Blackview BL9000 Pro 5G 12+512GB FLIR® Lepton 3.5 Thermal lmaging Camera MyFLIR® Pro APP 6.78-inch Dimensity 8020 6nm Rugged Phone
$759.99 $549.99
✔Latest Thermal Imaging FLIR® Lepton 3.5 & MyFLIR® Pro APP
✔50MP OIS Anti-shake Rear & 50MP Selfie Cameras
✔5G 6nm Octa-core MediaTek Dimensity 8020 CPU
✔Dual Band WiFi 6 & USB 3.0 Support
✔Dual Harman Kardon Smart-PA Speakers
✔Corning® Gorilla® Glass 7 (Victus®)
Capacity: 12GB+512GB
12GB+512GB
Color: Black
Shipment will start on May 16, 2024Will be in stock after May 16, 2024
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Frequently Bought Together
Total price:$899.97 $649.97
Specification
Design
ProductBL9000
OSDokeOS4.0 Based on Android 14
ColorBlack, Gold
Weight412g
Dimensions179.5*82.6*17mm
Screen
LCD panelBOE
ICILI7807S
Panel TypeIPS
Display ResolutionFHD+
Screen Size 6.78 Inch
Screen Resolution1080*2460 20:9
Screen to Body Ratio (%)86%
Viewing angle (H/V)Full angle
PPI/DPIPPI: 396
Refresh frequency 120HZ
GlassCorning® Gorilla® Glass 7(Victus®)
Connectivity
WIFI 802.11a/b/g/n/ac/ax
Bluetooth V5.1
2GB2/B3/B5/B8
3G WCDMA: B1/B2/B4/B5/B6/B8/B19
CDMA: BC0/BC1/BC10
4G TDD: B34/B38/B39/B40/B41
FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B25/B26/B28a/B28b/B30/B66
5G N1/3/5/7/8/20/28/38/40/41/77/78/79
Hardware
CPUMediaTek Dimensity 8020 (6nm), Octa-core, Up to 2.6GHz
CPU Clock ARM Cortex-A78 cores @ 2.6GHz*4, ARM Cortex-A55 cores @ 2.0GHz*4
GPUARM G77 MC9 836MHz
RAM 12GB
RAM TypeLPDDR4X
ROM512GB
ROM TypeUFS3.1
TF Card SlotNO
USBTYPE-C (USB 3.0)
Camera
Front Camera 50MP
Front Camera SensorSK Hynix 5022Q
Front Camera Aperturef2.45
Rear Camera 50MP main camera
FLIR® Lepton® 3.5, 160x120 Resolution Thermal Imaging Camera
13MP 120° Ultra-wide & up to 2cm Ultra-macro Camera
Rear Camera Sensor Samsung® ISOCELL GN5 + FLIR® Lepton® 3.5 LWIR Micro Thermal Camera Module + Hi-1336 + VGA
Rear Camera Aperture f1.88/f2.2
Rear Flash Yes
Video4K Video Recording with Beauty Mode
Thermal Imaging Camera Datasheet
ModelLepton 3.5, 160×120, 57° with shutter
Thermal Imaging DetectorUncooled microbolometer
Pixel Size 12 µm
Frame Rate Options 8.7 Hz (commercial application exportable)
Thermal Spectral Range Longwave infrared, 8 µm to 14 µm
Scene Temperature Range High Gain Mode: -10 °C to 140 °C (14 °F to 284 °F)
Low Gain Mode: -10 °C to +400 °C (14 °F to 752 °F) at room temperature
Power
Battery Capacity 8800mAh, 120W Super-fast Charge
Max Charging Current6A
Multi-media
Video 3pg\mp4\avi\3gp\3g2\3gpp…
Audio mpeg\3gpp\raw\wma\alac…
Imagejpeg\png\gif…
Features
NavigationGPS+GLONASS+Beidou+Galileo
Motor Flat motor
SensorsG/P/L-sensor
GyroscopeYES
MagneticYES
Air pressure sensorYES
HallNO
CompassYES
FingerprintYES
RGBYES
NFCYES
HotkontNO
Coulomb CounterYES
Wireless ChargingNO
Sim-Card TypeTwo nano card
FMYES
SpeakerDual Harman Kardon Smart-PA Speaker, Sound By Harman AudioEFX®
OTGYES
Earphones Jack TypeTYPE-C
Accessories
User Manualx1
Power Adaptorx1
USB Cablex1
NOTE
