OSCAL Pad 10 10.1-Inch Display 8GB+128GB 6580mAh Widevine L1 13MP+8MP Camera 4G Android Tablet
$219.99 $159.99
Note: This tablet's 4G network connection can only work in Europe and Asia area, please pay attention before purchasing or consult...
Capacity: 8GB+128GB
8GB+128GB
Color: Green
Gray
Silver
Green
HURRY! ONLY LEFT IN STOCK.
Frequently Bought Together
Total price:$369.96 $279.96
Description
Note:
This tablet's 4G network connection can only work in Europe and Asia area, please pay attention before purchasing or consult us.
Pad 10
Dare to Be Different
Stereo live sound
Smart-K Dual Box Speakers
Smart-K
Widevine L1 Support
Versatile PC Mode
with Keyboard and Mouse Support
6580mAh Battery
432hrs Standby
Octa-core UNISOC T606
AnTuTu 227854
8GB RAM+Up to 6GB Expansion+128GB ROM + Up to 1TB TF Support
RAM Fast 30% Faster
10.1-inch Vast display
Tempered Membrane
13MP rear camera 8MP front camera
Doke OS_P V3.0
Based on Android 12
  • Design
  • Convenience
  • Smoothness
Simple and Slim Body
A Neat and Smart Look
By integrating the latest artistic forms and a impressive sense of technology, OSCAL designers skillfully pack a larger battery into this slimmer-than-ever OSCAL Pad 10. With semi-flat-edged design and upgraded matte finish, OSCAL Pad 10 is pleasing to look and more comfortable to hold.
  • 536g Light
    8.9mm Slim
Mint Green
Moonlight Silver
Diamond Grey
Why to Choose
OSCAL Pad 10
  • Entertainment
    Upgrade
  • Efficiency
    Upgrade
  • Convenience
    Upgrade
Go for Unparalleled Enjoyment
  • Smart-K Dual
    Box Speakers
  • Widevine L1 Support
  • 10.1-inch Vast display
  • 6580mAh Battery
    432hrs Standby
Browse & Stream
Everything So Smoothly
The 10.1-inch bigger display on OSCAL Pad 10 contributes to unlimited visual pleasure with optimized colors accuracy and more splendid details on screen. Thanks to the eye-comfort support, every glance at it just feels smooth and comfortable.
  • Size
    10.1-inch
    16:10
    Aspect Ratio
  • Resolution
    1200*1920
    Screen to Body Ratio (%)
    79%
  • Panel type
    FHD IPS
    Brightness
    350cd/cm2
  • On-line group meeting with upgraded efficiency
  • Have on-line classes together
  • tream videos and socialmedia at the same time
  • Multitasking on the go for greater work productivity
Widevine L1 Support
1080p Cinematic Fun at Your Palms
Widevine L1 powered, OSCAL Pad 10 makes theatre-like enjoyment possible anywhere. Whether it is to watch block-blusters at home or stream the latest animation movies on the subway on, Disney+ or Amazon Prime Video, OSCAL Pad 10 has them covered all with 1080p viewing joy.
Smart-K Dual
Box Speakers
Bring the World to Your Ears
The dual Box speakers of OSCAL Pad 10 will make your acoustic journey more than pleasing with dynamic highs and booming bass. With a smart-K audio chip, OSCAL Pad 10 is powerful enough to produce on site-like stereo sound ready to rock your world.
6580mAh Battery
Big and Bigger Battery
Thanks to the 6580mAh battery, OSCAL Pad 10 delivers longer-than-expected support for all-day outdoor exploration, continuous gaming indulgence or intensive office work. Plus, the 10W charging is timely enough to provide efficient juice-refilling in case you are in a hurry.
  • 4hrs
    Game
  • 4hrs
    Video
  • 6hrs
    Web
  • 15hrs
    Music
  • 20hrs
    Calling
  • 432hrs
Higher Efficiency for Everyday Tasks
  • PC Mode
  • Wireless Keyboard and Mouse Support
  • 8MP+13MP Cameras
  • Octa-core UNISOC T606
    AnTuTu 227854
  • 128GB ROM + Up to 1TB TF Support
    8GB RAM + up to 6GB Expansion
  • Smart Pre-Loading
PC Mode
Work Faster, Play Harder
OSCAL Pad 10 maxes its versatility out by supporting PC mode which allows you to open multiple app windows at the same time as if you were on a mini-PC or laptop, while not compromise on touch-screen efficiency, enhancing the efficiency of everything you do.
Wireless Keyboard
and Mouse Support
Reliable Work or Study Partner
With wireless keyboard and mouse support, OSCAL Pad 10 can be turned into a mini-laptop or PC anytime or anywhere. Whether you work outdoors or study in a library, OSCAL Pad 10 will give a strong boost to your productivity and efficiency.
*The wireless keyboard and mouse are not included.
  • Act as as a mini PC or small-sized laptop with
    touch-screen benefit. Work outdoors with better efficiency
  • Chat with friends like on a PC
  • Write papers on OSCAL Pad 10 in a library
8MP+13MP Cameras
Make Every Shot A Show
Impressive group shots, decent selfies, clear online conferencing or private video calls; you name it, as OSCAL Pad 10 has them covered all with 13MP Sony®IMX319 rear camera and 8MP Samsung®5K4H7 front camera. The duo are capable of satisfying a wide range of photographic needs.
13MP Sony®IMX319
8MP Samsung®5K4H7
On-line meeting for better work communication.
Scan documents or take a picture of slides faster with upgraded clarity.
Speed Is What Matters
From buttery-smooth multitasks to thrilling gaming indulgence, the octa-core UNISOC T606 will always backs you up in your ongoing journey with faster speed and upgraded efficiency.
AnTuTu
227854
  • CPU
    UNISOC T606
    2*A75(1.6GHz) + 6*A55(1.6GHz)
  • RAM 8GB
    up to 6GB Expansion
    RAM 128GB
    Up to 1TB TF
  • GPU
    G57 1*Cocre
    650MHz
  • Expandable Storage
    Max TF Support
    1TB
8GB RAM+ up to 6GB Expansion=up to 14GB RAM
The 8GB RAM is supported by 6GB of virtual RAM, which makes it a total of 14GB of RAM. By expanding RAM, OSCAL Pad 10 speeds up your multitasking, gaming, browsing, and more, allowing you to run more apps in the background while making little sacrifice on fluidity.
8GB RAM +up to 6GB
Upgrade in Design, Convenience & Smoothness
Android 12
Versatile Desktop
Doke OS_P V3.0 renders all the magic tricks that amuse you and save your time. You can group apps together, dismiss folders, lock desktop layout or customize icons with a breeze.
Pristine and Inspiring Themes
Aurora
Rhythm
Thumbling
Smart Floating Windows
  • Swipe Left or Right and Then Hold for Smart Sidebar
    Customize the Smart Sidebar with often-used apps.
  • Swipe Right for Minus One Screen
    Organize important information all in one space.
  • Swipe Down for Control Panel
    A tap to take screenshot or access drop-down menu with more ease.
Other Highlights
  • Dual 4G
  • GPS+Glonass+ Beidou+Galileo
  • Face Unlock
Dual 4G Support
Double Online Fun
OSCAL Pad 10 supporting dual SIMs insertion opens up more potential for outdoor online enjoyment. Or you can insert one SIM card and one TF card to expand storage to up to 1TB for a huge amount of digital content.
    • 4-in-1 Navigation
      GPS+Glonass+Beidou+Galileo
      Whether you are at lost in a strange city or a remote village, OSCAL Pad 10 will guide you through your journey with 4-in-1 navigation system that provides precise location and effective route to ease your trip.
    • Face Unlock
      Faster Access to Joy
      With Face unlock support, you can access OSCAL Pad 10 at a glance without the hassle of entering password or pattern.
      *Note: the Face Unlock of OSCAL Pad 10 can only be operated horizontally.
Tempered Membrane
Buy One Get Two
Accidental drops or bumps will never be the problems for OSCAL Pad 10 thanks to the ultra-protective tempered membrane.
*Protective Case is not included
  • Green
  • Gray
  • Silver
OSCAL Pad 10
  • Mint Green
  • Moonlight Silver
  • Diamond Grey
  • Model
    OSCAL Pad 10
  • Colors
    Mint Green /Moonlight Silver/Diamond Grey
  • Dimension
    241.3*160*8.9mm
  • Weight
    536g
  • Display
    10.1-inch, 1200*1920, FHD IPS
    79% Screen-to-body Ratio
  • CPU
  • RAM & ROM
    8GB + 128GB, UMCP+UMCP
  • RAM Expansion
    Up to 6GB
  • Max TF Card Capacity
    1TB
  • OS
    Doke OS_P V3.0 Based on Android 12
  • Front Camera
    8MP Samsung®5K4H7
  • Rear Camera
    13MP Sony®IMX319
  • Battery Capacity
    6580mAh
  • Speaker
    1217 2PCS BOX Speakers
  • Wi-Fi
    IEEE802.11 a/b/g/n/ac
  • Navigation
  • SIM Slot
    Dual ; 2* SIMs / 1*SIM + 1*TF Card
  • Connectivity
    2G Bands: B2/B3/B5/B8
    3G Bands: B1/B8
    4G Bands: FDD:B1/B3/B7/B8/B20/B19/B28A/B28B
    TDD: B40
