Blackview BV9100 13000mAh 4G Rugged Smartphone - Blackview Store
Blackview BV9100 Battery Monster 4G Ruggedized Smartphone
$269.99 $209.99
✔13000mAh 30W Fast Charging
✔MT6765 4GB+64GB
✔16.0MP Camera
✔6.3 inch 4G Rugged Smartphone
Best BV9100 Alternative - New 13000mAh 6GB+128GB Rugged Phone BV7100
Capacity: 4GB+64GB - Refurbished
4GB+64GB
Color: Gray
Gray
Silver
Description
13000mAh
13000mAh Killer Battery
Super-Fast Charging
13000mAh
Battery Killer
30W Fast Charging
USB Type-C
5V/6A
4GB+64GB
Helio P35
Octa-Core Processor
Dual Rear Cameras
16MP Sony®
Front Camera
16MP Samsung®
6.3-Inch
FHD+ Waterdrop Screen
Android 9 Pie
Smart & Fast
Fingerprint Quick Access
Unlock in 0.1s
60 days standby time, stay connected at any time
The largest capacity battery in smartphone is here -- 13000mAh in BV9100. BV9100 offers the ultimate solution to the big battery needs of modern smartphone users. It kills your low battery anxiety once and for all.
Gaming
24H
Video
26.6H
Calling
60H
Music
66H
1440H
Fully charged in 2.5 hours, faster than ever
The BV9100 employs top level 30W (5V/6A) super-fast charging technology. You can fully charge the 13000mAh battery in 2.5 hours. Twice as fast as 9V/2A charging.
30W Fast Charging
Fully Charged
Tough from inside out, a reliable partner you can trust
Every component is designed for being super tough. The four corners of the internal structure is protected by impact buffers. Its fuselage is covered with industrial-leading soft rubber. Two sides of the phone are reinforced with anti-wear aluminum alloy. They complement each other, achieving 360-degree all-round collision mitigation.
1.5M Drop Proof
Always Ready for challenge
The BV9100 rises to the occasion whether it withstands pouring rains, muddy roads, relentless bumps, drops, pressure and force in construction sites. You deserve the most solid rugged outdoor phone.
IP68/IP69K waterproof
1.5m drop-proof
360° all-round dust-proof
Helio P35 Octa-core CPU Delivering high performance.
Powered by the efficient Helio P35 octa-core CPU and 4GB of RAM, it gives you fantastic experience in playing games, no lag in loading scene. 64GB ROM plus 128GB expandable storage enables you to store large quantity of videos, photos and Apps.
Helio P35
4GB+64GB
GPS, Glonass, Beidou, Galileo A trusted partner for outdoorsmen.
Equipped with GPS, Glonass, Beidou, Galileo 4 mode positioning systems, BV9100’s navigation accuracy capability is improved to unprecedented levels. It always helps you find your way even in remote region. It’s especially helpful when trekking, mountaineering or other outdoor adventures.
Android 9 Pie, smarter and faster
Android 9 Pie harnesses the power of artificial intelligence to give you more from your phone. It's smarter, faster and adapts to you according to how you use your phone and learning your preferences as you go. Your experience will be promised to get better and better over time, and it keeps things running smoother.
Specification
Design
Product BV9100
OS Android 9
Color Grey, Silver
Weight 408g
Dimensions 171.28*80.2*19.45 mm
Screen
LCD panel JDI
IC FT8719P
Panel type IPS
Display Resolution FHD+ IPS
Screen size 6.3 inch
Screen resolution 1080*2340
PPI/DPI 409
Screen to Body Ratio (%) 84.5%
Viewing Angle (H/V) Full angle
Connectivity
WIFI 802.11 a/b/g/n/ac
Bluetooth BT5.0
2G B2(1900), B3(1800), B5(850), B8(900)
3G B1(2100), B2(1900), B4(1700), B5(850), B8(900);
4G B1(2100), B2(1900), B3(1800), B4(1700), B5(850), B7(2600), B8(900), B12, B17(700), B18(850), B19(850), B20(800), B25(1900), B26(850), B40(2300), B66
Hardware
CPU MT6765
CPU Clock 2.3GHz
GPU IMG GE8320 680MHZ
RAM 4GB
RAM Type LPDDR4X
ROM 64GB
ROM Type EMMC5.1
TF Card Slot Support
Max TF Card Capacity 128GB
USB 24pin TYPE-C
Camera
Front Camera 16.0MP
Front Camera Sensor S5K3P9
Front Camera Aperture f2.0
Front Flash NO
Rear Camera 16.0MP + 0.3MP
Rear Camera Sensor IMX298 + GC0310
Rear Camera Aperture f2.0 / f2.0
Rear Flash YES
Power
Battery Capacity 13000 mAh
Max Charging Current 5V 6A
Multi-media
Video mp4/3gp/3gpp/avi/x-flv…
Audio ogg/aac/imy/amr/x-flac/mp3…
Image jpeg/png/gif/bmp
Features
Navigation GPS + GLONASS + Beidou + Galileo
Sensors YES
Gesture YES
Gyroscope YES
Magnetic YES
Air pressure sensor NO
Hall NO
Compass YES
Fingerprint YES
RGB YES
NFC YES
Hotkont NO
Coulomb Counter NO
Wireless Charging NO
Sim-Card Type 2 Nano-SIM
FM YES
OTG YES
Earphones Jack Type 3.5mm
SAR Head: 0.461 W/kg;
Body: 0.959 W/kg;
Accessories
User Manual x1
Protective Film Separately x1
Power Adaptor x1
USB Cable x1
Earphones x1
