Blackview BV9700 Pro 4G Rugged Smartphone - Blackview Store
Blackview BV9700 Pro Octa-Core 2.1GHz 6GB+128GB Wireless Charging 4G Rugged Smartphone - Official Refurbished
$299.99 $159.99
✔5.84 inch 4G Rugged Smartphone
✔MT6771T 6GB+128GB
✔16MP+8MP Dual Rear Cameras
✔16MP Front Camera
Capacity: 6GB+128GB - Official Refurbished
Color: Gray
Gray
Description
World's first MTK P70
BV9700 Pro
2019 Indestructible Flagship
Ruggedized Phone
19 : 9
5.84" FHD+ IPS Full Screen
Helio P70
6GB Ram + 128GB Rom
4380mAh
Quick Charge
16MP + 8MP
16MP Front Camera、Samsung
Android 9 Pie
Powered by AI
Night Vision Camera
Ultra-Light Sensitive
Air Detection
Air Quality & Pressure
Heart Rate Detection
Heart Rate Monitor
Prepare for Impact
Tested in all conditions and from -30 to +60°C, shrugs off muddy drops and rocky trips. BV9700 Pro can withstand relentless pounding, pressure and force. On the job site, in the field or in search of adventure, this Military Standard 810G device is an extremely rugged and reliable mobile solution. Have confidence your phone will cope with heavy downpours or a muddy trail and will continue to work for you, making sure you're connected at all times.
1.5M Drop Proof
IP68 | 1.5M Waterproof
99% Dust Proof
MIL-STD-810G
VOC Air Quality Detection
Indoor air pollutants, or more specifically Volatile Organic Compounds (VOCs), include a large range of chemicals and substances.The VOC detection sensor, which is capable of detecting volatile organic compounds, including both human-made and naturally occurring chemical compounds that are harmful to your health. Avoid breathing too much harmful gases from newly renovated rooms or air-contaminated outdoors.
External Night Vision Camera
The BV9700 Pro’s external camera is equipped with a Sony STARVIS IMX291 ultra-light sensitive cmos sensor, special design for low light and night scenes. The individual pixel size is up to 2.9um, 2.6 times the phone's main camera sensor. Light plays a huge role in photography. With the increase of pixels size, more light enters individual pixels. And together with ultra angle big aperture 6P structure lens, your phone instantly turns into a night-vision unit, easily capturing the wonderful moments in the dark.
The Most Intelligent Processor Ever
AI Master P70, Rugged Phone Debut. Helio P70 use the 12nm FinFET production process combined with CorePilot 4.0 provides class-leading performance and power-efficiency. So that the system does not hang when you are immersed in a movie or game, and multitasking becomes faster and easier.
Android 9 Pie , Powered by AI
Android 9 harnesses the power of artificial intelligence to give you more from your phone. Now your phone is learning your preferences as you go. Your experience gets better and better over time, and it keeps things running smoother, longer.
Grey
Specification
Design
Product BV9700 Pro
OS Android 9
Color Grey
Weight 283g
Dimensions 165.9*81.3*16.5 mm
Screen
Panel Type IPS
Display Resolution FHD+ IPS
Screen Size 5.84 Inch
Screen Resolution 1080*2280 19:9
Screen to Body Ratio(%) 85%
Viewing angle (H/V) Full Angle
PPI/DPI 432
Connectivity
WIFI 802.11 a/b/g/n/ac
Bluetooth BT4.1
GSM B2(1900), B3(1800), B5(850), B8(900)
3G WCDMA: B1(2100), B2(1900), B4(1700), B5(850), B8(900);
TDSCDMA: B34(2010---2025), B39(1880---1920);
CDMA: BC0(800), BC1(1900);
4G FDD: B1(2100), B2(1900), B3(1800), B4(1700), B5(850), B7(2600), B8(900), B12(700), B13(), B17(700), B18(), B19(850), B20(800), B25, B26, B28a(700), B28b(700);
TDD: B34(2100), B38(2600), B39(1900), B40(2300), B41(2500);
Hardware
CPU MT6771T,4xCortex­A73,2.1GHz& 4xCortex­A53,2.0GHz
CPU Clock 2.1GHz
GPU ARM Mali G72 MP3 900MHz
RAM 6GB
RAM Type LPDDR4X
ROM 128GB
ROM Type EMMC5.1
TF Card Slot Support
Max TF Card Capacity 256GB
USB 24pin TYPE-C
Camera
Front Camera 16.0MP
Front Camera Sensor S5K3P9
Front Camera Aperture f2.0
Front Flash NO
Rear Camera 16.0MP + 8.0MP
Rear Camera Sensor S5K2P7 + S5K4H7
Rear Camera Aperture f1.75 + f2.0
Rear Flash YES
Power
Battery Capacity 4380 mAh
Max Charging Current 9V 2A
Multi-media
Video mp4, 3gp, 3gpp, avi, x-flv …
Audio ogg, aac, imy, amr, x-flac, mp3 …
Image jpeg, png, gif, bmp
Features
GPS YES
Sensors YES
Gesture YES
Gyroscope YES
Magnetic YES
Air pressure sensor YES
Hall NO
Compass YES
Fingerprint YES
RGB YES
NFC YES
Hotkont NO
Coulomb Counter YES
Wireless Charging YES
Sim-Card Type 2 Nano-SIM
FM YES
OTG YES
Earphones TYPE-C
SAR Head: 0.164 W/kg;
Body: 0.290 W/kg;
Accessories
User Manual x1
Protective Film Separately x1
Power Adaptor x1
USB Cable x1
Earphones x1
