OSCAL Pad 60 10.1-Inch Display Rockchip RK3326S Quad-core 3GB+64GB 6580mAh Android 12 WiFi Tablet
$159.99 $109.99
Oscal Pad 60 Immersive Play, Joys Stay. 2M Front + 5M Rear Cameras Quad-core Rockchip RK3326S 537g Light 9.9mm Thin 10.1-inch...
Capacity: 3GB+64GB
3GB+64GB
Color: Gray
Gray
Blue
HURRY! ONLY LEFT IN STOCK.
Categories: All Products Tablets
Frequently Bought Together
Total price:$304.96 $224.96
Description
Oscal Pad 60
2M Front + 5M
Rear Cameras
Quad-core
Rockchip RK3326S
10.1-inch HD+ Display
6580mAh Battery
Dual Box Speakers with Smart PA
DokeOS_P 3.0 Go Based on Android 12
9.9mm Slim 537g Light
Redefine Elegance with Futuristic Design
Pad 60 is designed to be an incarnation of elegance, with rounded corners perfectly matching with its slim symmetric frame, and spray-coated back with a silk-printing logo. Razor-thin and light as it is, you can hold it in a single hand or pack it up in your tote to take it everywhere you go.
  • Misty Blue
  • Meteorite Grey
Dive into the Vision and Join for Endless Fun
Pad 60 incorporates a wide 10.1-inch HD+ Display, presenting the truest scenario with clear details and vivid color. Whether for reading, binge-watching, or having online conferences or classes, Pad 60 will never fail to indulge your passion.
  • 10.1-inch
    Screen Size
  • 800*1280
    Resolution
  • 16:10
    Aspect Ratio
  • 79%
    Screen-to-body Ratio
  • 300 nit
    Brightness
  • HD+ IPS
    Panel Type
With Great Performance, Just Unleash Your Passion
The quad-core Rockchip RK3326S renders an enhanced performance, whether watching movies, casual gameplay, or moderate multitasking, sufficiently meeting your daily work and entertainment needs.
  • CPU
    4*Cortex-A35 up to 1.5GHz
  • GPU
    Mali-G31MP2
  • Antutu
    69381
RAM: 3GB+ up to 2GB Expansion
ROM: 64GB+ up to 1TB TF Expansion
Enrich Your Fun Experience To Next-level.
Provided by the Memory Expansion Technology, Pad 60 features up to 2GB visual RAM, extending the RAM to up to 5GB without cost and ensuring your smooth experience of app-launching, switching, and simultaneous app-working. 64GB ROM offers ample capacity for your exploration. For more, with a TF card slot, you can add up to 1TB ROM expansion to fully satisfy your desire.
6580mAh Battery
Long-lasting Power Lasts Your Fun
Whether browsing or streaming, Pad 60 with 6580mAh mega power under the hood will be your faithful companion, rendering 6 hours of website browsing and 5 hours of video playback.
*Battery life will vary based on device settings,environment, and other conditions.
  • 4.5 hrs
    Game
  • 5 hrs
    Video
  • 6 hrs
    Web
  • 15 hrs
    Music
  • 312 hrs
2M Front + 5M Rear
Seize the Day, Channel the Present Into the Future
Shoot every moment you want to share with your friends or record your life fragments, all with clarity and details. Weave your story with clear pictures of those trivial moments forward to a brighter future.
Dual Speakers with Smart PA
Hear the World, Feel the Beat.
Pad 60 features dual speakers with smart PA, giving you an authentic texture of sound. Play music or video on the speakers and feel the resonance. You may hear the gurgling of brooks flowing together or the splashing of waves lashing on the sand.
Upgraded Convenience & Smooth
Try to swipe up, down, left or right to find out all the magic tricks of DokeOS_P 3.0 Go.
  • Swipe down for the control panel
    A tap to take a screenshot and switch between Ring/Mute.
    Drop down the menu.
  • Press the volume button for the pop-up window on the right
    Shortcut for sound adjustment of media, alarms and notifications.
    Quick access to sound setting.
  • Refined Animation
    DokeOS_P 3.0 Go witnesses faster and smoother animation of screenshots and all types of floating windows. Always be in sync with you without latency.
  • Pre-installed WPS Office Suite
    Equipped with WPS Office, Pad 60 facilitates your daily work with Excel, Word, PowerPoint, and PDF, from organizing and calculating data with Excel to edit your presentation PPT.
  • Split Screen View
    Split the screen into two and you can launch two apps at once, allowing you to chat with your friends while watching movies or supporting collaborative work with two launched WPS processes, highly improving your productivity.
  • Eye Protection with Dark Mode and Reading Mode
    To release eye strain from long-lasting study or work, Pad 60 is designed with a reading mode and multi-layered dark mode, meeting your needs for eye protection.
  • Model
    Pad 60
  • Color
    Misty Blue, Meteorite Grey
  • Dimension
    246.5*163*9.9mm
  • Weight
    537g
  • OS
  • Display
    10.1-inch, HD+ IPS, 800*1280, 79% Screen-to-body Ratio
  • CPU
  • ROM & RAM
    3GB LPDDR3, 64GB eMMC 5.1
  • RAM Expansion
    Up to 2GB
  • Max TF Card Storage
    1TB
  • Battery Capacity
    6580mAh; 10W Charge
  • Camera
    2MP Front + 5MP Rear
  • WiFi & Bluetooth
    802.11b/g/n (2.4GHz), Bluetooth 4.1
  • Earphone Type
    3.5mm Jack
  • Speaker
    1217 2PCS BOX Speakers
  • Card Slot
    1 TF Card Slot
