Blackview BV6600 Pro Thermal Camera 5.7" 4+64GB 8580mAh Android 11 4G Rugged Smartphone
$399.99 $239.99
✔FLIR® Thermal Imaging Camera
✔8580mAh Big Battery
✔IP68&IP69K MIL-STD-810G
✔Doke 2.0 OS Based On Android 11.0
Capacity: 4GB+64GB
4GB+64GB
Color: Green
Green
HURRY! ONLY LEFT IN STOCK.
Frequently Bought Together
Total price:$549.97 $335.97
Description
THE MOST AFFORDABLE
THERMAL RUGGED PHONE
Identify and fix problems through advanced
thermal imaging technology
advanced thermal imaging technology
Thermal by FLIR®8580mAh battery
  • Thermal by FLIR®
    See and measure heat
  • 8580mAh battery
    792 hrs standby time
  • Reverse charging
    Power bank
  • IP68 & IP69K & MIL-STD-810G
    Dominant toughness
  • Samsung®16MP rear camera
    Sony® 8MP front camera
  • 5.7" HD+ display
    1440 x 720
  • Octa-core CPU
    4GB RAM+ 64GB ROM
  • Global LTE bands
    Fingerprint sensor & NFC
Thermal by FLIR®
Introducing the most economical, longest lasting, Thermal by FLIR® ruggedized phone, the BV6600 Pro. With over 8500mAh of power, the BV6600 Pro will support your communications, browsing, gaming, outdoor lifestyle, and social media updates without needing to stop for more power. Endlessly share thermal images of the world on a single charge, never missing a moment.
Work and Play
The BV6600 Pro thermal phone is more than a predictive maintenance tool, home inspection system, that fits in your back pocket, it is a connected device providing you with new and exciting ways to view the world. Powered by FLIR® thermal imaging technology the BV6600 Pro is an exciting addition to your social media lifestyle. Share, stream, and have fun with alien-like vision.
Thermal Imaging Indoors
bv6600pro
Thermal Imaging for Temperature Distribution
in Bedroom and Living Room
Pinpoint the area with the ideal temperature
Care for health of your families
  • bv6600pro
    Optimal temperature of living room
  • bv6600pro
    Optimal temperature of bedroom
Thermal Imaging for Potential fire Prevention
Find the potential electrical failures and avoid electrical fires
Care for safety of your families
  • bv6600pro
  • Water dripping
    from air outlet
    bv6600pro
  • Potential light overload
    bv6600pro
Thermal Imaging for Kitchen Uses
Find plumbing issues, blocked pipes and leaks
Discover problems earlier, improve kitchen use efficiency and reduce
maintenance cost
  • bv6600pro
    • The place where
      it's clogged
      bv6600pro
    • The place
      where it fails
      bv6600pro
    • The water leaks
      bv6600pro
Thermal Imaging for First Responder
See through obscurance
See through hazards such as smoke and find people
  • bv6600pro
  • A room with thick smoke
    Find the people in thick smoke behind the door
    bv6600pro
Temperature Distribution on Windows,
Chimney, Roof and Doors
Spot energy inefficiency due to leaking issues
  • Air leak
    bv6600pro
    Leaking on windows
  • bv6600pro
    The clogged chimney
  • bv6600pro
    Water leak on the roof
  • Air leak
    bv6600pro
    Leaking on doors
Thermal Imaging for Daily Agriculture
Help monitor moisture levels in soil for healthy plants
(garden, lawn, balcony, bedroom)
Effectively find the problems and carry out corresponding measures
  • Flowers in garden
    bv6600pro
    • Flowers on balcony
      bv6600pro
    • Grass on lawn
      bv6600pro
    • Flowers in bedroom
      bv6600pro
Thermal Imaging for Culinary
Get the ideal diet temperature for your families members
  • Cold and hot water in coffee
    bv6600pro
    • Fresh
      bv6600pro
    • Spoiled
      bv6600pro
    • Fresh
      bv6600pro
    • Spoiled
      bv6600pro
    • Beverage
      bv6600pro
  • Beverage
    bv6600pro
Funny Thermal Images in Daily Life
Everyone can be Van Gogh
  • bv6600pro
  • bv6600pro
  • bv6600pro
  • bv6600pro
  • bv6600pro
  • bv6600pro
  • bv6600pro
Thermal Imaging for Finding Hidden Pets
Find your pets in areas invisible to naked eyes
(Under the dark bed, at corners, in basement, at the stairwells, in the grass)
Make it more effective to find the pets
  • Hidden inside the quilt
    bv6600pro
  • A dog under the car
    bv6600pro
Thermal Imaging Outdoors
bv6600pro
Temperature Distribution of Cars
Inside and outside, help detect and analyze automotive electrical and mechanical problems
Always find the best maintenance solution to your cars in advance
bv6600pro
  • Rear window defroster
    wire inspecting
    Engine compartment checking
    In-car temperature monitoring
    Tire chassis detecting
    bv6600pro
    • bv6600pro
    • bv6600pro
    • bv6600pro
    • bv6600pro
bv6600pro
bv6600pro
bv6600pro
bv6600pro
Distribution in Public Places
Find the area with the most comfortable temperature
Go out more comfortably
  • Bus
    bv6600pro
  • Subway
    bv6600pro
  • Restaurant
    bv6600pro
  • Supermarket
    bv6600pro
Thermal Imaging for Night Out
Reduce potential risks and get out at night more safely
  • bv6600pro
  • Find the hidden people
    bv6600pro
  • Find the hidden wild boar
    bv6600pro
Outdoor Travels
Enhance personal safety in outdoor environments
Discover the followers behind the trees and grass and make every travel safer
  • Find the dangerous animals
    Find the lost teammates
    Check the BBQ fire
    bv6600pro
    bv6600pro
  • Check the BBQ grill fire
    bv6600pro
  • Find the lost teammates
    bv6600pro
Effective area for thermal imaging: 25m
Distance 2-5m: 2℃-3℃ temperature difference
Distance over 5m: 5℃-10℃ temperature difference
Thermal Imaging for Social Life
Thermal Imaging for Families
Check the emotions from temperature changes
Find a more pleasant way to communicate
  • The kid being sad
    The kid laughing
    Before getting angry
    After getting angry
    bv6600pro
Thermal Imaging for Friends
Make it simpler to communicate with your friends
  • bv6600pro
  • Discussion
    Exciting talking
    Before partying with friends
    After partying with friends
Thermal Imaging for Love Romances
Every temperature change reveals the love
  • bv6600pro
  • Love at first sight
    Agitating dating
    Before proposal
    After proposal
8580mAh battery beast
Everlasting productivity
53% above average capacity
Network-off standby time up to 792 hrs and 4G/WiFi standby time up to 430 hrs. You will no longer suffer from battery anxiety.
Network-off standby
792 hrs
4G/WiFi standby
430 hrs
Advanced dual electric cores technology
Safer and more stable. It delivers the best 8580mAh phone experience possible, without compromise.
Serve as power bank too Buy one get two
Supporting reverse charging function, BV6600 Pro can perform as an enormous 8580mAh power bank to lend juice to another device on the go. The Type-C charging port makes it easier to plug.
IP68 & IP69K & MIL-STD-810G certified
Built to take a beating
As a serious rugged phone, BV6600 Pro has outstanding resistance to water, drops, shock, and daily abuse that cannot be matched by a mainstream device in a case.
A solid structure for outstanding drops and shocks resistance
  • Metal frame fixed with screws
  • Thickened rubber corner
    for great protection
  • Tough unibody for
    reduced risk of falling apart
  • Well-fixed dual batteries for
    enhanced stability and safety
* BV6600 Pro is drop-proof up to 1.2m based on the laboratory test
Leading waterproof technology
BV6600 Pro is specially designed to perform to high standards even in wet environments, with internal parts protected with waterproof membranes, as well as an anti-deforming charging cap.
* BV6600 Pro can be submersible in up to 1.5 meters of freshwater for up to 30 minutes
* It's suggested to air dry BV6600 Pro after water immersion
The perfect trio
Thermal technology + Massive battery + Dominant toughness
Everything you need is included
  • Rain doesn't stop your business.
  • Drops cause little harm.
  • Less downtime as the battery outlasts.
  • Navigate smarter and avoid danger,
    day or night.
  • Best partner for x-sports.
Samsung®16MP rear camera & Sony® 8MP front camera
High-class camera for classy photography
PortraitColor, Mono, and Beauty modes are handy to get incredible snaps effortlessly.
Available on both the rear and front cameras.
  • PortraitColor
    Stand out in the Monochrome world.
  • Mono
    Get an antique look with a blend of surrealism and realism.
  • Beauty
    Flawless beauty, perfect you.
5.7 inches HD+ display
Good balance of toughness and aesthetics on the screen
The 5.7 inches HD+ display uses in-cell technology to present natural vivid colors in every frame. Protected by the DragontrailTM glass, it has great resistance to scratches.
5.7
inches
1440 X 720
Resolution
18 : 9
Aspect ratio
Octa-core processor Smooth experience and fast response to your demands
BV6600 Pro is equipped with fast octa-core CPU for a smooth experience. Paired with 4GB of RAM, 64GB of storage with 128GB microSD card expansion, worry-free to save as many as 150 movies.
MediaTek Helio P35, Octa-core
4GB RAM + 64GB ROM
128GB Expansion
More powerful and efficient
Upgrade to Helio P35 compared with the predecessor, BV6600
Model
BV6600
BV6600 Pro
Processor
Helio A25
Helio P35
CPU
1.8 GHz quad-core Cortex-A53
1.5 GHz quad-core Cortex-A53
8× Cortex-A53 @ 2.3GHz
GPU
PowerVR GE8320 @ 600 MHz
PowerVR GE8320 @ 680MHz
Always in the right direction
More is better when it comes to satellites.BV6600 Pro's quad navigation system enables faster and more reliable ambiguity fixing even in street canyons, mountains.
Doke 2.0 OS
As natural as breathing
Doke 2.0 OS is developed based on Android 11 and goes beyond the Android system in terms of aesthetics, interaction, and efficiency.
  • App Freezer
    One click to put rogue apps in the Freezer and stop their background running for maximum power saving and efficiency.
  • Data Migration Assistant
    Safely migrate photos, contacts, messages and more from your old phone to your new phone with the Data Migration Assistant. All can be done without Wi-Fi or mobile data.
  • System Manager
    Get better and smarter control over trash cleaning, battery performance, gaming boosting, and background running of Apps.
Even the little things make a big deal
Multi-function NFC
The user-friendly NFC function allows you to use Google pay, buy public transport tickets and share files with other smartphones.
power button 2-in-1 key
Easy to reach. Unlock in a wink. No need to input passwords or draw a complicated pattern.
Dual 4G VoLTE
BV6600 Pro supports 4G VoLTE in both slots simultaneously - enjoying faster data transmission, lower power consumption, and more reliable connection.
Global LTE bands
FDD-LTE Bands 1/2/3/4/5/7/8/12/13/17/19/18 /20/28A/28B/25/26/66; TDD-LTE Bands 38/40/41. Get 4G in more places.
  • Oasis Green
  • Nightfall Black
  • Sunset Orange
Specification
Design
ProductBV6600 Pro
OSAndroid 11.0
ColorBlack, Orange, Green
Weight325g
Dimensions159*79.4*18
Screen
LCD panelBOE
ICICNL9911C
Panel TypeIPS
Display ResolutionHD+
Screen Size5.7 Inch
Screen Resolution720*1440
Viewing angle (H/V)Full angle
PPI/DPI182
GlassDragontrail Glass
Connectivity
WIFI 802.11 a/b/g/n/ac
Bluetooth V5.0
2G2/3/5/8
3G WCDMA:B1/B2/B4/B5/B8
CDMA: BC0/BC1/BC6
4G TDD: B38/B40/B41
FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B19/B18/B20/B28A/B28B/B25/B26/B66
Hardware
CPUMT6765V/CA
CPU Clock 2.3GHz
GPUIMG GE8320 650MHz
RAM4GB
RAM TypeLPDDR4
ROM64GB
ROM TypeEMMC
TF Card SlotSupport
Max TF Card Capacity128GB
USBTYPE-C
Camera
Front Camera 8.0MP
Front Camera SensorIMX134/IMX219
Front Camera Aperturef2.0
Rear Camera 16.0MP + 5.0MP
Rear Camera Sensor S5K3P9SX + GC5035
Rear Camera Aperture f2.0
Rear FlashYes
High Resolution Micro Thermal Camera80 x 60 active pixels,Low operating power – 140 mW typical, 650 mW during shutter event
Video 1080P 30fps H.264
Power
Battery Capacity8580mAh
Max Charging Current9v 2A
Multi-media
Videomp4\3Gp\mov\mkv…
Audioflac\ape\ac….
Imagejpeg\png\gif\bmp
Features
NavigationGPS+GLONASS+Beidou+Galileo
MotorCylinder motor
SensorsYES
GyroscopeYES
MagneticYES
Air pressure sensorNO
HallNO
CompassYES
FingerprintYES
RGBYES
NFCYES
HotkontNO
Coulomb CounterNO
Wireless ChargingNO
Sim-Card TypeTwo nano card
FMYES
OTGYES
Earphones Jack TypeTYPE-C
Accessories
User Manualx1
Protective Film Separatelyx1
Power Adaptorx1
USB Cablex1
Earphonesx1
NOTE
