Blackview N6000 4.3-Inch MediaTek Helio G99 8GB+256GB 48MP Camera 4G Small Ruggedized Phone
$259.99 $199.99
✔4.3 Inch Display & 208g Light
✔3880mAh Solid-state Battery
✔Corning® Gorilla® Glass 5
✔Multifunctional NFC
Capacity: 8GB+256GB
8GB+256GB
Color: Green
Green
paypalvisamastermaestrojcbamerican expressdiners clubdiscovercartes bancairesklarnaafterpaygoogle payapple pay
Description
Blackview N6000 Classical in Palm, Super Durable
&Ultra-High Specifications.
4.3-inch Screen Seize All the Information in A Glance
208g 65.25mm Wide
& 208g Light
3,880mAh Battery Up to 18 days
of Standby
Solid State Battery
Withstand extreme temperatures (-40 -80 )
Corning® Gorilla®
Glass 5
2x scratch resistance
100,000 times wear-
proof lineation test
Leading IP68&IP69K
Underwater Submersion for Up to
15 meters about 30 mins
MIL-STD 810H
Up to 5m Death Broke
Drop-proofness
Throw-proofness 60meters
Up to 16GB RAM 8GB RAM + 8GB Expansion
256GB ROM
Octa-core
MediaTek Helio G99
Exceed some of 5G Chipsets 6nm 2* Cortex-A76 (2.2GHz) +6* Cortex-A55 (2.0GHz)
AnTuTu 403,181
Fourfold Cooling System Up to 15°C Temperature Reduction
Constant Temperature at
40°C in Video Streaming
Smart Pre-loading
25% faster app start-up
Low Memory Killer
15% smoother and
more efficient
Atomized Memory
17% faster and
more fluent
From Android 12 to Android 13
Personality Privacy
Security
15% of Photography
Improvement
16MP Front Camera
48MP
Rear Camera
Samsung® ISOCELL GM2 1/2” AF Higher Light Sensitivity in
Low-lit Conditions
Fearless to the night
Smart
Google Lens
Translation & Recognition
& Text Extraction
Fingerprint &
Face Unlock
Ultra-linear Box Speaker
with Smart-PA
BesLoudness Hi-Fi Mode
DokeOS 3.1 Simpler and More
Considerate
Customized Shortcut Button Single-tap Access to Apps
Dual SIM Standby GSM Support
Multifunctional
NFC
Why choose N6000?
No.1 In Mini Size, Of Great Use
No.2 Top Ruggedness
No.3 New-level Performance
No.4 Remarkable Photography
NO.1 Pack with Ease Where You Go
4.3-inch Screen Seize All the Information with A Glance
65.25mm Wide & 208g Light
Comfortably
Fit in a Palm
QHD+ Display Clearer and Sharper Fonts
Ultra-linear Box Speaker with Smart-PA Clearer Voice and Higher-quality Audio
of Standby
4.3-inch Screen View All in a Glance, Done All
with a Thumb
4.3
Take N6000 out. Hold it in your hand and operate with only a thumb swiping left, right, up and down. Whether checking information, or sending messages, all made easy on the 4.3-inch N6000.
  • 4.3 inch
    Screen Size
  • 83%
    Screen-to-body Ratio
  • 20:9
    Aspect Ratio
Compact and Light, Greatly
Fit in Your Hand
N6000, a uni-body with symmetrical design and measuring a width of a credit card of 65.25mm , makes it snugly fit in a palm and renders a comfort grip.With a compact body of only 208g, you can bring it with you lightly, in your pocket, bag, anywhere.
65.25mm Wide about the same width
of a credit card
208g Light relieve hand numbness
for longtime use
QHD+ Display Bring All Your Content to Life
N6000, housing a QHD+ display with 540*1200 resolution , renders 306 PPI for more dynamic images and sharper text. The display is always brilliant with 450 nits of brightness. Viewing can be truly comfortable both indoors and outdoors.
QHD+ TN Screen Type
540*1200 Resolution
306 PPI
450nits Brightness
MiraVision Technology Enhanced visual experience achieved by intelligently altered picture attributes
3,880mAh Battery with
Up to 18-day Standby
Mini Sized, Long-lasting Powered
Thanks to the dual cell solid state battery introduced by professional Blackview R&D Team, N6000 incorporates a 3880mAh battery under the hood. With only one single charge, N6000 ensures a longer exploration and constant fieldwork for you in the outdoors with up to 18 days of standby.For only 87 minutes, N6000 will be ready for your journey at full charge with a 18W fast charge.
Solid State Battery Liquid State Battery with Same Battery Capacity
Higher energy density --Slimmer and Lighter Better chemical stability --Longer life span and Safer in use
18 days Standby
22 hrs Calling
6 hrs Game
13 hrs Music
10 hrs Website
7 hrs Video
Ultra-linear Box Speaker with Smart-PA Louder and Brighter, Clearer and Smoother
Coupled with a Smart-PA ultra-linear box speaker, working in tandem with sound enhancement
options, N6000 can serve as ‘an interphone’ in a noisy environment; or as a music player for a feast for your ears, N6000 escorts your audio journey with peace of mind.
Sound Enhancement
BesLoudness Brighter and clearer voice
Hi-Fi Mode Higher-quality music and audios
NO.2 Top Ruggedness
Corning® Gorilla® Glass 5 2x scratch resistance
MIL-STD 810H
Leading IP68&IP69K
Solid State Battery
Useful ToolKit
Death Broke Drop-proofness
5 meters
Throw-proofness
60 meters
Deep Underwater 15meters for 30mins
15m
Survive in temperature
extremes from
Weight-bearing capability
of up to
20,000kg
100,000 times
Wear-proof Lineation
Test
Forged to Redefine Ruggedness Despite its mini size, N6000 is engineered by Blackview, which has been devoted to rugged smart devices for more than 10 years, from inside out, with elaborate design and is made of selected materials to level up its ruggedness for water, dust, shocks, drops, and rough elements to new heights.
Double-shot molding TPU & glass fibre back shell cover for greater anti-shock protection and abrasive resistance Aluminium alloy side frames fixed with screws for enhanced integrity from shocks and drops
Thickened rubber corners for shock-resistance
Tightly-fit cap for charging port for enhanced
water- and dust- resistance
Rest Assured from Scratches and Cracks
Blackview built N6000 with Corning® Gorilla® Glass 5 as its screen for improved toughness to protect it from cracks and thick scratches caused by accidental drops and falls.
Compared to competitive
aluminosilicate glass
MIL-STD 810H Gear Up for Any Situations To meet with people like outdoor enthusiasts in the modern age pursuing outdoor activities and facing dangerous uncertainties, Blackview N6000 has passed through a barrage of tests with military spec 810H for your peace of mind while confronting harsh environments.
N6000 has undergone tests that include but are not limited to:
Rain
Sand and Dust
Vibration
Shock
Acceleration
High Temperature
Low Temperature
Humidity
Altitude
Immersion
Leading IP68 & IP69K Water and Dust, Not a Problem.
Still worry about phones dropping off into the water or suffering damages from dust and water? With an ingress protection rating of IP68 & IP69K, N6000 is certified to be impervious to water and dust. Bring N6000 with you to a damp and dusty environment with confidence and smoothly get your work done.
Solid State Battery
Strongly Power You Up from -40℃-80℃
With the solid state battery incorporated, N6000 is fearless of temperature extremes ranging from -40 -80 (-40°F to 176°F). Through tests like needling, the built-in battery empowers N6000 with greater capability to withstand high pressure and drop impact. Whether through the glaciers and mountains or across the desert, you will be backed up with N6000, your faithful assistant rendering useful help on your way adventuring.
Safer and more Stable
More Tolerant of temperature
extremes (-40
-80 )
Greater Capability to withstand high
Thrown into Whatever Extreme Conditions,
N6000 Dare to Take the Challenges
Accidental oil and splatters
during meals
Spluttered hot coffee
while working
Falling from heights while doing
extreme sports like parkour
Dropping into a stream
during hiking
NO.3 New-Level Performance
6nm
Octa-core
MediaTek Helio G99
Constant Temperature at 40°C in Video Streaming
GPU ARM Mali-G57 CM2
Up to 2,133MHz
LPDDR4X
+ UFS2.1
256GB ROM
Smart Pre-loading
AnTuTu 403,181
Atomized Memory
17% faster and
more fluent
Low Memory Killer
15% smoother and
more efficient
Considerate
Data Protection
Personality Privacy
Security
Per-app language
preferences
App Pinning
DAC&MAC Double Protection
Double Data Security
Eye Comfort
Settings
Notification
permissions
Cleared clipboard
history
New Step-
Count App
All-new
control
panel
6nm MediaTek Helio G99 Catches up with and
Surpasses Some of 5G Chipsets
6nm MediaTek Helio G99 Strong Heart, Powerful
Performance
Treated by 6nm-class production process,
MediaTek Helio G99 , featuring 2 high-performance Arm Cortex-A76 processors and a capable Arm Mali G57-class GPU with data access of LPDDR4X memory up to 2,133MHz and UFS2.1-class storage, renders exceptional performance for N6000 in games, apps and everyday activities with incredible power efficiency.
  • RAM
    Up to 16GB
    LPDDR4X
  • ROM
    256GB
    UFS2.1
  • CPU
    High Performance Multitasking
  • GPU
    Arm Mali G57
    High Power Efficiency
MediaTek HyperEngine 2.0 Lite Gaming Technologies Resource Management Engine 2.0 This feature ensures sustained performance and smoother gameplay that lasts longer.
Intelligent, dynamic management of CPU, GPU and memory according to active measurement of power, thermal and gameplay factors. Smoother performance in heavy-loading game engines, demanding scenes and intense gameplay. Hardware and software enhancements for high FPS power savings and longer battery life without sacrificing the user experience.
Networking Engine 2.0
N6000 with Networking Engine gives faster response and more reliable connectivity to ensure you always stay connected, even when you defer calls while in-game.
Antutu Benchmark
Predecessor N6000
353,283 403,181
49,898 score higher than its predecessor Higher performance to be faster,
more fluid and more responsive
8GB RAM + 8GB Expansion = Up to 16GB RAM 256GB ROM
Go Further than to Suffice
N6000 enables you to store more files and apps with 256GB ROM. With up to 16GB RAM , of which 8GB can be expended without cost, N6000 tackles multitasking and data processing in a breeze.
8GB RAM + 8GB Expansion= Up to 16GB RAM
20%
Faster Multitasking
and data processing
1:1 RAM Expansion
Fourfold Integrated Cooling System CPU Temperature Reduction Up to 15°C
1,175.9mm²
Cooling copper foil
168mm²
Cooling silicon
2,925mm²
Cooling graphite
1,180mm²
Cooling graphite copper
Constant Temperature at 40°C in video streaming
Smart Pre-Loading
With Smart Pre-loading backed by DokeOS 3.1, N6000 can anticipate which app you are going to launch and help accelerate your app launching speed by 25% .
Useful ToolKit Your Handy Good Helper
Compass
HeightMeasure
Torch
SoundMeter
Whether for kicking start a rugged life or for daily life use, N6000 will be your trusted aide to include all you need in the useful ToolKit.
Protractor
Mirror
Alarmbell
Magnifier
Pic Hanging
Plumb Bob
Barometer
Atomized Memory Technology
Atomized Memory is a RAM optimization engine. It
analyzes the memory usage pattern of your apps and compresses the RAM of each app into the smallest possible unit to ensure the best RAM performance. As a result, N6000 launches apps and multitasks faster by
17%.
Low Memory Killer Technology
With the advanced Low Memory Killer (LMK), N6000 prioritizes foreground apps with more memory and CPU computational power by intelligently reducing unimportant background app processing to achieve up to 15% smoother and more efficient system running during multitasking.
Brand-new Experience Brought by All-new Platform
From Android 12 to
The Latest
Android 13
Personality
Privacy
Security
Blackview utilizes Android 13 on N6000 to bring users a newer experience from Android 12 with upgrades for more personal settings and more comprehensive protection with higher privacy and security.
Per-app language preferences Always the right language. Assign different language settings to individual apps, so that you can move fluidly between languages on your device, just like in real life.
DAC & MAC Double Protection
Safeguards Your
Privacy.
As DAC (Discretionary Access Control) allows a lot of freedom for users and has several considerable limitations, rendering flexibility, scalability and simplicity for a simple and uninterrupted workflow, N6000 delivers a higher level of security with MAC (Mandatory Access Control), whose high privacy has been embodied by its application to the NSA.
Security that
keeps your data
protected all day.
From the moment that you turn on N6000, it works to keep your data safe and secure. You have more control over what information apps can and can’t access - including specific photos, videos and clipboard history.
Notification permissions Stop the dings,
rings, and
pings.
You’re in control of which apps can send you notifications - helping you limit distractions.
Cleared clipboard
history
With Android 13, N6000 has safeguards built in to help protect your personal data. To protect the information on your clipboard, you’ll get an alert when an app accesses it, and your clipboard history will be cleared after a period of time to prevent unwanted access.
Permission Manager Get non-stop
protection at
every turn.
Afraid of theft of information from malware and want to get rid of hassling from spam? N6000 will ease those for you. You will be the only decider of which apps to access your information.
App Pinning This feature allows you to keep the current app in view until you unpin it.
The Up-to-Date DokeOS 3.1 Simpler and More Considerate Matching with its mini size, N6000 is engineered with the newly-customized DokeOS 3.1 UI system to render users an all-new experience to lead a simple lifestyle with simpler interface and more considerate settings for daily use.
Control Panel One Touch, Easy Reach
Add frequently used functions here on the control panel and quickly switch to the settings. Quick power key to turn the phone off. With one tap, all active apps in view. Manage apps to improve the functionality.
New StepCount App Every Step Counts Blackview Software Team has streamlined the cumbersome programs to simplify your busy lifestyle. Just set up your workout schedule. N6000 will track your daily steps to help you develop a healthy lifestyle.
Eye Comfort Modes Adjust the colors and textures of the items on your screen to deliver a more comfortable and enjoyable visual experience.
NO.4 Remarkable Photography
48MP Rear Camera
Low-lit Conditions
16MP Front Camera
Pro Mode Create Your Own Artistic Style
Face Fill Light
2K Video Recording
15% of Photography
Improvement
Improved HDR Handle Diverse Exposure Levels
Night Mode Never Miss any Detail
Beauty Mode Naturally Airbrushed Faces
Portrait Mode You Are the Main Character
360° Panorama Expansive Scenery in Full View
Encapsulate Every Memorable Moment 48MP Rear Camera
Ready For Any Moment
Whether day or night, indoors or outdoors, Blackview N6000 with 48MP Samsung® ISOCELL GM2 rear camera will never let you down to render vibrant pictures with the same clearness.
TetraPixel Technology Replicate night landscape with jaw-dropping light sensitivity
Super-PD Auto Focus Capture every motion in sight with clearness
Smart-ISO With less noise in low-lit environment while with more detail and in more vivid color in sunny outdoors
16MP Front Camera Click away, Features Stay.
Taking advantage of Re-mosaic Algorithm and its Quad Bayer color filter array, the 16MP SK Hynix® HI-1634Q front camera renders satisfying photography performance with high color accuracy, replicating the truest color of people, food, landscapes, and more. Whether video calls or selfie shooting, all are made easy with N6000. Crack a smile and freeze it with vivid images.
the photographic results of the camera modes by 15% !
Improved HDR
Blackview combines HDR for a natural rendering of vibrant pictures at different exposure levels. This feature enables shooting for various scenarios with great details and vivid colors.
Night Mode Night mode brings night photography to the next level, capturing clear pictures with more details even in dimly-lit conditions.
Beauty Mode
Beauty Mode automatically airbrushes faces with blemishes brushed away for refined skin texture and complexion, delivering natural faces.
360° Panorama
Panorama seamlessly stitches all you see into one frame. Turn to the Panorama and shoot an endless captivating vista of snow peaks and shadowed valleys.
Portrait Mode
Portrait Mode captures pictures with naturally blurred backgrounds and more conspicuous subjects. Explore More Photographic Fun with N6000
Pro Mode Challenge More Photographic Possibilities Blackview assigned N6000 with Pro mode for customized photography. Attributes can be adjusted as you want. Play with light and shade and explore more possibilities with Pro Mode.
Cinematic 2K Video Recording with Beauty Mode Every Marvelous Motion Maintained Being a vlog master can’t be ever easier with 2K video recording, even with Beauty Mode. Every moment freezes and every frame in the video stays alive.
Face Fill Light Taking a selfie outdoors at night is a complete no-brainer with Face Fill Light. Selfie-friendly N6000 lets you never comprise on light conditions and take pictures of yourself and friends day or night.
Master Your Life with N6000
Smart Google Lens Intelligent Search, Efficient Life.
Through the lens, instantly get all done, including translation, text extraction, recognition, and even more. Just open the camera, take a picture and choose the right way to solve your problem.
GPS & GLONASS & Beidou & Galileo Precise Location for Secure Journey.
With the 4-in-1 navigation system, security on your adventure is ensured and all you need to do is to input your destination and follow the direction.
Fingerprint & Face Unlock Safeguard Your Privacy
Get rid of too many passwords in your career by granting your fingertip unlock and face unlock. With a glance or a touch, you can get into N6000 in a minute and only you.
Multifunctional NFC N6000 with NFC support facilitates your life further, data exchange, mobile payment, public transport ticket purchase and even more.
2.5W OTG Reverse Charging Support Your Backup Power Bank at Standby While you forget to charge your wireless earphone and you are in the middle of enjoying your concert, that it suddenly ran out of juice happens. This feature will serve to help.
Customized Shortcut Button Tap, Press, and Get into the App With custom key settings enabled, N6000 makes one-handed operation even easier. Program and quickly reach your frequently-used apps with a single tap or a long press on the side button.
Sound Recorder
Camera
ToolKit
Maps
Payment App
FM Radio
Dual 4G VoLTE Stay Wired and Stay Connected With dual nano SIM slots, N6000 supports dual 4G VoLTE. You can switch flexibly between to get the best internet choice and ensure a stable internet connectivity. No more worries about losing connection.
Green
  • Model
    Blackview N6000
  • Colors
    Black, Orange, Green
  • Dimension
    133*65.25*18.4mm
  • Weight
    208g
  • OS
    DokeOS 3.1 Based on Android 13
  • Display
    4.3-inch QHD+, 60Hz Refresh Rate,
    540*1200 Resolution, CORNING® GORILLA® GLASS 5
  • CPU
    MediaTek Helio G99 (6nm),
    Octa core(2 *A76@2.2GHz + 6* A55@2.0GHz)
  • RAM & ROM
    8GB RAM & 256GB ROM, LPDDR4X+UFS2.1
  • RAM Expansion
    Up to 8GB
  • Battery
    3,880mAh, 18W Fast Charge
  • Front Camera
    16MP (SK Hynix® HI-1634Q)
  • Rear Camera
    48MP (Samsung® ISOCELL GM2)
  • Speaker
    Ultra-linear Box Speaker with Smart-PA, 1 PCS
  • Rugged Rating
    IP68 & IP69K & MIL-STD 810H
  • Navigation
    GPS+GLONASS +Beidou+Galileo
  • Card Slot
    Dual Nano SIM Slots
  • NFC
    Support
  • Wi-Fi
    IEEE802.11 a/b/g/n/ac
  • Network Connectivity
    GSM spec: B2/B3/B5/B8
    3G spec: B1/B2/B4/B5/B8
    LTE spec: TDD: B38/B40/B41,
    LTE:FDD:B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/ B20/B28A/B28B/B25/B26//B66,
    CDMA:BC0/BC1/BC10
208g 65.25mm Wide
& 208g Light
of Standby
Solid State Battery
Withstand extreme
temperatures (-40
-80 )
Corning® Gorilla®
Glass 5
100,000 times wear-
Leading IP68&IP69K
Underwater Submersion for Up to 15 meters about 30 mins
MIL-STD 810H
Drop-proofness
60m
256GB ROM
Octa-core
MediaTek Helio G99
AnTuTu 403,181
Smart Pre-loading
Low Memory Killer
15% smoother and
more efficient
Atomized Memory
17% faster and
more fluent
Personality Privacy
Security
15% of Photography
Improvement
16MP Front Camera
Fingerprint &
Face Unlock
Smart
Google Lens
& Text Extraction
48MP
Rear Camera
Low-lit Conditions
with Smart-PA
Considerate
Multifunctional
NFC
Why choose N6000?
No.2 Top Ruggedness
Comfortably
Fit in a Palm
of Standby
4.3-inch Screen
4.3
Screen-to-body Ratio 83% Aspect Ratio 20:9
Fit in Your Hand
of a credit card
for longtime use
QHD+ TN Screen Type
540*1200 Resolution
306 PPI
450nits Brightness
with a Thumb
18 days Standby
22 hrs Calling
6 hrs Game
13 hrs Music
10 hrs Website
7 hrs Video
*The data is tested by Blackview Laboratory based on continuous use.
Battery life depends on the actual usage situation.
Coupled with a Smart-PA ultra-linear box speaker , working in tandem with sound enhancement options, N6000 can serve as ‘an interphone’ in a noisy environment; or as a music player for a feast for your ears, N6000 escorts your audio journey with peace of mind.
Sound Enhancement
NO.2 Top Ruggedness
2x scratch resistance 100,000 times
wear-proof lineation test
MIL-STD 810H
Leading IP68&IP69K
Solid State Battery Lighter and Slimmer
Safer and More Stable
Useful ToolKit
5 meters
5m
Throw-proofness
20 floors about
60 meters
60m
15m
extremes from
-40°C 80°C
of up to
20,000kg
100,000 times
Test
Corning ® Gorilla ® Glass 5
Compass
HeightMeasure
Torch
SoundMeter
Protractor
Mirror
Alarmbell
Magnifier
Pic Hanging
Plumb Bob
Barometer
Solid State Battery
With the solid state battery incorporated, N6000 is fearless of temperature extremes ranging from -40 -80 (-40°F to 176°F) .Through tests like needling, the built-in battery empowers N6000 with greater capability to withstand high pressure and drop impact. Whether through the glaciers and mountains or across the desert, you will be backed up with N6000, your faithful assistant rendering useful help on your way adventuring.
extremes (-40
-80 )
Accidental oil and
splatters
during meals
while working
while doing extreme
sports like parkour
during hiking
6nm
Octa-core
MediaTek Helio G99
Up to 2,133MHz
LPDDR4X
+ UFS2.1
256GB ROM
Smart Pre-loading
AnTuTu 403,181
Atomized Memory
17% faster and
more fluent
Low Memory Killer
15% smoother and
more efficient
Considerate
Data Protection
Personality Privacy
Security
Per-app language
preferences
App Pinning
Eye Comfort
Settings
Notification
permissions
Cleared clipboard
history
New Step-
Count App
All-new
control
panel
Performance
  • RAM
    Up to 16GB
    LPDDR4X
  • ROM
    256GB
    UFS2.1
  • CPU
  • GPU
    Arm Mali G57
1:1 RAM Expansion
Faster Multitasking
and data processing
Smart Pre-Loading
17%.
48MP
Rear Camera
Samsung® ISOCELL GM2 1/2” AF Higher Light Sensitivity in Low-lit Conditions Fearless to the night
16MP Front Camera
Face Fill Light
2K Video Recording
15% of Photography
Improvement
48MP Rear Camera Ready For Any Moment
Improved HDR
Night Mode
Beauty Mode
360° Panorama
panoramic
Portrait Mode
Photographic
Possibilities
Google Lens
  • Model
    Blackview N6000
  • Colors
  • Dimension
    133*65.25*18.4mm
  • Weight
    208g
  • OS
  • Display
  • CPU
  • RAM & ROM
  • RAM Expansion
    Up to 8GB
  • Battery
  • Front Camera
  • Rear Camera
  • Speaker
  • Rugged Rating
  • Navigation
  • Card Slot
    Dual Nano SIM Slots
  • NFC
    Support
  • Wi-Fi
    CDMA:BC0/BC1/BC10
Rain Sand and Dust Vibration Shock Acceleration
High Temperature Low Temperature Humidity Altitude Immersion
response
Antutu Benchmark
Predecessor N6000
403,181
353,283
20%
1175.9mm² Cooling copper foil
168mm² Cooling silicon
2925mm² Cooling graphite
1180mm² Cooling graphite copper
From Android 12 to
The Latest
Android 13
Personality
Privacy
Security
Safeguards Your
Privacy.
Security that
keeps your data
protected all day.
rings, and
pings.
Cleared clipboard
history
protection at
every turn.
Specification
Design
ProductN6000
OSDoke-OS 3.1 ( Based on Android 13)
ColorBlack, Orange, Green
Weight208g
Dimensions133*65.25*18.4mm
Screen
LCD panelPV043FBE-T40-2QP0
ICST7703I-G5-DP
Panel TypeIPS
Display ResolutionQHD+
Screen Size4.3 Inch
Screen Resolution540*1200
Screen to Body Ratio (%)83%
Viewing angle (H/V)Full angle
PPI/DPIPPI:306
GlassCORNING® GORILLA® GLASS 5
Connectivity
WIFI 802.11a/b/g/n/ac
Bluetooth V5.2
2G2/3/5/8
3G WCDMA: B1/B2/B4/B5/B8
CDMA: BC0/BC1/BC10
4G TDD: B38/B40/B41
FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B28A/B28B/B25/B26//B66
Hardware
CPUMediaTek Helio G99(MT6789) Octa Core
CPU Clock 2*Cortex-A76 @ 2.2GHz; 6*Cortex-A55 @ 2.0GHz
GPUARM G57 MC2
RAM8GB
RAM TypeLPDDR4X
ROM256GB
ROM TypeUFS2.1
TF Card SlotNO
USBTYPE-C
Camera
Front Camera 16MP
Front Camera SensorSK Hynix® HI-1634Q
Front Camera Aperturef2.2±5%
Rear Camera 48MP
Rear Camera Sensor Samsung® ISOCELL GM2
Rear Camera Aperture f1.79±5%
Rear Flash Yes
Video 2K Video Recording
Power
Battery Capacity 3880mAh, 18W Fast Charge
Max Charging Current4.45V 4.5A
Multi-media
Video mp4\3Gp\3gpp\avi\x-flv…
Audio ogg\aac\imy\amr\x-flac\mp3….
Imagejpeg\png\gif\bmp
Features
NavigationGPS+GLONASS+Beidou+Galileo
Motor Flat motor 1020
SensorsG/P/L-sensor
GyroscopeYES
MagneticYES
Air pressure sensorYES
HallNO
CompassYES
FingerprintYES
RGBYES
NFCYES
HotkontNO
Coulomb CounterNO
Wireless ChargingNO
Sim-Card TypeTwo nano card
FMYES
OTGYES
Earphones Jack TypeTYPE-C
Accessories
User Manualx1
Power Adaptorx1
USB Cablex1
NOTE
