ↑ Convenience ↑ Privacy ↑ Smoothness ↑
5100mAh Massive Battery Unlimited Power, Non-stop Entertainment
Dual Hybrid
Card Slots
SIM*2/ SIM*1+TF*1
Free TPU
Protective
Case
Face Unlock
3 New Eye-catching Color Gradients Love at first sight - With strong visual impact brought by WAVE 6C, unlike the singular color scheme in the past, this time it adopts a unique gradient design made by an all-new exquisite spray coating process - presenting gorgeous color gradients in the simple back panel, making your style more distinctive and personality more prominent!
9.7mm Slim
191g Light
Find Your Colors, Find Yourself
Lilac Purple Looking closely, WAVE 6C seems like elegant blooming lilac flowers, giving you an extremely tranquil and peaceful atmosphere.
Mint Blue The soft and lively mint blue feels like a cool breeze on your cheeks, particularly refreshing and invigorating.
Midnight Black The midnight black accumulates the mystery and tranquility of the night. WAVE 6C looks low-key yet elegant in your hand.
6.5-inch Bigger Screen Stunning Views on A Bigger Screen Embark your next incredible and immersive visual journey on the expansive 6.5-inch waterdrop display with silky smoothness and quick responsiveness. The high-definition resolution brings you real-world vividness that fascinates you much.
6.5 inch Screen Size
720*1600 HD+ Resolution
87.6% Screen-to-body
Ratio
380cd/cm2 Brightness
60Hz Refresh Rate
20:9 Aspect Ratio
269 PPI
Smart-K Box Speaker More Pleasing to the Ear Whether watching movies, playing games or listening to music, WAVE 6C allows you to experience clearer tones and deeper sounds. Relish in the passionate rock music, or the singer's quiet humming.
5100mAh Massive Battery Last Longer, Charge Less Under the hood, the WAVE 6C embeds an above-average battery and turns out to be a strong powerhouse that continuously powers you up, living up to more than a day of regular use. Even though you use it heavily, WAVE 6C’s battery life exceeds your expectations.
7 hrs Game
7 hrs Video
10 hrs Web
27 hrs Call
35 hrs Music
792 hrs Standby
*The data is tested by Blackview Laboratory. Battery life depends on the actual usage situations.
Octa-core Unisoc SC9863A Smoothly Respond to Each Task Clocked at up to 1.6GHz, the Blackview WAVE 6C, backed by octa-core Unisoc SC9863A, runs multiple apps and multitasks at sufficient fluidity, responsiveness, and efficiency to satisfy your productivity and entertainment needs.
Up to 4GB RAM + 32GB ROM Competent in Daily Multitasking & Storage WAVE 6C has up to 4GB RAM, which allows you to run multiple applications simultaneously and switch between them easily. Additionally, its 32GB ROM, with the option to expand by 1TB TF card, offers enough space for installing applications and storing files, making it suitable for everyday use and providing a satisfying user experience.
RAM 2GB RAM+ 2GB RAM=
Up to 4GB RAM
ROM 32GB ROM +
1 TB TF Expansion
5MP + 8MP Cameras Capture Every Brilliant Moment
Capture spectacular landscapes, creative videos and exciting sports moments with Blackview WAVE 6C’s 8MP Samsung® ISOCELL 4H7 Rear Camera that delivers incredible details and vivid colors. And don't forget its 5MP front camera, which makes every selfie lively and vibrant.
1080P Video Recording Details Beyond Your Imagination
Whether you are shooting the endless mountains, the flowing rivers, or the swaying trees, WAVE 6C can present the colors and rich textures close to reality and capture every exquisite detail. When taking portraits, it can also highlight the charm and expressions of the characters, and bring the texture to a higher level.
Gatherings
Cooking Videos
Rock Climbing Breathtaking Landscapes
Doke OS 4.0 Go
Based on Android 13
Empower Every Aspect Blackview has always focused on user experience improvement and therefore developed the Doke OS Leaping from OS 2.1 to Doke OS 4.0 Go version. The latest upgraded OS brings more friendly features for the intuitive visuals and smooth controls. With Android 13, you can also relish new Android highlights.
Artistic Themes Two sets of themes are with enriching icons and invigorating wallpapers.
Clear Wave
Oil
Versatile Desktop DokeOS 4.0 Go renders all the magic tricks for saving your time. You can group apps together, dismiss folders, or lock desktop layouts in a breeze.
Three Eye-comfort Modes
Dark Mode Reduce the light emitted by the screen to decrease eye strain.
Night Light Mode Provide warmer color at night to promote your sleep.
Reading Mode Create a Kindle-like format for better reading of newspapers and novels.
EasyShare App
With WAVE 6C's EasyShare app, music,
photographs, or files can be exchanged at a transfer rate of
7.7MB/s without any need for a network or traffic. Transfer bigger files and increase your productivity.
Atomized Memory 2.0 Atomized Memory 2.0 enhances performance by automatically distributing memory usage among applications, increasing available memory for other applications by 5% to 9%, and allowing multiple apps to run simultaneously in the background.
5%~9% More RAM Available ↑
Smart Power Saving WAVE 6C’s smart Power Saving Mode extends its battery life by limiting unnecessary background applications and disabling some features to reduce battery consumption.
Cleared Clipboard History Clipboard history will be cleared after a period of time if you allow it to prevent unintended information leakage. With Android 13's support, you will also receive notifications when apps access your clipboard.
Privacy Dashboard Show which apps recently used permissions over the past 24 hours.
Permission Manager Freely control apps' access to all your data, including notifications, location, camera and more.
Security-Enhanced Linux
Kernel-level security process to
effectively protect programs from rooting and attacks
B1-level military security
performance,
not easily compromised
by vulnerabilities
Flexible mandatory access
control structure
with enhanced level of security
protection
Reduces the resources
accessible
to service
processes in the system
Mitigates disasters caused
by malicious
attacks or
malware
Provides a high level of
security
for information with high confidentiality and
integrity requirements
More Details More to Impress
Face Unlock in A Blink Enable the face recognition function to unlock the WAVE 6C quickly at a glance.
3-in-1 Navigation System WAVE 6C supports GPS, GLONASS, and Galileo
navigation for faster positioning.
4G LTE Connectivity Deliver fast and stable mobile network experience for better work and play capabilities.
Multiple Card Slots Design More room, more fun. Support the insertion of 2*SIMs /1*SIM+1*TF Card
Free TPU Protective Case Soft TPU materials can significantly reduce damage and provide extra protection.
Blackview WAVE 6C
  • Model
    WAVE 6C
  • Colors
    Lilac Purple,Mint Blue,Midnight Black
  • Dimension
    164.7*76.5*9.7mm
  • Weight
    191g
  • OS
    DokeOS 4.0 Go (Based on Android 13)
  • Display
    720*1600 20:9 HD+ IPS
  • CPU
    SC9863A
  • RAM & ROM
    2GB RAM + 32GB ROM
  • RAM Expansion
    2GB RAM Expansion
  • Max TF Card Storage
    1TB
  • Battery Capacity
    5100mAh
  • Camera
    5MP Front Camera,8MP Samsung® ISOCELL 4H7 Rear Camera
  • Navigation
    GPS+Glonass+Galileo
  • Wi-Fi & Bluetooth
    802.11b/g/n 2.4G ; BT V4.2
  • Network Connectivity
    GSMspec: 850/900/1800/1900 (B2/B3/B5/B8)
    3G spec: WCDMA:B1/B8
    LTE spec: FDD: B1/B3/B7/B8/B20/B19 TDD : B40
  • Card Slots
    Dual Slots; 2*SIM/ 1*SIM+ 1*TF Card
WAVE 6C
8MP
Rear
Camera
5MP
Front
Camera
3 Brand-new
Eye-catching
Color Gradients
2GB RAM+ 2GB RAM =Up to 4GB RAM
32GB ROM +
1 TB TF Expansion
Up to 1.6GHz
Personality Convenience
Privacy Smoothness
Dual Hybrid
Card Slots
SIM*2/ SIM*1+TF*1
Free TPU
Protective
Case
Face Unlock
9.7mm Slim
191g Light
Ratio
60Hz Refresh Rate
20:9 Aspect Ratio
269 PPI
7 hrs Game
7 hrs Video
10 hrs Web
27 hrs Call
35 hrs Music
792 hrs Standby
*The data is tested by Blackview Laboratory. Battery life depends on the actual usage situations. Whether watching movies, playing games or listening to music, WAVE 6C allows you to experience clearer tones and deeper sounds. Relish in the passionate rock music, or the singer's quiet humming.
Up to 4GB RAM
ROM 32GB ROM +
1 TB TF Expansion
5MP + 8MP Cameras Capture Every Brilliant Moment Capture spectacular landscapes, creative videos and exciting sports moments with Blackview WAVE 6C’s 8MP Samsung® ISOCELL 4H7 Rear Camera that delivers incredible details and vivid colors. And don't forget its 5MP front camera, which makes every selfie lively and vibrant.
Gatherings
Cooking Videos
Rock Climbing
Doke OS 4.0 Go
Based on Android 13
Clear Wave
Oil
EasyShare App
Kernel-level security process to effectively protect programs from rooting and attacks
B1-level military security performance, not easily compromised by vulnerabilities
Flexible mandatory access control structure with enhanced level of security protection
Reduces the resources accessible to service processes in the system
Mitigates disasters caused by malicious attacks or malware
Provides a high level of security for information with high confidentiality and integrity requirements
Blackview WAVE 6C
  • Model
    WAVE 6C
  • Colors
  • Dimension
    164.7*76.5*9.7mm
  • Weight
    191g
  • OS
  • Display
  • CPU
    SC9863A
  • RAM & ROM
    2GB RAM + 32GB ROM
  • RAM Expansion
    2GB RAM Expansion
    1TB
  • Battery Capacity
    5100mAh
  • Camera
  • Navigation
    GPS+Glonass+Galileo
  • Wi-Fi & Bluetooth
  • Card Slots
