Blackview OSCAL S60 5.7 inch 3+16GB Drop-proof Ruggedized 4G Cellphone
$139.99 $129.99
Note: This phone can only work in Europe and Asia area, please pay attention before purchasing or consult us. S60 Budget...
Capacity: 3GB+16GB
3GB+16GB
Color: Orange
Green
Add to Wishlist
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscover
Frequently Bought Together
Total price:$239.97 $199.97
Description
Note:
S60
Budget Rugged Phone King
  • IP68&IP69K&MIL-STD-810G
  • 5.7-inch
  • 3GB+16GB MediaTek A22
  • Underwater Mode
  • 5MP+8MP Camera
  • 4980mAh
  • Android 11 Doke OS 2.1
  • GPS+GLONASS+Beidou+Galileo
Rugged & Tough
Invincible from inside out
Constructed from durable TPU and reinforced polycarbonate with 10% Glass Fibers material and treated with various durability tests, S60, with a robust structure, can well protect itself from daily rough uses. Have peace of mind whether on construction sites or outdoors.
*Solid unibody to reduce risks of falling apart
  • *High-strength Panda glass for scratch and crack resistance
  • *Thickened jagged corners to buffer shocks and crashes
  • *Double-shot molding process for slip and drop resistance
IP68 & IP69K & MIL-STD-810G
Survive from Any Challenges
The solid build that cannot be compared by most delicate and fragile mainstream smartphones makes it exceptionally resistant to damage caused by falls, water immersion, shock and impact.
Waterproof
Waterproof up to 1.5m deep for 30mins
Oil & coffee splash resistant
Dustproof
Fully dustproof
Drop-proof
*Drop-proof up to 1.5m height
4980mAh Battery
Power Lasts Longer
Charge less and extend longer. The large 4980mAh battery with built-in smart battery management effectively avoids running out of juice in the middle of enjoyment even for heavy uses.
7hrs
Game
8hrs
HD video
11.5hrs
Web
24hrs
Calling
28hrs
Music
288hrs
*The battery data is tested by OSCAL Laboratory.
Everyday Companion You can Rely on
5.7" HD+ Display
Rugged to Resist, Clear to View
Make every frame clear and vivid on the large 5.7" HD+ display. On the exterior, it's covered with high-strength Panda glass to avoid daily screen scratches or breaks. Always get the pleasing and spellbinding visuals.
5.7" HD+ Display
5.7" Screen
720*1440 Resolution
77.6% Screen-to-body Ratio
Quad-core MediaTek Helio A22
Smooth & Responsive to Multitask
Powered by a quad-core CPU coupled with 3GB RAM and 16GB internal storage,
it's easy to execute your demands with enough efficiency and fluidity.
3GB
RAM
16GB
ROM
Up to 128GB
Expandable Storage
Underwater Mode
Capture the Beauty on Land or in Water
With the Underwater mode available, make awesome snaps for the splendid scenes or other wonderful life moments anywhere.
5MP Front Camera
8MP Rear Camera
Always Find Your Way
Coordinating 4 navigation satellite systems together, S60 is capable of providing more reliable and accurate positioning to help never lose the way especially in outdoor explorations.
  • GPS
  • Galileo
  • Glonass
  • Beidou
  • GPS
  • Galileo
  • Glonass
  • Beidou
Doke OS 2.1
Based on Android 11, Intuitive & Smooth
S60 combines the developed Doke OS 2.1 and Android 11 OS to boost interaction smoothness and efficiency.
  • Dual Artistic Themes
    Both are designed with exquisite wallpapers and app icons for aesthetics and intuitiveness.
  • System Manager
    Get better and smarter all-in-one control such as over the battery and app management.
  • Cold Room
    One click to put rogue apps in the Freezer and stop their stealthy background running.
  • Clone Phone
    Safely transfer all the data from old to new device even without Wi-Fi or mobile data.
  • Screenshot/Long Screenshot
    For important messages, make a screenshot or long screenshot and edit it easily.
  • Split View
    Support a multi-window view and help multitask effectively and productively.
Oasis Green
Flame Orange
Eclipse Black
Specification
Design
ProductS60
OSAndroid 11.0
ColorBlack, Orange, Green
Weight255g
Dimensions161.7*78.5*14mm
Screen
LCD panelBOE
ICICNL9911C
Panel TypeIPS
Display ResolutionHD+
Screen Size5.7 Inch
Screen Resolution720*1440
Viewing angle (H/V)Full angle
PPI/DPI182
GlassPanda
Connectivity
WIFI 802.11/b/g/n
Bluetooth V4.2
2G2/3/5/8
3G WCDMA: B1/B2/B4/B5/B8
4G TDD: B40
FDD: B1/B3/B7/B8/B20
Hardware
CPUMT6761V/WE
CPU Clock 2.0GHz
GPUIMG GE8300
RAM3GB
RAM TypeLPDDR3
ROM16GB
ROM TypeEMMC
TF Card SlotSupport
Max TF Card Capacity128GB
USBMicro 5pin
Camera
Front Camera 5.0MP
Front Camera SensorGC5035
Front Camera Aperturef2.2
Rear Camera 8.0MP
Rear Camera Sensor IMX355
Rear Camera Aperture f2.0
Rear FlashYes
Video 1080P 30fps H.264
Power
Battery Capacity4980mAh
Max Charging Current5v 1A
Multi-media
Videomp4\3Gp\mov\mkv…
Audioflac\ape\ac….
Imagejpeg\png\gif\bmp
Features
NavigationGPS+GLONASS+Beidou+Galileo
MotorFlat motor 1020
SensorsYES
GyroscopeYES
MagneticYES
Air pressure sensorNO
HallNO
CompassYES
FingerprintNO
RGBYES
NFCNO
HotkontNO
Coulomb CounterNO
Wireless ChargingNO
Sim-Card TypeTwo nano card
FMYES
OTGYES
Earphones Jack Type3.5mm jack type
Accessories
User Manualx1
Protective Film Separatelyx1
Power Adaptorx1
USB Cablex1
NOTE
