Blackview BV6100 Dual Gorilla Glass 4G Rugged Phone - Blackview Store
Blackview BV6100 Dual Gorilla Glass 4G Ruggedized Smartphone
$199.99 $129.99
✔6.88 inch Dual Gorilla Glass
✔3GB+16GB IP68 Waterproof
✔Android 9.0 5580mAh NFC
Capacity: 3GB+16GB
3GB+16GB
Color: Gray
Gray
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Description
IP68 &IP69K & MIL-STD-810G
The Main technique
6.88"
Notch Fullview Display
5580mAh
Huge Battery
Helio A22
Quad Core Processor
3GB RAM
16GB ROM
8MP Sony
Dual Rear Camera
IP68
Certified Rating
NFC
Multifunctional
Fast Touch ID
IP68/IP69K Certified Rating MIL-STD-810G Military Standard
BV6100 is an ultra-rugged smartphone with super big screen and huge battery, which is built strong to withstand harsh conditions and rough handling compared to other ordinary smartphones. BV6100 meets military standard for dust, shock, water, humidity, solar radiation and temperature extremes, which meets the rigorous demand of your job site but also is suitable for business needs.
MIL-STD-810G
1.5M Drop Test 15 Times
IP69K
1.5M Water Deep 30 Mins
IP68
99% Dustproof
Space to Explore 6.88" Immersive Full Screen Display
Bigger than ever before, the 19:9 Full Screen Display truly captivates. As soon as you turn on the screen, every pixel leaps out in full color to paint a true-to-life picture. Lose yourself into a truly immersive experience, ambitious gamers and entertainment bingers can dive into their own world.
GPS, Glonass, Beidou, Galileo
4 Mode Navigation, Exceptionally Accurate Positioning BV6100 is our first ever rugged phone equipped with 4 mode positioning systems. By using GPS, Glonass, Beidou, Galileo 4 channels signals in coordination, over 100 navigation satellites, continuously scans your location 24 hours a day, navigation accuracy is improved to unprecedented levels.
Power You Up 5580mAh battery, Huge Capacity
Inside the sleek exterior of BV6100 lies massive energy — a 5580mAh battery custom-crafted to pack maximum performance into minimum space. This industry-leading 5580mAh battery delivers a staggering level of power that can handle intense gaming and long working hours. Moreover, it is also a battery that has rich enough power to support charging your other devices. Do more, without worry of getting through the day.
Video Playback
22H
Continuous Gameplay
10H
Music Playback
100H
Standby Time
600H
See a Clear World
AI Dual Rear Camera
BV6100 features an advanced dual-camera system. The ultra-sensitive dual camera has newly updated AI capabilities, featuring flagship Sony cmos sensor for stunning nightscape shots and fast VCM autofocus so that shots focus rapidly even in dimly-lit environments. And with underwater camera mode built in, now you can explore the underwater world with just your own smartphone, open a new field of photography.
8.0MP + 0.3MP
background blurring
VCM
Autofocus
1.12 μm
large pixels
Underwater
Camera
The latest version of Blackview's beautiful user interface that’s designed to provide a more intuitive experience to help you accomplish tasks and find information faster, improve your productivity, and simply have more fun using your phone.
30% More
Performance
15% Less
Consumption
Multifunctional NFC
Replace your bank card, bus card, and door card in one device with the latest generation NFC module. And It is also compatible with the Google Pay, fast, simple way to pay in millions of places – online, in stores, and more.
Google Pay
Access
Data-transmission
Specification
Design
Product BV6100
OS Android 9
Color Grey, Silver
Weight 315g
Dimensions 181*89.7*11.5 mm
Screen
Panel type IPS
Display Resolution HD-
Screen size 6.88 inch
Resolution 640*1352
Connectivity
WIFI 802.11 a/b/g/n
Bluetooth BT5.0
2G B2(1900), B3(1800), B5(850), B8(900)
3G B1(2100), B8(900)
4G B1(2100), B3(1800), B7(2600), B8(900), B20(800), B40
Hardware
CPU MT6761
CPU Clock 2.0GHz
GPU IMG GE8300@420/660MHZ
RAM 3GB
RAM Type LPDDR3
ROM 16GB
ROM Type EMMC
TF Card Slot Support
Max TF Card Capacity 128GB
USB TYPE-C
Camera
Front Camera 5.0MP
Front Camera Sensor GC5025
Front Camera Aperture f2.4
Front Flash NO
Rear Camera 8.0MP/0.3MP
Rear Camera Sensor IMX134/GC0310
Rear Camera Aperture f2.4/f2.8
Rear Flash YES
Power
Battery Capacity 5580 mAh
Max Charging Current 5V 2A
Multi-media
Video mp4\3gp\mov\mkv...
Audio flac\ape\ac…
Image jpeg\png\gif\bmp
Features
Navigation support GPS+Beidou+Glonass+Galileo
Sensors YES
Gesture NO
Gyroscope YES
Magnetic YES
Air pressure sensor NO
Hall NO
Compass YES
Fingerprint YES
RGB YES
NFC YES
Hotkont NO
Coulomb Counter NO
Wireless Charging NO
Sim-Card Type 2 Nano-SIM
FM YES
OTG YES
Earphones Jack Type 3.5mm
SAR Head: 0.915 W/kg;
Body: 0.827 W/kg;
Accessories
Gift Box x1
User Manual x1
Protective Film Separately x1
Power Adaptor x1
USB Cable x1
Earphones x1
