Blackview BV6200 6.56-Inch 4+64GB 13000mAh Loud Speaker 4G Ruggedized Cellphone
$219.99 $139.99
✔Smart-K Box Speaker, Louder For Outdoor
✔13000mAh Mega Battery & 18W Fast Charging
✔Powered by ArcSoft® Imaging Technology
✔MIL-STD-810H & IP68 & IP69K
Capacity: 4GB+64GB
4GB+64GB
Color: Orange
Green
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscovercartes bancairesklarnaafterpaygoogle payapple pay
Frequently Bought Together
Total price:$329.97 $209.97
Description
Note:
Stay Charged.
Embrace the Nature's Challenge.
13000mAh Mega Battery Long Endurance, Large Capacity. Having a 13000mAh battery is putting security into your hands. Even if you forget to bring charging cables before you go out, BV6200 will help you avoid battery anxiety. 62 days of standby time will protect you against getting lost in the mountains or being unable to take an Uber home on a rainy night when your phone runs out of power.
  • Game
    17 hrs
  • Video
    20 hrs
  • Web
    23 hrs
  • Calling
    50 hrs
  • Music
    40 hrs
  • Standby
    1488 hrs
18W Fast Charging Resolved in 4 Hours With 13,000mAh Mega battery and 18w fast charging, BV6200 can be fully charged in just four hours. Gently Charge your phone, take a cozy snooze, and the BV6200 will be back to full charge. Instead of wasting too much time on charging, spend more time on entertainment and leisure.
Reverse Charging When you encounter a situation where some devices run out of power, you can connect them to BV6200 for charging by using a special OTG cable that supports reverse charging. The phone is transformed into a mobile power source, helping you to travel light. Reverse Charging Compatible Devices
8MP + 13MP Cameras Record Richer Details Whether in high or low light, the 8MP front camera delivers a leading image and performance, capturing all the tiny details you miss in daily life. All delighted moments, spectacular views can be clearly recorded with the 13MP ultra-wide angle lens rear camera, leaving fresh memories.
8MP front camera +
13MP Rear Camera
18W Fast Charging & Reverse Charging
IP68 & IP69K & MIL-STD-810H
Panorama Mode
Beauty Mode
HDR Mode
Portrait Mode
MediaTek Helio A22
4GB RAM+ Up to 4GB Expansion
64GB ROM + Up to 1TB TF Support
6.56-inch Display &
83% Screen-to-body Ratio
Doke OS 3.1
Based on Android 13
Dual 4G LTE
Face Unlock
GPS+GLONASS+
Beidou+Galileo
Portrait Mode Always overwhelmed by cluttered backgrounds when taking photos? Portrait mode helps you solve this annoying problem. Keep only the clear face and blur the background to get a photo that highlights the main point.
Panorama Mode The panoramic mode of the BV6200 surpasses the shooting angle of regular lenses, allowing for capturing a wider field of view and obtaining more complete and comprehensive photos.
HDR Mode Turning on HDR mode can help you take spectacular landscape photos by keeping the balance of light and dark in your photos, making them more colorful.
Beauty Mode The beauty mode carried by BV6200 can appropriately blur blemishes and restore the real skin texture while achieving skin beautification.
Night Mode When you are in low-light conditions, you can use BV6200's night mode to enhance the brightness. It can clearly show the textures on your clothes, the details of your makeup and make the photos more textured.
As Sturdy as Iron As a rugged phone, BV6200 reflects professionalism on its robust structure for withstanding harsh weather conditions and special occasions. MIL-SPEC Upgrading from 810G to 810H In order to further enhance the adaptability to harsh environments and to further improve the ability for difficult outdoor adventures, the BV6200 has undergone a change from MIL-SPEC 810G to MIL-SPEC 810H. The standards achieved include but are not limited to:
Rain Sand and Dust Vibration Shock Acceleration
High Temperature Low Temperature Humidity Altitude Immersion
Drop proof up to 1.5 meters*.
IP68 & IP69K Rated Waterproofness With the high protection standards of IP68 & IP69K , BV6200 provides complete protection against ingress of dust and will not be damaged even if it is immersed in water under certain pressure, demonstrating its durability and ruggedness.
Waterproof up to 1.5m deep for 30mins*.
MediaTek Helio A22 New Power, New Journey The Mediatek Helio A22 chip installed on the BV6200 uses advanced 12nm process technology and four ARM Cortex-A53 low-power processor cores to deliver good performance at low power consumption, which means that it can provide longer battery life for the phone, pushing the boundaries of longer battery life.
4GB RAM+ Up to 4GB Expansion Jumping out of Clumsiness Insufficient memory storage will only make your phone sluggish when trying to switch to chat software while playing games like Genshin Impact, whereas having 4GB RAM coupled with 4GB virtual RAM will allow you to switch back and forth smoothly between multiple software.
64GB ROM + Up to 1TB Expansion Freedom from Crowding On top of the 64GB ROM memory, BV6200 can also be loaded with up to 1TB TF card to store action-packed games, diverse applications, colorful photos, and brilliant clips. Everything you desire can be stored in this crazy huge storage card. 6.56-inch Display 83% Screen-to-body Ratio Indulge in the Visual Feast With a large 6.56-inch screen and solid, calm look, the intrepid BV6200 has an 83% screen-to-body ratio for excellent picture presentation. Compared to phones of the same size, it offers a larger screen and more comfortable visual effects for your eyes.
  • Size
    6.56
  • Screen Aspect Ratio
    20:09
  • Refresh Rate
    60Hz
  • Touch Sampling Rate
    120Hz
  • PPI
    269
  • Screen-to-body Ratio
    83%
  • Panel Type
    HD+ IPS
Smart-K Box Speaker Like Being in A Concert The BV6200 uses Smart-K box speaker to increase the volume of the speaker. Music coming to our ears has crisp and bright high tones, rich and powerful low tones, allowing you to experience a different kind of soul uplift, just like being in a concert.
Doke OS 3.1 Based on Android 13 Convenient, Efficient, Rapid
Versatile Desktop Doke OS 3.1 has made great progress in saving time and increasing efficiency. It allows you to group apps together, customize icons, or dismiss folders, which means you can create your own style of phone desktop.
Smart Floating Windows Swipe Left or Right And Then Hold The Smart Sidebar. Develop sidebar to create a quick access program.
The Upgraded Notebook You can insert appropriate text, pictures, and audio to remind you of important things, and lock your memos to ensure its security.
Cold Room
You can easily drag certain applications into the cold room installed on the BV6200 without unloading them to get faster phone operation.
Dual 4G LTE BV6200 supports dual 4G LTE, enabling 4G connectivity on two SIM cards, allowing you to switch between two 4G networks at will. Dual card slots:
Three Slots: 2* SIMs + 1* TF Card
GPS+GLONASS+Galileo
+Beidou
The navigation system assembled on the BV6200 covers GPS, GLONASS, Galileo and Beidou satellite navigation systems for more accurate and efficient positioning, so you never have to worry about getting lost.
Face Unlock Secure, convenient, and efficient face unlocking does not require physical contact like fingerprint recognition, but a natural look to unlock.
Black Orange Green
  • Model
    BV6200
  • Color
    Black,Orange,Green
  • Dimension
    174.4*82*19.2mm
  • Weight
    438g
  • OS
  • Display
    6.56 inches, 720*1612, HD +IPS
  • CPU
    Mediatek Helio A22
  • RAM & ROM
    4GB & 64GB
  • Max TF Card Capacity
    1TB
  • Front Camera
    8MP
  • Rear Camera
    13MP+0.3MP
  • Card Slot
  • Battery Capacity
    13000mAh
  • Connectivity
    Wi-Fi version & spec:IEEE802.11 a/b/g/n/ac
    Bluetooth version & spec:V5.0
    GSM spec:B2/B3/B5/B8
    3G spec:W1/W8
    LTE spec:FDD:B1/B3/B7/B8/B20 TDD:B40
  • Navigation
    GPS/GLONASS/Beidou/Galileo
