Blackview BV9500 Pro Walkie Talkie 4G Rugged Phone - Blackview Store
Blackview BV9500 Pro Walkie Talkie 4G Rugged Phone - Blackview Official Store
Blackview BV9500 Pro Walkie Talkie 6GB+128GB 4G Ruggedized Phone - Official Refurbished
$399.99 $150.00
βœ”Walkie-talkie + 4G Rugged Smartphone
βœ”5.7 Inch Helio P23 6GB +128GB
βœ”16.0MP+0.3MP Dual Rear Cameras
βœ”Android 8.1 10000 mAh
Capacity: 6GB+128GB
6GB+128GB
6GB+128GB - Refurbished
Color: Black
Yellow
Green
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Description
Rugged, powered with Android Blackview BV9500 Pro BV9500 Pro come with 10000 mAh battery This ruggedized smartphone comes with a ultra-big capacity battery on 10000mAh, keep the device running for a long time. Running smoothly The faster running rugged phone you want 6GB RAM and 128GB ROM, and up to 2.5GHz CPU offer the Blackview BV9500 Pro Android rugged phone running smoothly, and the Walkie Talkie function is supplied by the device. 4G lte ruggedized phone More faster than 3G network The BV9500 Pro ruggedized phone come with Walkie Talkie and 4G network, make the device more powerful than other devices. BV9500 Pro features No SIM card required for near field communication The ruggedized phone which configure with Walkie Talkie, Allows you to keep in touch with nearby colleagues at any time. BV9500 Pro support 24W fast charging, let the device get power faster. Come with IP68 & IP69K waterproof and MIL-STD-810G military certified. This Walkie Talkie water-resistant ruggedized phone offers longer battery life, it is your best partner on work. BV9500 Pro comes with SONY 16MP rear camera The device come with 5.7 inch screen, which is pocket friendly BV9500 Pro support wireless charging and OTG Other features like Fingerprint, NFC, and more
Specification
Design
Product BV9500 Pro
OS Android 8.1
Color Black, Yellow, Green
Weight 365g
Dimensions 165*81.8*18.7 mm
Screen
Screen Type IPS
Display Resolution FHD IPS
Screen size 5.7 inch
Screen resolution 1080*2160
Connectivity
WIFI 802.11 a/b/g/n
Bluetooth BT4.2
GSM B2(1900), B3(1800), B5(850), B8(900)
3G WCDMA: B1(2100), B2(1900), B4(1700), B5(850), B8(900);
TDSCDMA: B34(2010---2025), B39(1880---1920)
4G FDD: B1(2100), B2(1900), B3(1800), B4(1700), B5(850), B7(2600), B8(900), B17(700), B18(850), B19(850), B20(800), B25(1900), B26(850), B28a(700), B28b(700);
TDD: B34(2100), B38(2600), B39(1900), B40(2300), B41(2500);
C2K: BC0(800), BC1(1900)
GPS YES
Hardware
CPU MT6763T
CPU Clock 2.5GHz
GPU ARM Mali-G71-MP2 770MHz
RAM 6GB
RAM Type LPDDR4
ROM 128GB
ROM Type EMMC5.1
TF Card Slot Support
Max TF Card Capacity 128GB
USB 24pin TYPE-C
Camera
Front Camera 13.0MP
Front Camera Sensor S5K3L8
Front Camera Aperture f2.0
Front Flash NO
Rear Camera 16.0MP + 0.3MP
Rear Camera Sensor IMX298 + GC0310
Rear Camera Aperture f2.0 + f2.8
Rear Flash YES
Power
Battery Capacity 10000 mAh
Max Charging Current 12V 2A
Multi-media
Video mp4\3Gp\mov\mkv…
Audio flac\ape\ac…
Image jpeg\png\gif\bmp
Features
Sensors YES
Gesture YES
Gyroscope YES
Magnetic YES
Air pressure sensor YES
Hall NO
Compass YES
Fingerprint YES
RGB YES
NFC YES
Hotkont NO
Coulomb Counter YES
Wireless Charging YES
Sim-Card Type 2 Nano-SIM
FM YES
OTG YES
Earphones Jack Type 3.5mm
SAR Head: 0.322 W/kg;
Body: 0.517 W/kg;
Accessories
Gift Box x1
User Manual x1
Protective Film Separately x1
Power Adaptor x1
USB Cable x1
Earphones x1
