Blackview BV4800 6.56-Inch Helio A22 2+32GB/3+64GB 5180mAh 4G Ruggedized Cellphone
£145.00 £100.00
BV4800 Empower Your Rugged Lifestyle 5MP + 13MP Leading IP68&IP69K Certified Water- & Dust- Resistant 6.56” HD+ Display Protected By CORNING®...
Capacity: 2GB+32GB
2GB+32GB
3GB+64GB
Color: Green
Green
HURRY! ONLY LEFT IN STOCK.
Tags: 4G
Frequently Bought Together
Total price:£330.00 £223.00
Description
BV4800
5MP + 13MP
Leading
IP68&IP69K
Certified
6.56” HD+ Display
Protected By CORNING® GORILLA® GLASS 5
64GB ROM
Up to 1TB
Expandable Storage
Reverse
Charging Support
GPS + Beidou +
Glonass + Galileo
Doke OS 3.1
(based on Android 13 Go)
MediaTek Helio A22
3GB RAM + up to
3GB Expansion
5180mAh
Battery
Three Card Slots
(2* SIMs + 1* TF Card)
Face
Unlock
Glove
Mode
MediaTek Helio A22
New Power, New Journey
The Mediatek Helio A22 chip installed on the BV4800 uses advanced 12nm process technology and four ARM Cortex-A53 low-power processor cores to deliver good performance at low power consumption, which means that it can provide longer battery life for the phone, pushing the boundaries of longer battery life.
3GB RAM+ Up to 3GB Expansion
Jumping out of Clumsiness
Insufficient memory storage will only make your phone sluggish when trying to switch to chat software while playing games like Genshin Impact, whereas having 3GB RAM coupled with 3GB virtual RAM will allow you to switch back and forth smoothly between multiple software.
64GB ROM + Up to 1TB Expansion
Freedom from Crowding
On top of the 64GB ROM memory, BV4800 can also be loaded with up to 1TB TF card to store action-packed games, diverse applications, colorful photos, and brilliant clips. Everything you desire can be stored in this crazy huge storage card.
6.56-inch Display 83% Screen-to-body Ratio
Indulge in the Visual Feast
With a large 6.56-inch screen and solid, calm look, the intrepid BV4800 has an 83% screen-to-body ratio for excellent picture presentation. Compared to phones of the same size, it offers a larger screen and more comfortable visual effects for your eyes.
Size
6.56
Screen Aspect Ratio
20:09
Refresh Rate
60Hz
Touch Sampling Rate
120Hz
PPI
269
83%
Panel Type
HD+ IPS
5180mAh Large Battery
Enduring at Its Core
The 5180mAh battery in BV4800 extends your joy throughout the day or beyond. The high-capacity battery responds to your productivity needs reliably be it for work or study without frequently asking for a next charge.
5MP + 13MP Cameras
Record Richer Details
Whether in high or low light, the 5MP front camera delivers a leading image and performance, capturing all the tiny details you miss in daily life. All delighted moments, spectacular views can be clearly recorded with the 13MP rear camera, leaving fresh memories.
Portrait Mode
Always overwhelmed by cluttered backgrounds when taking photos? Portrait mode helps you solve this annoying problem. Keep only the clear face and blur the background to get a photo that highlights the main point.
Panorama Mode
The panoramic mode of the BV4800 surpasses the shooting angle of regular lenses, allowing for capturing a wider field of view and obtaining more complete and comprehensive photos.
HDR Mode
Turning on HDR mode can help you take spectacular landscape photos by keeping the balance of light and dark in your photos, making them more colorful.
Beauty Mode
The beauty mode carried by BV4800 can appropriately blur blemishes and restore the real skin texture while achieving skin beautification.
Night Mode
When you are in low-light conditions, you can use BV4800's night mode to enhance the brightness. It can clearly show the textures on your clothes, the details of your makeup and make the photos more textured.
As Sturdy as Iron
As a rugged phone, BV4800 reflects professionalism on its robust structure for withstanding harsh weather conditions and special occasions.
MIL-SPEC Upgrading from 810G to 810H
In order to further enhance the adaptability to harsh environments and to further improve the ability for difficult outdoor adventures, the BV4800 has undergone a change from MIL-SPEC 810G to MIL-SPEC 810H.
The standards achieved include but are not limited to:
Drop proof up to 1 meter*.
IP68 & IP69K Rated Waterproofness
With the high protection standards of IP68 & IP69K , BV4800 provides complete protection against ingress of dust and will not be damaged even if it is immersed in water under certain pressure, demonstrating its durability and ruggedness.
Waterproof up to 1 meter deep for 30mins*.
Doke OS 3.1 Based on Android 13 GO
Convenient, Efficient, Rapid
Versatile Desktop
Doke OS 3.1 has made great progress in saving time and increasing efficiency. It allows you to group apps together, customize icons, or dismiss folders, which means you can create your own style of phone desktop.
Dual 4G LTE
BV4800 supports dual 4G LTE, enabling 4G connectivity on two SIM cards, allowing you to switch between two 4G networks at will.
Three Card Slots: 2* SIMs + 1* TF Card
GPS+GLONASS+Galileo +Beidou
The navigation system assembled on the BV4800 covers GPS, GLONASS, Galileo and Beidou satellite navigation systems for more accurate and efficient positioning, so you never have to worry about getting lost.
Face Unlock
Secure, convenient, and efficient face unlocking does not require physical contact like fingerprint recognition, but a natural look to unlock.
Green
Model
BV4800
Colors
Black, Orange, Green
Dimension
174.7*81.5*13.5mm
Weight
285g
OS
DokeOS 3.1 Based on Android 13 GO
Display
6.56-inch, 60Hz Refresh Rate, 720*1612 Resolution, CORNING® GORILLA® GLASS 5
CPU
Mediatek Helio A22, Quad-core, 4*A53 @2.0GHz
RAM & ROM
2GB RAM+32GB ROM, 3GB RAM+64GB ROM, LPDDR4X+EMMC5.1
RAM Expansion
Up to 2GB/3GB Expandable
Expandable Storage
Up to 1TB
Battery
5180mAh, 10W Charge
Cameras
5MP Front + 13MP Rear
Speaker
Smart-K BOX Speaker, 1PCS
Rugged Rating
IP68 & IP69K & MIL-STD-810H
Navigation
GPS, GLONASS, BEIDOU, Galileo
Network Connectivity
Wi-Fi: IEEE802.11 a/b/g/n/ac 2G Band: GSM: 850/900/1800/1900 (B2/B3/B5/B8) 3G Band: B1/B8 4G Band: FDD:B1/B3/B7/B8/B20 TDD:B40
Card Slot
Three; 2* SIMs + 1* TF Card
Glove Mode
Support
Height: 174.7mm
Width:81.5mm
Thickness: 13.5mm
Weight: 285g
