Blackview Tab 30 Wifi 10.1-inch 2+64GB 5100mAh WiFi 6 Widevine L1 Support Android Tablet PC
£115.00 £84.00
TAB 30 WIFI Blazing Speed, Seamless Connectivity 10.1-inch HD + IPS 2 Eye Comfort Modes Black-white Mode/Night Light Mode Widevine L1...
Capacity: 2GB+64GB
2GB+64GB
Color: Gray
Blue
Gray
HURRY! ONLY LEFT IN STOCK.
Tags: Wifi
Frequently Bought Together
Total price:£185.00 £146.00
Description
TAB 30 WIFI
Connectivity
10.1-inch HD + IPS
2 Eye Comfort Modes
Widevine L1 Support
1080P Disney+, Amazon Prime Video, Youtube
WiFi 6 Technology
5100mAh
Massive Battery
Quad-core
Allwinner A133P
Up to 1.8 GHz
Dual Box Speakers
2GB RAM + Up to 4GB Expansion
64GB ROM + Up to 128GB TF Expansion
Android 13
Small in Size, Versatile in Use
Think a phone is too small, a laptop too heavy? Introduce Blackview Tab 30 WiFi, a mighty hybrid, designed for those with requirements in between and for whoever thinks out of the box.
Best for
Students
Workplace newbies
The elderly
Dream Device for Students
Enjoy tech life in the most economical way
10.1-inch HD+ display
Light up the screen and the resolution gives you an ideal vision for productivity tasks, reading and entertainment.
2 Eye Comfort Modes
Customized for Your Eye Health
Tab 30 WiFi has two eye comfort modes to take care of your eye health. Night Light Mode provides warmer colors at night to help you fall asleep more easily while Black-white Mode reduces the light emitted by the screen and prevents eye fatigue when reading for an extended period of time.
Black-white Mode Night Light Mode
Widevine L1 Support
With Widevine L1 support, you can get access to 1080P Full HD video streaming on platforms like Disney+, Amazon Prime Video, and Hulu. Don't be afraid of missing out on the latest epic sci-fi movies, action-packed fighting movies, or thrilling horror movies, breaking free from the high pressure of daily work and studies.
8MP rear camera
The versatile back camera enables you to record the classes, scan documents, and capture memorable moments at school.
Stuck on a question?
Look it up right away
Whenever you’re stuck while doing homework or writing papers, take your Tab 30 WiFi right from your bag or your big-sized pocket and an encyclopedia unfolds for you on a big screen!
Root for workplace newbies
Give an edge to your work, a spur to your life
Make your clients happier
The super portable, big-screen Tab 30 WiFi is always ready and available to impress your clients in a pinch whether for retrieving documents and critical information or bringing up a sample room display and virtual panoramic tour. Sealing the deal is just easy.
Your pocket theater
What’s better than watching a movie or Tiktok to unwind after work? Tab 30 WiFi comes into play for immediate off-work chill.
WiFi 6 Technology
Make Latency A Thing of The Past
With advanced WiFi 6 technology utilized on Tab 30 WiFi, streaming just got so much better and you can relish 8K movies, large file downloads and uploads, and responsive games – all without buffering. Enjoy rock-solid coverage from your garage to the second story and get ultra-fast connections.
Faster
transmission
speed
Lower
power
consumption
Wider
coverage
Stronger
security
Quad-core Allwinner A133P
Power for Better Efficiency and Smoothness
From responsive app launching through smooth video streaming to seamless light-duty multitasking, the Allwinner A133P nails them all without a sweat. Get your basic daily entertainment needs perfectly satisfied.
4GB RAM + up to 4GB Expansion
With large storage capacity, Tab 30 WiFi allows you to download storage-occupying movies and more music, work files and a wide range of productivity apps for efficient work styles. Tab 30 WiFi provides the new Memory Expansion Technology that extends the 4GB RAM to up to 8GB, giving you an edge to open more apps simultaneously and switch between different apps with ultra-smoothness.
5100mAh big battery
Extend your joy with extended battery life. Tab 30 WiFi never runs out of battery as you watch movies, surf the internet, and play games on your way home.
Friendly to use
For the elderly
Easy to read, even for the presbyopia
Compared to a phone, Tab 30 WiFi’s 10.1-inch big screen makes it better to read messages and news. For the elderly with the presbyopia problem, the word size can be enlarged even wider from the Setting.
Easy to pick up and hold
Slim and weighing just 520.5g, Tab 30 WiFi can be effortlessly held in one hand while sitting on a chair, couch, or lying in bed.
Easy to hear with dual-box speakers
Tab 50 WIFI is equipped with dual-box speakers that produce loud sounds. Even in noisy environments, such as crowded buses or bustling markets, elderly users can easily hear every important phone call.
Android 13
Convenience Upgrades
Per-app Language Preferences
Assign different language settings to individual apps on Tab 30 WiFi, allowing you to seamlessly switch between languages.
Power Saving Mode
Enable dark theme, and restrict or shut down some background activities to extend battery life, allowing you to use it for a longer period.
*When charged above 90%, power saving mode will turn off automatically.
Handy Tools
Alarm
Set alarms for your important events and make sure you don't miss every task.
Bedtime
Stopwatch
Take more accurate control of your time when exercising or playing sports.
Timer
Set a countdown for what you're going to do in the future with sound alerts.
Fluency Upgrades
Refined Animation
Android 13 witnesses faster and smoother animation of screenshots and all types of floating windows. Always be in sync with you without latency.
CPU Scheduling
Thanks to CPU Scheduling, Tab 30 WiFi automatically adjusts the CPU frequency to make CPU-intensive apps run smoother and easier while saving more power on your tablet when running lightweight apps.
Smart Pre-Loading
Tab 30 WiFi predicts which apps you are going to launch and helps preload the apps beforehand, thus increasing the app launch speed by 7%.
Fluency Upgrades
Privacy Dashboard
Show which apps recently used permissions over the past 24 hours.
Permission Manager
Freely control apps' access to all your data, including notifications, location, camera and more.
Notifications on
the Lock Screen
You can choose to show all notification content on the lock screen or not.
Glacier Blue
Space Grey
Model
Tab 30 WiFi
Colors
Glacier Blue, Space Grey
Dimension
246*162.7*9.85MM
Weight
520.5g
Display
10.1-inch 800*1280 HD+ IPS
79% Screen-to-body Ratio
CPU
RAM & ROM
2GB + 64 GB, LPDDR3 + EMMC
RAM Expansion
Up to 4GB
Max TF Card Capacity
Up to 128GB
Card Slot
One TF Card Slot
Cameras
5MP Front + 8MP Rear
Battery
5100mAh ; 10W Charge
Speaker
1217 Dual Speakers
Wi-Fi
WIFI6 (2.4G+5G) 802.11a/b/g/n/ax/ac
OS
Android 13
