Blackview MP100 AMD Ryzen™ 5/7 7430U/5700U/5825U CPU DDR4 M.2 SSD Windows 11 Pro Mini PC
£360.00 £276.00
MINI PC MP100 Boost Your Day, Turbo Your Play Go to Rock and Rule the Game and Show! Rocket-fast Wi-Fi 6...
CPU: AMD Ryzen™ 7 5700U 4.3GHz
AMD Ryzen™ 5 7430U 4.3GHz
AMD Ryzen™ 7 5825U 4.5GHz
Capacity: 16GB+512GB
16GB+512GB
32GB+1TB
16GB+1TB
Color: Gray
Gray
Blue
Description
MINI PC MP100
Rocket-fast Wi-Fi 6
Wi-Fi 6
AMD Ryzen™ 7 5700U/5825U
8 Cores 16 Threads TSMC 7nm FinFET Process
4.3GHz/4.5GHz Max Turbo Frequency
Flagship AMD Radeon™ Graphics
1900MHz/2000MHz Core Clock
Wireless BT5.2
4K UHD Display
Triple 4K Display Support
DP 4K@144Hz HDMI 4K@60Hz
Type C 4K@60Hz
Windows 11 Pro Pre-installed
Tailored for office tasks, gaming,
and home entertainment
Advanced 3-in-1 Cooling System
Ultra-large cooling fan,
Copper Heat Pipe,
Cooling copper fins
512GB/1TB M.2 SSD + Max 2TB
2.5" Scalable SSD/HDD Support
Ample Storage for Apps
Games, Movies, Music & More
Versatile 12 Powerful Ports
Meet Various Connectivity Needs
Whisper-quiet Design
16GB/32GB DDR4 & Max
64GB Expansion Support
VESA Back Mounting Support
Minimize Space Usage
0.726L Pocket-Size
492g Easy to Carry
Cool RGB Ambient Light
Why Choose Blackview MP100?
Next-level 4K 144Hz Gaming
& Leisure & Office Prowess
NO.1
Ultra-quiet 3-in-1 Constant
Temperature Cooling System
NO.2
Seamless Operation & Triple
Display with 12 Well-organized Interfaces
NO.3
Power Up with Mini &
Cool Magic
NO.4
NO.1
Next-level 4K 144Hz Gaming & Leisure & Office Prowess
Ace Your Daily Grind in Play, Downtime, and Work
Power Up Your Day, Boost Your Gameplay
Gaming-grade AMD Ryzen™ 7 5700U/5825U
With its gaming-grade AMD Ryzen™ 7 5700U/5825U , Blackview MP100 achieves a max turbo frequency of 4.3GHz/4.5GHz , making it ideal for a wide range of everyday uses, work situations, and gaming, ensuring top-notch performance and immersive experiences.
TSMC 7nm
FinFET Process
4.3GHz/4.5GHz
Max Turbo Frequency
4M + 8M/16M
L2+L3 Cache
3.8X ↑ Smoother
CPU Benchmark
8 Cores
16 Threads
Comparison of Single-Core
vs. Multi-Core Performance
Rev Your Tasks to the Next Level
16GB/32GB DDR4 & Max 64GB Expansion Support
Outfitted with dual DDR4 channels, MP100 comes with 16GB/32GB high-performance DDR4 memory, with the potential to upgrade to 64GB . Its exceptional multitasking ability makes it a flexible solution for anything from gaming office tasks to and video editing.
16GB/32GB DDR4
Dual Channel SODIMM
3200MHz
Transmission speed
64GB
Max 64GB
Expansion Support
Dump Delays and Defy Data Caps!
512GB/1TB M.2 SSD + Max 2TB 2.5" Scalable SSD/HDD Support
Maximizes your digital capacity with MP100's speedy 512GB/1TB M.2 SSD, and allows you to scale up to a 2TB with a 2.5" SSD/HDD, providing robust storage while ensuring quick and efficient data retrieval.
Seamless Performance, Lightning Quick
High Speed M.2 SSD
Standard HDD
Effortless Upgrades, Endless Possibilities
Unlock more power with MP100. Open the bottom to upgrade, boosting your system's ability to handle games, multitask, and process big files with ease.
Up Your Game at Work and in Play
with Sharper, Smoother Visuals
Smoother, Clearer,
Faster, Than Ever
Powered by AMD Radeon™ Graphics, MP100 boosts gaming speed while delivering uncompromising image quality, and enhances resolution for an immersive visual extravaganza.
58% Higher Graphics
Performance
Epic Visual Feast Unleashed
4K 144Hz UHD Display
Buckle up for a visual spectacle with MP100’s 4K UHD and epic 144Hz refresh rate! Expect nothing less than vivid details and seamless graphics that will rev up your gaming and leisure time.
Level up Your Immersion in the Game
Enjoy even Smoother Visuals
Make Your Workflow Smoother than Ever
* Test result are for reference only. Actual performance may vary due to changes in the objective environment.
NO.2
Ultra-quiet 3-in-1 Constant Temperature Cooling System
Maximizing Performance with a Top-Notch Cooling System and Whisper-quiet Design
Mini Monster, Mega Chill
Superb Heat Dissipation System
Ready to max out your gaming and productivity? MP100 comes equipped with a cooling fan providing a maximum airflow of up to 3.86 CFM , supplemented by copper heat pipes and heat sinks, to ensure maximum heat dissipation efficiency and unparalleled performance.
3.86 CFM
Maximum airflow
340 cm²
High-performance heat sink
≤104°F
Constant Cooling Temperature
Stay Silent, Stay Driven
Easily distracted by sound? Blackview MP100 features a super-quiet fan operating at 2300 RPM , keeping noise levels below 20 dB during everyday office use. Stay laser-focused on your priorities without any noise interruptions.
2300 RPM
Super-silent fan speed
≤20dB
Regular usage
34-39dB
Peak performance
NO.3
Seamless Operation & Triple Display
Tap into Top-notch Smoothness and Convenience
Connect More, Do Anything, Effortlessly
12 Clever Well-organized Interfaces
Decked out with 12 clever well-organized interfaces , MP100 turns your desk into command central—connect everything from headphones to keyboards in a snap. It's a perfect match for up to 99% of the peripherals out there, giving you a powerhouse of functionality and ease.
Tripled Vision, Tripled Productivity
Max out your multitasking with Blackview MP100. Its HDMI, DP, and USB-C ports enable a seamless 4K triple-monitor support for peak productivity and top-notch entertainment.
Games
Design
Content Creation and
Multimedia Edits
Streamed Media and Films
Online courses
Office Tasks
Speed Up, Lag Down
Rocket-fast Wi-Fi 6 & Wireless BT5.2
Blaze through games without a hitch with MP100's rocket-fast Wi-Fi 6 , ensuring no lag as you and your team rack up wins. Plus, Wireless BT5.2 cranks up the stability and speed of your wireless connections.
Power Through Work and Play
Enjoy professional-grade app, privacy, stylish design, and realistic visuals with Windows 11 Pro pre-installed on MP100, which is tailored for office tasks, gaming, and home entertainment.
NO.4
Power Up with Mini & Cool Magic
Pocket-sized to Streamline Daily Routine and Boost Productivity
Mini Size, Mega Power
Space-saving Design
Small but mighty, Blackview MP100 is a true powerhouse packed into a tiny package. Its space-saving design allows it to effortlessly fit into any space , providing the performance of a full-size PC in a compact form factor perfect for use on the move.
0.726L
Pocket-Size
492g
Easy to Carry
Illuminate Your Victory Horn!
Cool RGB ambient light kick up the intensity of fierce gaming battles, bringing the thrill right to your fingertips for a super immersive feel.
Cool RGB
Ambient Light
Office Use
Home Entertainment
On-the-Go Business Trips
Freedom to Mount, Space to Spare
Mount MP100 behind your monitor using a VESA bracket to minimize space usage while maximizing aesthetics—a clean, clutter-free zone.
Blackview MP100
Brand Blackview
Model MP100
Color Grey, Blue
Dimension 127*127*45mm
Weight 492g
CPU AMD Ryzen™ 7 5700U/5825U, 8 Cores, 16 Threads
GPU AMD Radeon™ Graphics
Display 4K UHD, Max 144Hz Refresh Rate
Cache L2 + L3, 4M + 8M/16M
Burst Frequency 4.3GHz/4.5GHz
Base Frequency 1.8GHz/2GHz
CPU Power Consumption 25W(5700U)/15W(5825U)
RAM 16GB/32GB DDR4, 3200MHz
Dual Channel, Max 64GB Expansion Support
SSD 512GB/1TB M.2
Dual Channel, Max 2TB 2.5" Scalable SSD/HDD Support
OS Windows 11 Pro
Wi-Fi Wi-Fi 6
Wireless BT 5.2
LAN Support 10/100/1000Mbps
I/O Display Port (Max 4K 144Hz)
HDMI 2.0 (Max 4K 60Hz)
Type-C*2 (10Gbps/Max 4K 60Hz)
USB 3.2 Gen2*2 (10Gbps)
USB 2.0 (480Mbps)
1x RJ45 LAN (1000Mbps)
3.5mm Audio-in/out Jack
Clear CMOS Button
Power Button
5.5/2.1mm DC Jack
