Blackview A80 Pro 4G Smartphone - Blackview Store
Blackview A80 Pro Sony® IMX258 13MP Quad Camera 4GB+64GB 4G Smartphone - Official Refurbished
$159.99 $80.00
✔6.49" Waterdrop
✔Octa Core 4GB+64GB 4680mAh
✔Quad Rear Camera
Capacity: 4GB+64GB - Official Refurbished
4GB+64GB
Color: Black
Red
Blue
Green
Description
Note:
This phone CAN NOT work with U.S. carrier Verizon Wireless. If you have any questions about the mobile phone, please feel free to contact us.
Quad Camera Budget King
All the Features You Want in a Budget King A80 Pro
8MP High-Resolution Selfie
4680mAh Big Battery
5V/2A, Type-C Port
MediaTek Helio P25 Processor
4GB RAM + 64GB ROM
HD+ 6.49" In-Cell Waterdrop Screen
90.3% Screen-to-Body Ratio
Global LTE Bands
Perfect for Worldwide Travel
Face & Fingerprint Unlock
Speedy and Secure
Android 9 Pie
3.5mm Audio Jack
LED Notification
3D Aesthetics Design
8.8mm Slim Body
All for Your Personal
Photo Studio
Blackview A80 Pro fits four separate cameras into a single smartphone. A 13MP rear main lens is assisted with triple sub-lens for crystal-clear and vivid photos. Combined with smart scene recognition and cutting-edge photography technology, it turns any moment into artistic photos with depth and clarity.
Sony® IMX258 Quad Camera
13MP High Resolution
Enhance Your
Natural Beauty
A80 Pro’s Sony® 8MP front camera enhances your facial features even further with clarity and delicacy. It automatically identifies ages and smoothens different skin tones depending on gender.
Sony® IMX239
AI Beautification
Face Unlock
4680mAh Big Battery
With the help of a power-saving processor and AI power management, the 4680mAh Big battery can generally power you through one day or more easily.
4680mAh Big Battery | 5V/2A Fast Charge | Type-C Port | OTG Support
19H Calling
21H Music
8.4H Video
600H Standby
Powered to Enjoy More
Working in tandem with A80 Pro’s 4GB of RAM, MediaTek Helio P25 Octa-core provides faster performances while produces significant power-saving performance. Paired with 64GB of storage, it allows you to work more, play more, share more and at the same time plug in less.
High-Performance
Helio P25 Octa-core
4GB RAM + 64GB ROM
AnTuTu 90K+
Average Benchmarks
MediaTek Helio P23
100%
MediaTek Helio P25
135%
Immerse Yourself in The Visual Feast
A80 Pro’s 6.49’’ waterdrop screen, combined with in-cell technology, supports a full screen of distinct clarity and vivid color. Nothing is this more evident than playing the graphic rich games. 2.5D curved glass flowingly joints to the body for better handling and aesthetic feel.
19:9 Aspect Ratio
90.3% Screen-to-body Ratio
Global LTE Bands, Perfect for Worldwide Travel
The A80 Pro supports global LTE bands, which helps your phone work globally across time zones and with most international and local wireless carriers. Always stay connected wherever you are.
2G
GSM Bands 2/3/5/8
3G
Bands 1/2/4/5/8
4G
FDD-LTE Bands 1/2/3/4/5/7/8/12/13
/17/18/19/20/25/26/28A/28B/66
TDD-LTE Bands 38/40/41
EVDO BC0/BC1
Hold a Piece of Artwork
A80 Pro’s 3D aesthetics design gives you a natural touch in the palm of your hand. The colors shine the balance of silky fluency and ultra comfort.
Always Find Your Way through Exploration
Equipped with GPS & GLONASS & BeiDou triple navigation systems, A80 Pro minimizes the dead zone when driving between urban canyons, or playing outside. You are free to explore and discover.
Android 9 Pie,
No Ads & Bloatware
Blackview A80 Pro runs the smoothest and fastest Android 9 pie, no ads and bloatware! Powered by artificial intelligence, it gives you more features than ever.
Coral Red
Gradient Blue
Jade Green
Midnight Black
Specification
Design
Product A80 Pro
OS Android 9
Color Coral Red, Gradient Blue, Jade Green, Midnight Black
Weight 180g
Dimensions 162.75*77*8.8 mm
Screen
Panel type IPS
Display resolution HD+ IPS 19:9
Screen size 6.49 inch
Resolution 1560*720
Screen to Body Ratio(%) 90.3%
Viewing angle (H/V) Full Angle
PPI/DPI 265
Connectivity
WIFI IEEE 802.11b/g/n
Bluetooth V4.2
2G GSM Bands 2/3/5/8
3G Bands 1/2/4/5/8
4G FDD-LTE Bands 1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28A/28B/66
EVDO BC0/BC1
(Note: This phone CAN NOT work with U.S. carrier Verizon Wireless.)
Hardware
CPU MediaTek Helio P25 (MT6757V) SoC
CPU Clock 2.6GHz
GPU ARM Mali-T880 MP2 1GHz
RAM 4GB
RAM Type DDR3
ROM 64GB
ROM Type eMMC5.1
TF Card Slot Support
Max TF Card Capacity 256GB
USB Type-C
Camera
Front Camera 8MP
Front Camera Sensor IMX239
Front Flash NO
Rear Camera 13MP + 2MP + 0.3MP + 0.3MP
Rear Camera Sensor IMX258 + GC032A
Rear Flash YES
Power
Battery Capacity 4680 mAh
Max Charging Current 5V 2A
Multi-media
Video Yes
Audio Yes
Image Yes
Features
GPS GPS + GLONASS + BeiDou
Gesture NO
Gyroscope NO
Magnetic NO
Hall NO
Fingerprint YES
RGB YES
NFC NO
Hotkont NO
Coulomb Counter NO
Wireless Charging NO
Sim-Card Type Nano SIM, Dual SIM or a SIM & a TF card
FM YES
OTG YES
Earphones Jack Type 3.5mm
Accessories
User Manual x1
Power adaptor x1
USB Cable x1
Earphones x1
