Blackview A60 Pro 4G Smartphone - Blackview Official Store
$99.99
A60 Pro Waterdrop Screen | 4080mAh Battery 6.088" Waterdrop Screen 8MP Dual Rear Camera 4G Connectivity Touch ID 4080mAh Big Battery...
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Description
A60 Pro
6.088"
Waterdrop Screen
8MP Dual
Rear Camera
4G
Connectivity
Touch ID
4080mAh
Big Battery
3GB RAM
16GB ROM
Waterdrop Full Screen,
Expand Your Vision
Water is life. The unique shape of the Blackview A60 Pro’s notch is inspired by a droplet of water captured at the moment before it falls; a brief, transitional state between movement and stillness, where anything is possible. When you turn on the screen, it bursts into life as if infused with the life-giving power of water.
4080mAh big battery using the world's leading ATL Li-ion battery
A huge 4080mAh battery capacity frees you from the concern of battery draining during your day. Moreover, smart and thoughtful AI battery management freezes inactive apps and reduces excess caching to save more power. This allows you to play at will, and there's no need to worry about running out of battery because of using the world's leading ATL Li-ion battries.
Extreme Speed Rear Fingerprint Scanning
By embedding fingerprint sensor at the back of the phone, A60 Pro’s Fingerprint Scanning technology can accurately identify you, with just a single touch required for immediate access.
Quad-Core Performance Meets 3GB RAM
Empowered by a new quad-core processor and 3GB Ram, the Blackview A60 Pro Android smartphone runs smoothly even when performing complex tasks. Easily run multiple apps simultaneously, and switch between games and social media apps with ease. Don’t worry - your A60 Pro is designed to keep up with you!
Android 9 Pie, AI Powered
Android 9.0 harnesses the power of artificial intelligence to give you more from your phone. It contains the best of Android in a much smaller size, built with new and reimagined apps, provides a smarter, more efficient and convenient user experience.
4G Worldwide Connectivity
Its WorldMode LTE has supported VoLTE and Dual SIM Dual Standby, meeting futureproof needs as 2G networks are progressively retired. To ensure the connectivity experience remains consistent, MediaTek’s TAS 2.0 smart antenna technology improves the power efficiency and user experience by providing a more reliable and consistent connection quality.
Global 4G
Network Support
Ultra-Fast
Download Speed
Green
Blue
Specification
Design
Product
A60 Pro
OS
Android 9.0
Color
Black, Green, Blue
Weight
170g
Dimensions
156.8*74*9.8 mm
Screen
Panel type
IPS
Display resolution
HD- IPS 19.2:9
Screen size
6.088 inch
Resolution
1280*600
Screen to Body Ratio(%)
92%
Viewing angle (H/V)
Full angle
PPI/DPI
232
Connectivity
WIFI
IEEE 802.11 b/g/n
Bluetooth
V4.2
2G
B2(1900), B3(1800), B5(850), B8(900)
3G
B1(2100), B8(900)
4G
B1(2100), B3(1800), B7(2600), B8(900), B20(800), B40(2300)
Hardware
CPU
Helio A22 (MT6761) SoC
CPU Clock
2.0GHz
GPU
IMG GE8300 660MHz
RAM
3GB
RAM Type
DDR3
ROM
16GB
ROM Type
eMMC
TF Card Slot
Support
Max TF Card Capacity
256GB
USB
5pin Micro
Camera
Front Camera
5.0MP
Front Camera Sensor
GC5025
Front Flash
NO
Rear Camera
8.0MP
Rear Camera Sensor
OV8858
Rear Flash
YES
Power
Battery Capacity
4080 mAh
Max Charging Current
5V 1A
Multi-media
Video
Yes
Audio
Yes
Yes
Features
GPS
YES
Sensors
YES
Gesture
NO
Gyroscope
NO
Magnetic
NO
Hall
NO
Fingerprint
YES
RGB
YES
NFC
NO
Hotkont
NO
Coulomb Counter
NO
Wireless Charging
NO
Sim-Card Type
2 Nano-SIM, 1 TF
FM
YES
OTG
NO
Earphones Jack Type
3.5mm
SAR
Head: 0.186 W/kg;
Body: 0.390 W/kg;
Accessories
Gift Box
x1
User Manual
x1
Power adaptor
x1
USB Cable
x1
Earphones
x1
