Blackview Tab 12 Pro 10.1-inch Unisoc Tiger T606 Octa-core 8GB+128GB 6580mAh Battery Widevine L1 Android Tablet PC
$249.99 $149.99
Tab 12 Pro Edgy Inspiration Juices Life up Widevine L1 Support | 10.1-inch Vast Display Doke OS_P 3.0 | 6580mAh Battery...
Capacity: 8GB+128GB
8GB+128GB
Color: Blue
Gray
Blue
Silver
HURRY! ONLY LEFT IN STOCK.
Frequently Bought Together
Total price:$399.96 $269.96
Description
Tab 12 Pro
Octa-core Unisoc Tiger T606 | PC Mode
8GB RAM+Up to 6GB Expansion
  • Thickness : 7.4mm
    Weight : 430g
  • Matte Finish
  • Anodized Coloring Technology
  • Flat Edges
Simple and Slim Body
Can’t Take Your Eyes off
Backed up by an anodized metal body and perfectly embellished with delicate texture, Blackview Tab 12 Pro allows you to feast your eyes on it at distance or up close. Slipping Tab 12 Pro into your tote or handbag is easy-peasy as the tablet is much slimmer and lighter than you’d expected.
  • 10.1-inch
    Expansive Size
  • In-cell Technology
    Thinner and Lighter
  • 1200*1920
    High Resolution
  • 16:10
    Aspect Ratio
  • 81%
    Screen to body Ratio
  • FHD +IPS
    Panel type
  • 300 cd/m2
    Brightness
10.1-inch Vast display
Make Merry out of This Visual Revel
Blackview Tab 12 Pro gives you ample on-screen room and theater-level color gamut with smoother gradients and superb clarity. Browse social feeds or watch live streams on Tiktok to kick back for a while, losing yourself in the exclusive visual spree offered by Blackview Tab 12 Pro.
Widevine L1 Support
1080p Cinematic Fun at Your Palms
Widevine L1 powered, Blackview Tab 12 Pro makes theatre-like enjoyment possible anywhere. Whether it is to watch block-blusters at home or stream the latest animation movies on the subway on Disney+, Amazon Prime Video or Hulu, Blackview Tab 12 Pro has them covered all with 1080p viewing joy.
    • GPU
      G57 1Core @650MHz
    • Expandable ROM
      1TB
    • Unisoc Tiger T606
      Octa-core
    • 8GB RAM
      UMCP
    • AnTuTu
      234000+
    • Expandable RAM
      6GB
    • 128GB ROM
      UMCP
Run Like A Cheetah
Embedded with Cortex A55*6(1.6GHz AP) and A75*2(1.6GHz AP), Unisoc Tiger T606 heightens the speed of data-processing and intelligently transforms the way how AI-tasks are dealt with in the present day. Tab 12 Pro, loaded with Unisoc Tiger T606, will not only deliver stable connection but also remarkable signal penetration.
  • 8GB RAM+ up to 6GB
    Expansion=up to 14GB RAM
    The 8GB RAM is supported by 6GB of virtual RAM, which makes it a total of 14GB of RAM. By expanding RAM, it speeds up your multitasking, gaming, browsing, and more, allowing you to run more apps in the background while making little sacrifice on fluidity.
  • 128GB ROM + Up to 1TB
    TF Support
    1TB expandable storage helps you treasure your creative snapshots, meaningful videos or valuable audio without breaking a sweat.
6580mAh Large Battery
  • Video
    4.5 hrs
  • Music
    14 hrs
  • Game
    4 hrs
  • Web
    6 hrs
  • Standby
    360 hrs
  • Calling
    24 hrs
6580mAh Battery
Get a Kick out of it Longer
Feel upset about low battery when you are having an important conference call with VIP clients or writing your thesis last minute before the deadline? Assisted by a 6580mAh mega battery, Tab 12 Pro allows you to get ahead in life and carry on with your days with long-lasting vigor and power.
* Battery life will vary based on device settings, usage and other factors.
  • 5 MP
    GC5035
    Front Camera
  • 13 MP
    OV13853
    Rear Camera
5MP+13MP Cameras
Snap Ready-to-Share Moment at Will
The 13 MP camera is always dependable on each shutter whim during a birthday party at home, encouraging hike outdoors or more big moments in life, generating knockout photos with ultra-clarity and optimized contrast. 5MP selfie snapper is set to make for ethereal portraits that showcase the best attribute of your face.
  • Take a snapshot of a document and share it with colleagues with a 13MP camera.
  • The 5MP camera enables you to have fluent calls in online conferences or classes.
Dual Box Speakers
Sound that Touches the Heart
Reproducing the sound you heard in real life, from a live concert or wild nature, Tab 12 Pro creates breezy bass, mellow highs and all the melodious acoustic waves that will rock your world. Here awaits you a sound gala from Tab 12 Pro dual Box speakers.
Doke OS_P 3.0 Based on Android 12
Boost Convenience to Amp up Your Productivity
Upgrade in Design, Convenience & Smoothness
  • Gorgeous Design
    Three Themes with New Icons & Wallpapers
  • Higher Efficiency
    The Notes
    WPS Office Suite
  • Better Smoothness
    System Manager
    Cold Room
    Data Migration Assistant
    Game Mode
Smart Pre-Loading
By learning your pattern of app-opening, Doke OS_P 3.0 with Pre-Loading is able to foresee which app you are going to launch and help preload your apps before you open them, hence improving the average app-launching speed by 30%.
Versatile Desktop
Doke OS_P 3.0 renders all the magic tricks that amuse you and save your time. You can group apps together, dismiss folders, lock desktop layout or customize icons with a breeze.
Pristine and Inspiring Themes
  • Bella Flor
  • Rhythm
  • Aurora
Smart Floating Windows
  • Swipe Left or Right and Then Hold for Smart Sidebar
    Customize the Smart Sidebar with often-used apps.
  • Swipe Right for Minus One Screen
    Organize important information all in one space.
  • Swipe Down for Control Panel
    A tap to take screenshot or access drop-down menu with more ease.
PC Mode
Work Faster, Play Harder
Blackview Tab 12 Pro maxes its versatility out by supporting PC mode, which allows you to open multiple app windows at the same time as if you were on a mini-PC or laptop while not compromise on touch-screen efficiency, enhancing the efficiency of everything you do.
Wireless Keyboard and Mouse Support
Reliable Work or Study Partner
With wireless keyboard and mouse support, Blackview Tab 12 Pro can be turned into a mini-laptop or PC anytime or anywhere. Whether you work outdoors or study in a library, Blackview Tab 12 Pro will give a strong boost to your productivity and efficiency.
*The wireless keyboard and mouse are not included.
Dual 4G
Double Online Fun
Blackview Tab 12 Pro supports dual SIMs insertion, which opens up more potential for outdoor online enjoyment. Or you can insert one SIM card and one TF card to expand storage to up to 1TB for a huge amount of digital content.
4-in-1 Navigation
GPS+Glonass+Beidou+Galileo
Whether you are at lost in a strange city or a remote village, Blackview Tab 12 Pro will guide you through your journey with 4-in-1 navigation system that provides precise location and effective route to ease your trip.
Face Unlock
Faster Access to Joy
With Face unlock support, you can access Blackview Tab 12 Pro at a glance without the hassle of entering password or pattern.
*Note: the Face Unlock of Blackview Tab 12 Pro can only be operated horizontally.
Protective Case
Safer and More Protective
To ensure longer life span of Tab 12 Pro, Blackview provides a tablet case to protect the tablet in case of drops.
60° for movies or office work
30° for surfing or chatting
Tempered Membrane
Buy One Get Two
Accidental drops or bumps will never be the problems for Blackview Tab 12 Pro thanks to the ultra-protective tempered membrane.
  • Lunar Silver
  • Space Gray
  • Twilight Blue
  • Model
    Tab 12 Pro
  • Color
    Twilight Blue, Lunar Silver, Space Gray
  • Dimension
    238.5*157.45*7.4mm
  • Weight
    430g
  • OS
  • Display
    10.1 inches, 1200*1920, FHD +IPS
  • CPU
    Unisoc Tiger T606
  • RAM & ROM
    8GB & 128GB
  • Max TF Card Capacity
    1TB
  • Front Camera
    5MP
  • Rear Camera
    13MP
  • Face Unlock
    Supported
  • Battery Capacity
    6580mAh
  • Connectivity
    Wi-Fi version & spec:802.11a/b/g/n/ac(2.4GHz/5GHz)
    Bluetooth version & spec:V5.0
    GSM spec:850/900/1800/1900 (B2/B3/B5/B8)
    3G spec:WCDMA:B1/B8
    LTE spec:FDD:B1/B3/B7/B8/B20 TDD:B40
    View the countries where the use of Tab 12 Pro is supported
  • Dual 4 G LTE
    Supported
  • Dimension
    Length: 238.5
    Width: 157.45
    Height: 7.4mm
    Weight: 430g
Countries Where the Use of
Tab 12 Pro Is Supported
  • Angola
    Armenia
    Aruba
    Austria
    Australian
    Azerbaijan
    Bahrain
    Belgium
    Bhutan
    Brazil
    Bulgaria
    Cayman Islands
    Cambodia
    China
    Costa Rica
    Croatia
    Czech Republic
    Denmark
    Dominican Republic
    Estonia
  • Finland
    France
    Germany
    Greece
    Greenland
    Hungary
    Iceland
    India
    Indonesia
    Italy
    Ireland
    Iraq
    Ivory Coast
    Japan
    Kazakhstan
    Kuwait
    Kyrgyzstan
    Latvia
    Liechtenstein
    Lithuania
  • Luxembourg
    Macedonia
    Malaysia
    Malta
    Mauritius
    Moldova
    Monaco
    Montenegro
    Namibia
    Netherlands
    New Zealand
    Nigeria
    Norway
    Oman
    Paraguay
    Peru
    Philippines
    Poland
    Portugal
    Qatar
  • Romania
    Russia
    Saudi Arabia
    Singapore
    Slovakia
    South Africa
    South Korea
    Spain
    Sri Lanka
    Sweden
    Switzerland
    Tanzania
    Tajikistan
    Thailand
    UAE
    Uganda
    United Kingdom
    United States
    Venezuela
    Zimbabwe
