Blackview MP60 Mini PC Intel N-series CPU Windows 11 Pro VESA Mount Support Mini PC
$399.99 $219.99
✔Intel® Processor N-series
✔Up to 16GB DDR4 RAM + 1TB SSD
✔UHD 4K Dual Screens Display Support
✔Newest Windows 11 Pro OS
CPU: 11th Gen Jasper Lake N5095
12th Gen Alder Lake N95
Capacity: 16GB+512GB
8GB+256GB
16GB+512GB
16GB+1TB
Color: Black
Blue
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Frequently Bought Together
Total price:$749.96 $495.96
Description
Compact Yet Powerful
MINI PC MP60
0.852L Exquisite Design
More Spacious, More Efficient
Blackview MP60 has only 0.852L ultra-small volume, 390g lightweight, and gets things done just like a PC, in a much more small package.
0.852L
Ultra-small volume
390g
Lightweight
  • Small Body, Functional Operation
    Work Like On A PC
  • Thanks to the excellent integrated design, Blackview MP60 has highly integrated with the traditional desktop motherboard, CPU, memory, hard disk, heat sink, and other hardware in a palm-sized main chassis, which comes with more convenience in the office and entertainment.
11th Gen Intel Celeron N5095.
Farewell to Computer Crash
Blackview MP60 is equipped with NEW 11th generation Intel® Celeron® processor N5095, with a burst frequency of up to 2.9GHz, which can help you deal with fast web browsing, document editing, and speech presentation browsing to meet daily office and entertainment needs.
16GB RAM + 512GB ROM + up to 2TB Expansion
Multitasking Made Easier
Up to 16GB of DDR4 operation memory and 512GB solid-state drives, giving ample room for a bulk of valuable multimedia files to have everything right at your operation and blow through your pleasure anytime.
SSD: MAX 2TB
M.2/SATA
Read Speed
500MB/S
DDR4:
MAX 16GB
M.2/SATA
(MAX 2TB)
MAX 16GB
2TB Expandable Storage
2TB of Expandable storage, helping you treasure your favorite movies, cherished snapshots, meaningful videos, or valuable audio without breaking a sweat.
Why to Choose Blackview MP60?
Superb Heat Dissipation
More Smooth. More Fluidity
Blackview MP60 dedicates the CPU to thermal solutions with a newly designed large-windowed cooler fan to ensure maximum performance. With a fan speed of 5600 rpm and heat dissipation area of 25500mm², the fan will always keep MP60 host at 95°F. An efficient cooling fan will make the system more stable and the CPU life longer.
Noise Reduction Design
Always Quiet. Sleep Undisturbed
Does the noise interrupt your thought? Blackview MP60 has a built-in noise-canceling radiator that will reduce noise to less than 38 dB, which is quieter than the noise value of 40dB in the library, providing a comfortable environment that allows you to be more productive.
4K Ultra HD Display
Exceptional Visual Feast
Blackview MP60 supports 4K Ultra HD graphics, with four times the pixel count of 1080p, capturing more details on the screen to look lifelike, giving you an ultimate visual experience.
4K 60Hz
Intel UHD Graphics
Dual HDMI Ports
Doubled Productivity
Equipped with dual HDMI ports, Blackview MP60 allows for simultaneous dual-screen operation via HDMI Port, doubling the efficiency of office and entertainment.
Various Interfaces
More Connectivity. More Possibilities
Equipped with various interfaces, Blackview MP60 has compatible with more than 90% of mainstream peripherals. Headphones, mice, keyboards, and other devices can be connected at the same time. More importantly, MP60 works well with surveillance cameras, projectors, printers, monitors, and TVs.
Reliable Wireless Support
Keep You Well Connected
Thanks to 2.4G and 5G dual-band WiFi, Blackview MP60 enables fast wireless transmission with mobile devices. With Bluetooth 4.2 capabilities, MP60 is widely compatible with Bluetooth-enabled equipment. Ultra-fast network connectivity with up to 1000Mbps high-speed transmission speed, freeing you from the confines of a network cable for a better experience.
New Windows 11 Pro
Efficient Work, Private Protection
Blackview MP60, Driven by the newest operation system Windows 11 Pro, features that help you secure your devices, data, and applications and work more efficiently.
  • Privacy
    Data Stolen Prevention
  • Security
    Network Fraud Protection
  • Compatibility
    Compatible with 99.6% of APPs
Pocket Size
Carried Away As You Wish
Small and only 390g, designed for flexibility, Blackview MP60 fits on a desktop, on a desk, and even behind your monitor. You can easily take the MP60 home in your bag and avoid the hassle of lugging around a large heavy computer mainframe to continue unfinished work.
  • Brand
    Blackview
  • Model
    MP60
  • Color
  • Dimension
    128*128*52mm
  • Weight
    390g
  • OS
    Windows 11 Pro
  • Display
    4K ‎Intel UHD Graphics
  • Processor
    Intel® Celeron® Processor N5095 / Intel® Processor N95
  • Processor Speed
    2.9 GHz / 3.4 GHz
  • Processor Count
    4
  • RAM & ROM
    8GB RAM + 256GB ROM /16GB RAM + 512GB ROM /16GB RAM + 1TB ROM
  • Expandable Storage
    Up to 2TB
  • Chipset Brand
    Intel
  • Wireless Type
    Dual band 2.4G + 5G WiFi (802.11 a/b/g/n/ac)
    Bluetooth 4.2 integrated
  • Number of USB 2.0 Ports
    2
  • Number of USB 3.0 Ports
    2
  • Hardware Platform
    PC
  • Computer Memory Type
    DDR4 SDRAM
  • VESA Wall Mount
    Support
