Blackview BV6200 6.56-Inch 4+64GB 13000mAh Loud Speaker Ruggedized 4G Cellphone
✔Smart-K Box Speaker, Louder For Outdoor
✔13000mAh Mega Battery & 18W Fast Charging
✔Powered by ArcSoft® Imaging Technology
✔MIL-STD-810H & IP68 & IP69K
Frequently Bought Together
Description
Panorama Mode
The panoramic mode of the BV6200 surpasses the shooting angle of regular lenses,
allowing
for capturing a wider field of view and obtaining more complete and comprehensive photos.
64GB ROM + Up to 1TB Expansion
Freedom from Crowding
On top of the 64GB ROM memory, BV6200 can also be loaded with up to 1TB TF card to
store
action-packed games, diverse applications, colorful photos, and brilliant clips. Everything you desire can
be
stored in this crazy huge storage card.
6.56-inch Display 83% Screen-to-body Ratio
Indulge in the Visual Feast
With a large 6.56-inch screen and solid, calm look, the intrepid BV6200 has an 83%
screen-to-body ratio for excellent picture presentation. Compared to phones of the same size, it offers a
larger screen and more comfortable visual effects for your eyes.
Note:
Stay Charged.
Embrace the Nature's Challenge.
Long Endurance, Large Capacity.
Having a 13000mAh battery is putting security into your hands. Even if you forget to
bring
charging cables before you go out, BV6200 will help you avoid battery anxiety. 62 days of standby time will
protect you against getting lost in the mountains or being unable to take an Uber home on a rainy night when
your phone runs out of power.
18W Fast Charging
Resolved in 4 Hours
With 13,000mAh Mega battery and 18w fast charging, BV6200 can be fully charged in just
four hours. Gently Charge your phone, take a cozy snooze, and the BV6200 will be back to full charge.
Instead
of wasting too much time on charging, spend more time on entertainment and leisure.
8MP + 13MP Cameras
Record Richer Details
Whether in high or low light, the 8MP front camera delivers a leading image and
performance, capturing all the tiny details you miss in daily life. All delighted moments, spectacular views
can be clearly recorded with the 13MP ultra-wide angle lens rear camera, leaving fresh memories.
Game
17 hrs
Video
20 hrs
Web
23 hrs
Calling
50 hrs
Music
40 hrs
1488 hrs
Reverse Charging
When you encounter a situation where some devices run out of power, you can connect
them to BV6200 for charging by using a special OTG cable that supports reverse charging. The phone is
transformed into a mobile power source, helping you to travel light.
Reverse Charging Compatible Devices
8MP front camera +
13MP Rear Camera
13MP Rear Camera
18W Fast Charging & Reverse Charging
IP68 & IP69K & MIL-STD-810H
Panorama Mode
Beauty Mode
HDR Mode
Portrait Mode
Beauty Mode
HDR Mode
Portrait Mode
MediaTek Helio A22
4GB RAM+ Up to 4GB Expansion
64GB ROM + Up to 1TB TF Support
6.56-inch Display &
Doke OS 3.1
Based on Android 13
Based on Android 13
Dual 4G LTE
Face Unlock
GPS+GLONASS+
Beidou+Galileo
Beidou+Galileo
BV6200's camera is powered by ArcSoft, an advanced company that offers various
imaging
technologies to capture incredible photos and videos.
Portrait Mode
Always overwhelmed by cluttered backgrounds when taking photos? Portrait mode helps
you solve this annoying problem. Keep only the clear face and blur the background to get a photo that
highlights the main point.
HDR Mode
Turning on HDR mode can help you take spectacular landscape photos by keeping the
balance of light and dark in your photos, making them more colorful.
Beauty Mode
The beauty mode carried by BV6200 can appropriately blur blemishes and restore the
real skin texture while achieving skin beautification.
Night Mode
When you are in low-light conditions, you can use BV6200's night mode to enhance
the
brightness. It can clearly show the textures on your clothes, the details of your makeup and make the
photos more textured.
As Sturdy as Iron
As a rugged phone, BV6200 reflects professionalism on its robust structure for
withstanding harsh weather conditions and special occasions.
MIL-SPEC Upgrading from 810G to 810H
In order to further enhance the adaptability to harsh environments and to further
improve
the ability for difficult outdoor adventures, the BV6200 has undergone a change from MIL-SPEC 810G to
MIL-SPEC
810H.
The standards achieved include but are not limited to:
Rain
Sand and Dust
Vibration
Shock
Acceleration
High Temperature
Low Temperature
Humidity
Altitude
Immersion
Drop proof up to 1.5 meters*.
IP68 & IP69K Rated Waterproofness
With the high protection standards of IP68 & IP69K , BV6200 provides complete
protection against ingress of dust and will not be damaged even if it is immersed in water under certain
pressure, demonstrating its durability and ruggedness.
Waterproof up to 1.5m deep for 30mins*.
MediaTek Helio A22
New Power, New Journey
The Mediatek Helio A22 chip installed on the BV6200 uses advanced 12nm process
technology
and four ARM Cortex-A53 low-power processor cores to deliver good performance at low power consumption,
which
means that it can provide longer battery life for the phone, pushing the boundaries of longer battery life.
Jumping out of Clumsiness
Insufficient memory storage will only make your phone sluggish when trying to
switch
to chat software while playing games like Genshin Impact, whereas having 4GB RAM coupled with 4GB
virtual
RAM will allow you to switch back and forth smoothly between multiple software.
Size6.56
Screen Aspect Ratio20:09
Refresh Rate60Hz
Touch Sampling Rate120Hz
PPI269
Screen-to-body Ratio83%
Panel TypeHD+ IPS
Smart-K Box Speaker
Like Being in A Concert
The BV6200 uses Smart-K box speaker to increase the volume of the speaker. Music coming
to our ears has crisp and bright high tones, rich and powerful low tones, allowing you to experience a
different kind of soul uplift, just like being in a concert.
Doke OS 3.1 Based on Android 13
Convenient, Efficient, Rapid
Versatile Desktop
Doke OS 3.1 has made great progress in saving time and increasing efficiency. It
allows you to group apps together, customize icons, or dismiss folders, which means you can create your
own style of phone desktop.
Smart Floating Windows
Swipe Left or Right And Then Hold The Smart Sidebar. Develop sidebar to create a
quick access program.
The Upgraded Notebook
You can insert appropriate text, pictures, and audio to remind you of important
things, and lock your memos to ensure its security.
Cold Room
You can easily drag certain applications into the cold room installed on the BV6200 without unloading
them
to get faster phone operation.
Dual 4G LTE
BV6200 supports dual 4G LTE, enabling 4G connectivity on two SIM cards, allowing
you
to switch between two 4G networks at will.
Dual card slots:
Three Slots: 2* SIMs + 1* TF Card
GPS+GLONASS+Galileo
+Beidou The navigation system assembled on the BV6200 covers GPS, GLONASS, Galileo and Beidou satellite navigation systems for more accurate and efficient positioning, so you never have to worry about getting lost.
Face Unlock
Secure, convenient, and efficient face unlocking does not require physical contact
like fingerprint recognition, but a natural look to unlock.
Green
ModelBV6200
ColorBlack,Orange,Green
Dimension174.4*82*19.2mm
Weight438g
OSDoke OS 3.1 Based on Android 13
Display6.56 inches, 720*1612, HD +IPS
CPUMediatek Helio A22
RAM & ROM4GB & 64GB
Max TF Card Capacity1TB
Front Camera8MP
Rear Camera13MP+0.3MP
Card SlotThree Slots: 2* SIMs + 1* TF Card
Battery Capacity13000mAh
ConnectivityWi-Fi version & spec:IEEE802.11 a/b/g/n/ac
Bluetooth version & spec:V5.0
GSM spec:B2/B3/B5/B8
3G spec:W1/W8
LTE spec:FDD:B1/B3/B7/B8/B20 TDD:B40 -
NavigationGPS/GLONASS/Beidou/Galileo
