Oscal FLAT 1C 6.56" 2+32GB SC9863A Octa-core 4700mAh Massive Battery 4G Smartphone
$139.99 $99.99
OSCAL FLAT 1C Elegant Design, Unlimited Power 9.35mm Slim & 192g Light 3 Brand-new Eye- catching Color Gradients Stand Out with...
Capacity: 2GB+32GB
2GB+32GB
Color: Black
Blue
Purple
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Frequently Bought Together
Total price:$229.97 $159.97
Description
9.35mm Slim
& 192g Light
3 Brand-new Eye-
Stand Out with
Color Gradients
6.56-inch
HD+ Display
Stunning Views on A Bigger Screen
Smart-K Box Speaker More Pleasing to the Ear
4700mAh Massive Battery Unlimited Power,
Non-stop Entertainment
Octa-core SC9863A Up to 1.6GHz Smoothly Respond to Each Task
Personality
Convenience
Privacy
Smoothness
DokeOS 4.0 Go Based on Android 13
Dual Hybrid Card Slots SIM*2/ SIM*1+TF*1
8MP Samsung® ISOCELL
4H7 Rear Camera
Capture Every Brilliant Moment
32GB ROM + 1 TB TF Expansion ROM
5MP Front Camera 2GB RAM+ 2GB RAM Expansion
=Up to 4GB RAM
RAM
Face
Unlock
3 New Eye-catching Color Gradients
Find Your Colors, Find Yourself
Lilac Purple Looking closely, FLAT 1C seems like elegant bloom giving you an extremely tranquil and peaceful atmosphere.
Midnight Black The midnight black accumulates the mystery and tranquility of the night. FLAT 1C looks low-key yet elegant in your hand.
Mint Blue The soft and lively mint blue feels like a cool breeze on your cheeks, particularly refreshing and invigorating.
6.5-inch Bigger Screen Stunning Views on A Bigger Screen Love at first sight - With strong visual impact brought by FLAT 1C , unlike the singular color scheme in the past, this time it adopts a unique gradient design made by an all-new exquisite spray coating process - presenting gorgeous color gradients in the simple back panel, making your style more distinctive and personality more prominent!
6.56-inch
Screen Size
Resolution
720*1600
87.6% Screen-to-
body Ratio
380cd/cm2
Brightness
20:9
Aspect Ratio
269 PPI
Whether watching movies, playing games or listening to music, FLAT 1C allows you to experience clearer tones and deeper sounds. Relish in the passionate rock music, or the singer's quiet humming.
4700mAh Massive Battery Last Longer, Charge Less
Under the hood, the FLAT 1C embeds an above-average battery and turns out to be a strong powerhouse that continuously powers you up, living up to more than a day of regular use. Even that you’re a heavy smartphone user, it still lasts longer than you can expect.
7 hrs Game
7 hrs Video
10 hrs Web
29 hrs Call
32 hrs Music
816 hrs Standby
*The data is tested by OSCAL Laboratory. Battery life depends on the actual usage situations.
Octa-core Unisoc SC9863A Smoothly Respond to Each Task
Clocked at up to 1.6GHz, the OSCAL FLAT 1C , backed by octa-core Unisoc SC9863A, runs multiple apps and multitasks at sufficient fluidity, responsiveness, and efficiency to satisfy your productivity and entertainment needs.
Up to 4GB RAM + 32GB ROM Competent in Daily Multitasking & Storage FLAT 1C has up to 4GB RAM, which allows you to run multiple applications simultaneously and switch between them easily. Additionally, its 32GB ROM, with the option to expand by 1TB TF card, offers enough space for installing applications and storing files, making it suitable for everyday use and providing a satisfying user experience.
RAM ROM
5MP + 8MP Cameras
Capture spectacular landscapes, creative videos and exciting sports moments with Blackview FLAT 1C ’s 8MP Samsung® ISOCELL 4H7 Rear Camera that delivers incredible details and vivid colors. And don't forget its 5MP front camera, which makes every selfie lively and vibrant.
1080P Video Recording
Details Beyond Your Imagination
Whether you are shooting the endless mountains, the flowing rivers, or the swaying trees, FLAT 1C ’s 1080P video recording can present the colors and rich textures close to reality and capture every exquisite detail. When taking portraits, it can also highlight the charm and expressions of the characters, and bring the texture to a higher level.
  • Gatherings
  • Breathtaking Landscapes
  • Cooking Videos
  • Rock Climbing
Doke OS 4.0 Go Based on Android 13
Empower Every Aspect
OSCAL has always focused on user experience improvement and therefore developed the Doke OS Leaping from OS 2.1 to OS 4.0 Go version. The latest upgraded OS brings more friendly features for intuitive visuals and smooth controls. With Android 13, you can also relish new Android highlights.
  • Artistic Themes
    Oil
    Clear Wave
    Two sets of themes are with enriching icons and invigorating wallpapers.
  • DokeOS 4.0 Go renders all the magic tricks for saving your time. You can group apps together, dismiss folders, or lock desktop layouts in a breeze.
    Versatile Desktop
  • Three Eye-comfort Modes
    Dark Mode
    Reduce the light emitted by the screen to decrease eye strain.
    Night Light Mode
    Provide warmer colors at night to promote your sleep.
    Reading Mode
    Create a Kindle-like format for better reading of newspapers and novels.
EasyShare App
With FLAT 1C 's EasyShare app, music, photographs, or files can be exchanged at a transfer rate of 7.7MB/s without any need for a network or traffic. Transfer bigger files and increase your productivity.
Atomized Memory 2.0
Atomized Memory 2.0 with ultra-fine RAM Management System can intelligently divide the RAM that apps use so as to compress it more accurately in smaller units to maximize RAM performance at all times, resulting in 5-9% more RAM available for other processes and allowing more apps in the background simultaneously.
5-9% More RAM Available
Smart Power Saving FLAT 1C’s smart Power Saving Mode extends its battery life by limiting unnecessary background applications and disabling some features to reduce battery consumption.
Cleared Clipboard History Clipboard history will be cleared after a period of time if you allow it to prevent unintended information leakage. With Android 13's support, you will also receive notifications when apps access your clipboard.
Privacy Dashboard Show which apps recently used permissions over the past 24 hours.
Permission Manager Freely control apps' access to all your data, including notifications, location, camera and more.
Security-Enhanced Linux
Kernel-level security process to effectively protect programs from rooting and attacks B1-level military security performance, not easily compromised by vulnerabilities Flexible mandatory access control structure with an enhanced level of security protection
Reduces the resources accessible to service processes in the system Mitigates disasters caused by malicious attacks or malware Provides a high level of security for information with high confidentiality and integrity requirements
More Details
More to Impress
Face Unlock in A Blink Enable the face recognition function to unlock the FLAT 1C quickly at a glance.
3-in-1 Navigation System FLAT 1C supports GPS, GLONASS, and Galileo navigation for faster positioning.
4G LTE Connectivity Deliver fast and stable mobile network experience for better work and play capabilities.
Multiple Card Slots Design More room, more fun. Support the insertion of 2*SIMs /1*SIM+1*TF Card
Free TPU Protective Case Soft TPU materials can significantly reduce damage and provide extra protection.
Model FLAT 1C
Color Black, Blue, Purple
Dimension 164.7*76.5*9.35mm
Weight 192g
OS DokeOS 4.0 Go (Based on Android 13)
Display 720*1600 20:9 HD+ IPS
CPU SC9863A
RAM & ROM 2GB RAM + 32GB ROM
Max TF Card Storage 1TB
Battery Capacity 4700mAh
Camera 5MP Front Camera
Navigation GPS+Glonass+Galileo
Wi-Fi & Bluetooth 802.11b/g/n 2.4G ; BT V4.2
Network Connectivity
GSMspec: 850/900/1800/1900 (B2/B3/B5/B8)
3G spec: WCDMA:B1/B8
LTE spec: FDD: B1/B3/B7/B8/B20/B19 TDD:B40
Card Slot Two (SIM*2 / SIM*1 + TF card*1)
9.35mm 192g
Slim Light
9.35mm Slim
& 192g Light
3 Brand-new Eye-
Stand Out with
Color Gradients
6.56-inch
HD+ Display
Personality
Convenience
Privacy
Smoothness
4H7 Rear Camera
=Up to 4GB RAM
RAM
Face
Unlock
6.56-inch
Screen Size
Resolution
720*1600
87.6% Screen-to-
body Ratio
380cd/cm2
Brightness
20:9
Aspect Ratio
269 PPI
7 hrs
Game
7 hrs
Video
10 hrs
Web
29 hrs
Call
32 hrs
Music
816 hrs
Up to 4GB RAM + 32GB ROM Competent in Daily Multitasking & Storage FLAT 1C has up to 4GB RAM, which allows you to run multiple applications simultaneously and switch between them easily. Additionally, its 32GB ROM, with the option to expand by 1TB TF card, offers enough space for installing applications and storing files, making it suitable for everyday use and providing a satisfying user experience. RAM ROM 5MP + 8MP Cameras Capture spectacular landscapes, creative videos and exciting sports moments with Blackview FLAT 1C ’s 8MP Samsung® ISOCELL 4H7 Rear Camera that delivers incredible details and vivid colors. And don't forget its 5MP front camera, which makes every selfie lively and vibrant.
  • Gatherings
  • Cooking Videos
  • Rock Climbing
  • Artistic Themes
    Oil
    Clear Wave
    Versatile Desktop
    Dark Mode
    Night Light Mode
    Reading Mode
EasyShare App
Atomized Memory 2.0
More Details
More to Impress
Model FLAT 1C
Weight 192g
CPU SC9863A
B40
9.35mm 192g
Slim Light
