{"product":{"id":9189840257249,"title":"Blackview XPLORE 1 Pro Thermal Imaging Rugged 5G Phone with 6.78\" 120Hz Main \u0026 2.01\" Secondary Display 20000mAh \u0026 170LM Flashlight","body_html":"\u003cstyle\u003e\n    #xplore1pro{\n        max-width: 1200px;\n    }\n    @media screen and (max-width: 1200px) {\n        #xplore1pro{\n            max-width: 100%;\n        }\n    }\n\n\n\u003c\/style\u003e\n\u003cdiv class=\"main\" id=\"xplore1pro\"\u003e\n    \u003cstyle\u003e\n        .t4s-swatch__list .t4s-swatch__item{\n            text-decoration: none !important;\n        }\n        .t4s-product-tabs-wrapper.is--tab-position__external .t4s-container {\n            padding: 0;\n        }\n    \u003c\/style\u003e\n    \u003clink rel=\"stylesheet\" href=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/upload\/other\/xplore1pro-20251111094729923.css\"\u003e\n    \u003cdiv class=\"xplore1pro-pc\"\u003e\n        \u003csection id=\"section-1\" class=\"se\"\u003e\n            \u003cdiv class=\"page flex-col\"\u003e\n                \u003cdiv class=\"section_1 flex-col\"\u003e\n                    \u003cdiv class=\"image_1 flex-col\"\u003e\n                        \u003cdiv class=\"section_22 flex-row justify-between\"\u003e\n                            \u003cspan class=\"text_122\"\u003eXPLORE 1\u003c\/span\u003e\n                            \u003cdiv class=\"box_66 flex-col justify-between\"\u003e\n                                \u003cdiv class=\"image_95\"\u003e\n                                    5G\n                                \u003c\/div\u003e\n                                \u003cspan class=\"text_123\"\u003ePro\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_124\"\u003e See the Heat. Conquer the Extreme. \u003c\/span\u003e\n                        \u003cspan class=\"paragraph_67\"\u003e Powered by the Clearest FLIR® \u003cbr\u003e Lepton 3.5 — Wider. Smarter. Tougher.\n              \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_64 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_39 flex-col\"\u003e\n                            \u003cspan class=\"text_113\"\u003eThermal Beyond Compare\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_38 flex-col\"\u003e\n                            \u003cspan class=\"text_114\"\u003e XPLORE 1 Pro × FLIR ® Lepton 3.5 \u003c\/span\u003e\n                            \u003cspan class=\"text_115\"\u003e See Beyond Heat. Conquer Beyond Limits. \u003c\/span\u003e\n                            \u003cspan class=\"text_116\"\u003e Powered by FLIR®, the world leader in thermal imaging, XPLORE 1 Pro lets you see\n                  what others can’t — uncover hidden heat, detect problems before they strike, and capture every thermal\n                  detail with professional precision. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_61 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_40 flex-col\"\u003e\n                                \u003cspan class=\"text_117\"\u003e See Sharper. Feel Deeper. Reach Wider. \u003c\/span\u003e\n                                \u003cspan class=\"text_118\"\u003e Industry’s Only FLIR® VividIR™ | Exclusive MSX® Fusion | 57°FOV Wider View\n                  \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_55 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_28 flex-col\"\u003e\n                            \u003cspan class=\"text_89\"\u003e Industry’s Only Clarity Algorithm \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_33 flex-col\"\u003e\n                            \u003cspan class=\"text_90\"\u003e FLIR® VividIR™ Tech for AI-Enhanced Clarity \u003c\/span\u003e\n                            \u003cspan class=\"text_91\"\u003e Every Detail, Instantly Clear \u003c\/span\u003e\n                            \u003cspan class=\"paragraph_62\"\u003e With FLIR® VividIR™, thermal images become sharper and clearer—less noise,\n                  more detail. Whether you’re spotting hidden heat sources, analyzing equipment, or ensuring safety,\n                  open VividIR™ for next-level clarity. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_29\"\u003e\n                            \u003cspan class=\"text_93\"\u003eFLIR® VividIR™ Activation\u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"block_29 flex-col\"\u003e\n                        \u003cdiv class=\"image-wrapper_17 flex-col\"\u003e\n                            \u003cimg class=\"image_90 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a97ba2821a5b2bcf14b00681a3f2d0f3.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_30 flex-col\"\u003e\n                            \u003cspan class=\"text_94\"\u003eExclusive Image Fusion\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_34 flex-col\"\u003e\n                            \u003cspan class=\"text_95\"\u003e FLIR MSX® Mode for Detailed Thermal Image \u003c\/span\u003e\n                            \u003cspan class=\"text_96\"\u003e Embossed Outlines, Sharper Vision \u003c\/span\u003e\n                            \u003cspan class=\"paragraph_63\"\u003e FLIR MSX® fuses thermal and visual images, embossing sharp outlines and key\n                  details—making objects instantly recognizable for clearer inspections, faster analysis, and smarter\n                  decisions every time. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_58 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_42 flex-row justify-between\"\u003e\n                                \u003cspan class=\"text_97\"\u003eMSX® Strength Adjustment\u003c\/span\u003e\n                                \u003cspan class=\"text_98\"\u003ePicture-in-Picture Mode\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_43 flex-row\"\u003e\n                                \u003cspan class=\"text_99\"\u003e Visible\/Thermal Image Blending Adjustment \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"image-wrapper_18 flex-col\"\u003e\n                                \u003cimg class=\"image_91 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/7aa346498b2569a1d4a2f333845fe280.webp\"\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_33 flex-col\"\u003e\n                            \u003cspan class=\"text_100\"\u003e Industry’s Widest Thermal View \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_101\"\u003e57°FOV Broader View\u003c\/span\u003e\n                        \u003cdiv class=\"text-group_35 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_102\"\u003e See More, Heat Beyond Frame \u003c\/span\u003e\n                            \u003cspan class=\"paragraph_64\"\u003e With a 57° wide thermal view, capture broader scenes and more details in\n                  small frame—making inspections faster, area coverage greater, and thermal imaging more complete.\n                \u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_65 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_41 flex-row\"\u003e\n                            \u003cspan class=\"text_119\"\u003e57°FOV\u003c\/span\u003e\n                            \u003cspan class=\"text_120\"\u003ePeers\u003c\/span\u003e\n                            \u003cspan class=\"text_121\"\u003e42.2°FOV\u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"block_30 flex-col\"\u003e\n                        \u003cdiv class=\"image-text_7 flex-row justify-between\"\u003e\n                            \u003cspan class=\"text-group_29\"\u003e 35% Wider Vision \u0026amp; Faster Inspections \u003c\/span\u003e\n                            \u003cimg class=\"image_92 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a944a189974ea1f96b10e430ccc14a97.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_58 flex-col\"\u003e\n                \u003cspan class=\"paragraph_65\"\u003e Every Degree, Under Your Control \u003cbr\u003e \u0026lt;50 mK Sensitivity | –10 °C – 400\n                  °C Range \u003c\/span\u003e\n                            \u003cimg class=\"image_93 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/03087fc1eadbdfaee300e8deff804d09.webp\"\u003e\n                            \u003cdiv class=\"text-group_36 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_103\"\u003e \u0026lt;50mK Increased Thermal Sensitivity \u003c\/span\u003e\n                                \u003cspan class=\"text_104\"\u003eSee the Subtle Heat\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cspan class=\"paragraph_66\"\u003e With thermal sensitivity below 50mK, XPLORE 1 Pro detects even the slightest\n                  temperature differences. Subtle heat variations become visible, ensuring you never miss hidden issues.\n                \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_59 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_34 flex-col\"\u003e\n                                \u003cspan class=\"text_105\"\u003e50mk ≈ 0.05℃\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_62 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"group_59 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_35 flex-col\"\u003e\n                                    \u003cspan class=\"text_106\"\u003e Sensitive to small thermal fluctuations in air \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_60 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_36 flex-col\"\u003e\n                                    \u003cspan class=\"text_107\"\u003e Even the tiniest chip heat cannot hide \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_37 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_108\"\u003e -10℃ to 400℃ Wide Measurement Range \u003c\/span\u003e\n                            \u003cspan class=\"text_109\"\u003e From Frost to Fire, Measure it All \u003c\/span\u003e\n                            \u003cspan class=\"text_110\"\u003e XPLORE 1 Pro captures extreme cold and intense heat. Whether inspecting freezing\n                  conditions, industrial machinery, or high-temperature equipment — nothing is overlooked. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_94 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/ccc2e15e09ce72d7dbd216741beb96d4.webp\"\u003e\n                        \u003cdiv class=\"group_63 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"box_62 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_37 flex-col\"\u003e\n                                    \u003cspan class=\"text_111\"\u003e Boiler Temperature Monitoring \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_63 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_38 flex-col\"\u003e\n                                    \u003cspan class=\"text_112\"\u003e Extreme Cold Research and Exploration \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n        \u003c\/section\u003e\n        \u003csection id=\"section-2\" class=\"se\"\u003e\n            \u003cdiv class=\"page flex-col\"\u003e\n                \u003cdiv class=\"box_1 flex-col\"\u003e\n                    \u003cdiv class=\"group_1 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_1 flex-col\"\u003e\n                            \u003cspan class=\"text_1\"\u003e Flexible, Faster, Smarter for Every Scene \u003c\/span\u003e\n                            \u003cspan class=\"text_2\"\u003e 9 Color Palettes | 4 Image Fusion Modes | 5 Target Measuring Tools | Video\n                  Recording Support \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_1 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/0b0405ec126aab41fe08760306e176bd.webp\"\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"group_2 flex-col\"\u003e\n                        \u003cdiv class=\"block_1 flex-col\"\u003e\n                            \u003cspan class=\"text_3\"\u003e9 Color Palettes\u003c\/span\u003e\n                            \u003cdiv class=\"text-group_1 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_4\"\u003e Highlight Heat the Way You See Best \u003c\/span\u003e\n                                \u003cspan class=\"paragraph_1\"\u003e Choose from 9 color palettes to adapt to different environment and\n                    highlight subtle temperature contrasts, pinpoint hotspots. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_2 flex-col\"\u003e\n                            \u003cdiv class=\"text-group_2 flex-col\"\u003e\n                                \u003cspan class=\"text_5\"\u003e4 Image Fusion Modes\u003c\/span\u003e\n                                \u003cspan class=\"text_6\"\u003e Adapt to Any Scene. See Every Detail \u003c\/span\u003e\n                                \u003cspan class=\"text_7\"\u003e Whether you need clarity, contrast, or context, each mode gives you the\n                    flexibility to capture and analyze heat exactly as you need. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cspan class=\"text_8\"\u003eFull Thermal Mode\u003c\/span\u003e\n                            \u003cspan class=\"paragraph_2\"\u003e MSX® Fusion Mode \u003cbr\u003e (Multi-Spectral Dynamic Imaging) \u003c\/span\u003e\n                            \u003cspan class=\"paragraph_3\"\u003e Alpha Fusion Mode \u003cbr\u003e (All-New Picture-in-Picture) \u003c\/span\u003e\n                            \u003cspan class=\"text_9\"\u003eFull Visible Mode\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_3 flex-col\"\u003e\n                            \u003cspan class=\"text_10\"\u003e5 Target Measuring Tools\u003c\/span\u003e\n                            \u003cspan class=\"paragraph_4\"\u003e Smart Measure, \u003cbr\u003e Focus on Whats Matters \u003c\/span\u003e\n                            \u003cspan class=\"text_11\"\u003e Whether monitoring large areas or focusing on specific spots, each mode gives you\n                  control, clarity, and actionable insights. \u003c\/span\u003e\n                            \u003cspan class=\"text_12\"\u003eSpot\u003c\/span\u003e\n                            \u003cspan class=\"paragraph_5\"\u003e Measure temperature at an individual Spot \u003cbr\u003e Add up to five spots per image\n                  simultaneously \u003c\/span\u003e\n                            \u003cspan class=\"text_13\"\u003eFull Frame\u003c\/span\u003e\n                            \u003cspan class=\"text_14\"\u003e Display temperature for the entire scene \u003c\/span\u003e\n                            \u003cdiv class=\"text-group_3 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_15\"\u003eRectangle\u003c\/span\u003e\n                                \u003cspan class=\"text_16\"\u003e Display temperature for a specific rectangular area \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cspan class=\"text_17\"\u003eCircle\u003c\/span\u003e\n                            \u003cspan class=\"text_18\"\u003e Display temperature for a specific circle area \u003c\/span\u003e\n                            \u003cspan class=\"text_19\"\u003eLine\u003c\/span\u003e\n                            \u003cspan class=\"text_20\"\u003e Track temperature along a line in the frame \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_4 flex-col\"\u003e\n                            \u003cdiv class=\"text-group_4 flex-col\"\u003e\n                                \u003cspan class=\"text_21\"\u003e3 Recording Modes\u003c\/span\u003e\n                                \u003cspan class=\"text_22\"\u003e Snap, Record, Track Your Heat \u003c\/span\u003e\n                                \u003cspan class=\"text_23\"\u003e Whether capturing a single moment, continuous footage, or tracking changes over\n                    time, these three modes give you full control, flexibility, and insight. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_2 flex-row justify-between\"\u003e\n                                \u003cspan class=\"text_24\"\u003ePhoto\u003c\/span\u003e\n                                \u003cspan class=\"text_25\"\u003eVideo\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_5 flex-col justify-between\"\u003e\n                                \u003cdiv class=\"text-wrapper_3\"\u003e\n                                    \u003cp class=\"text_26\"\u003eTime-lapse\u003c\/p\u003e\n                                    \u003cp class=\"text_27\"\u003e[Industry’s Only]\u003c\/p\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"text_28\"\u003e (Automatically capture interval images and then create time-lapse videos for\n                    monitoring gradual thermal changes —— See the Changes, Not just the Moment) \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"group_3 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_6 flex-col\"\u003e\n                            \u003cspan class=\"text_29\"\u003e 4 Efficient Heat Monitoring \u0026amp; Analyzing Tools \u003c\/span\u003e\n                            \u003cspan class=\"text_30\"\u003e See, Track, and Understand Heat Instantly \u003c\/span\u003e\n                            \u003cspan class=\"text_31\"\u003e From instant alerts to professional reports, these smart tools help you detect,\n                  analyze, and share thermal insights with ease and precision. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_5 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"group_4 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_7 flex-col justify-\"\u003e\n                                    \u003cspan class=\"text_32\"\u003eDynamic Isotherm\u003c\/span\u003e\n                                    \u003cspan class=\"text_33\"\u003e Mark a specific temperature range with a highlight color \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_4 flex-col\"\u003e\n                                \u003cspan class=\"text_34\"\u003eSmart Timer\u003c\/span\u003e\n                                \u003cspan class=\"paragraph_6\"\u003e Set a 3s or 10s timer to capture thermal or visible images hands-free,\n                    avoid shaky shots, plan your framing \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_6 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_8 flex-col justify-\"\u003e\n                                \u003cspan class=\"text_35\"\u003e Smart Alerts \u0026amp; PDF Report \u003c\/span\u003e\n                                \u003cspan class=\"text_36\"\u003e Set your target temperature range, receive real-time alerts when temperatures\n                    reach the preset limits, and then you can instantly generate PDF reports from thermal images for\n                    easy sharing with colleagues or clients. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"list_1 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_9-0 flex-col\"\u003e\n                                \u003cspan class=\"text_37-0\"\u003estep 1\u003c\/span\u003e\n                                \u003cspan class=\"text_39-0\"\u003eSet Warning Temperature\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_9-1 flex-col\"\u003e\n                                \u003cspan class=\"text_37-1\"\u003estep 2\u003c\/span\u003e\n                                \u003cspan class=\"text_39-1\"\u003eAutomatically take Photos\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_9-2 flex-col\"\u003e\n                                \u003cspan class=\"text_38-2\"\u003estep 3\u003c\/span\u003e\n                                \u003cspan class=\"text_39-2\"\u003eSend Reminder\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_9-3 flex-col\"\u003e\n                                \u003cspan class=\"text_38-3\"\u003estep 4\u003c\/span\u003e\n                                \u003cspan class=\"text_39-3\"\u003eGenerate Report\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"group_11 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_17 flex-col\"\u003e\n                            \u003cspan class=\"text_67\"\u003eFLIR SDK Mobile Support\u003c\/span\u003e\n                            \u003cspan class=\"text_68\"\u003e Become a Developer and Create a Brand New App \u003c\/span\u003e\n                            \u003cspan class=\"paragraph_25\"\u003e With FLIR Mobile SDK (Software Development Kit), Developers can utilize FLIR\n                  interface to integrate thermal imaging or thermal sensing capabilities to their own apps. Convenient\n                  for further development by Android\/iOS users. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_4 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/d002a22ba067303bf5fd382d3002c370.webp\"\u003e\n                        \u003cdiv class=\"group_12 flex-col\"\u003e\n                \u003cspan class=\"paragraph_26\"\u003e Ready for Every Challenge — Thermal Imaging \u003cbr\u003e Tailored to Your Needs\n                \u003c\/span\u003e\n                            \u003cimg class=\"image_5 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/6abe7f85b7df65afbb52898f1719962f.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_32 flex-col\"\u003e\n                            \u003cspan class=\"text_85\"\u003e Medical \u0026amp; Biological Monitoring \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"image-wrapper_1 flex-row justify-between\"\u003e\n                            \u003cimg class=\"image_6 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/2d6b8a0ef38ddb047a3469b57a74d960.webp\"\u003e\n                            \u003cimg class=\"image_7 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/ff7ddd92810f0a467c0c0002f5019391.webp\"\u003e\n                            \u003cimg class=\"image_8 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/e97bd4bf4a925b073592acdb771ee8bb.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_23 flex-row\"\u003e\n                            \u003cspan class=\"text_69\"\u003eInfant \u0026amp; Child Care\u003c\/span\u003e\n                            \u003cspan class=\"text_70\"\u003eTemperature Screening\u003c\/span\u003e\n                            \u003cspan class=\"text_71\"\u003eLocal Inflammation Detection\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_24 flex-col\"\u003e\n                            \u003cspan class=\"text_72\"\u003e Industrial \u0026amp; Equipment Maintenance \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"image-wrapper_2 flex-row justify-between\"\u003e\n                            \u003cimg class=\"image_9 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a749c26259003a2b6da16808325be239.webp\"\u003e\n                            \u003cimg class=\"image_10 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/2b4d480936e09cd7e0f2b9cabedba464.webp\"\u003e\n                            \u003cimg class=\"image_11 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/94eff62f6422ab545133ed0775d3c76e.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_25 flex-row\"\u003e\n                            \u003cspan class=\"text_73\"\u003eElectrical Inspection\u003c\/span\u003e\n                            \u003cspan class=\"text_74\"\u003eMechanical Monitoring\u003c\/span\u003e\n                            \u003cspan class=\"paragraph_28\"\u003e Pipelines \u0026amp; \u003cbr\u003e Boilers leaks Identifying \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_26 flex-col\"\u003e\n                            \u003cspan class=\"text_75\"\u003e Building \u0026amp; Energy Management \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"image-wrapper_3 flex-row justify-between\"\u003e\n                            \u003cimg class=\"image_12 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/8f7d8ca6d4828781086f9b768a891bf4.webp\"\u003e\n                            \u003cimg class=\"image_13 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/cab9c54565e9e3787a6da9cf196878fe.webp\"\u003e\n                            \u003cimg class=\"image_14 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/c4e1649b00443604e9b41bedfe3c7091.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_27 flex-row justify-between\"\u003e\n                            \u003cspan class=\"text_76\"\u003eThermal Loss Detection\u003c\/span\u003e\n                            \u003cspan class=\"text_77\"\u003e HVAC \u0026amp; Pipes Monitoring \u003c\/span\u003e\n                            \u003cspan class=\"text_78\"\u003eSolar Panels Inspection\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_28 flex-col\"\u003e\n                            \u003cspan class=\"text_79\"\u003e Field Exploration \u0026amp; Wildlife Observation \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"image-wrapper_4 flex-row justify-between\"\u003e\n                            \u003cimg class=\"image_15 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/3ccae7f6b6fd7644d320e80e593eee7b.webp\"\u003e\n                            \u003cimg class=\"image_16 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a1c8923a9e80b469d4aaa014eedd7eaa.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_29 flex-row justify-between\"\u003e\n                            \u003cspan class=\"text_80\"\u003eWildlife Monitoring\u003c\/span\u003e\n                            \u003cspan class=\"text_81\"\u003e Energy \u0026amp; Geological Surveys \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_30 flex-col\"\u003e\n                            \u003cspan class=\"text_82\"\u003eSecurity \u0026amp; Safety\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"image-wrapper_5 flex-row justify-between\"\u003e\n                            \u003cimg class=\"image_17 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/11c2132f625a883e72dd85a498038db2.webp\"\u003e\n                            \u003cimg class=\"image_18 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/be22e2f1cfdac177366251888e96849f.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_31 flex-row justify-between\"\u003e\n                            \u003cspan class=\"text_83\"\u003eNight Surveillance\u003c\/span\u003e\n                            \u003cspan class=\"text_84\"\u003eFire Warning\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_13 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_18 flex-col justify-\"\u003e\n                  \u003cspan class=\"paragraph_29\"\u003e Industry-leading 2m for 30mins Water \u003cbr\u003e Resistance, 1.5m Death-broke\n                    Drop-proof, \u003cbr\u003e Protection, 6m Free-fall Durability \u003c\/span\u003e\n                                \u003cspan class=\"text_86\"\u003e Beyond the Limits, Conquer Every Extreme \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"group_5 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_5 flex-col\"\u003e\n                            \u003cspan class=\"text_40\"\u003e The Waterproof \u0026amp; Dustproof Benchmark \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_10 flex-col\"\u003e\n                            \u003cspan class=\"text_41\"\u003e Leading IP68 \u0026amp;IP69K \u0026amp; MIL-STD-810H Certified \u003c\/span\u003e\n                            \u003cspan class=\"text_42\"\u003e Weather Any Storm, Conquer Any Terrain \u003c\/span\u003e\n                            \u003cspan class=\"paragraph_7\"\u003e With leading IP68 and IP69K water and dust resistance, XPLORE 1 Pro is built\n                  to offer 360° protection against water and even the finest dust particles. Moreover, certified by the\n                  strict MIL-STD-810H standard, it effortlessly withstands accidental drops, intense shocks, or extreme\n                  temperature swings from ice to fire. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"group_6 flex-col\"\u003e\n                        \u003cdiv class=\"block_14 flex-col\"\u003e\n                            \u003cdiv class=\"group_7 flex-row justify-between\"\u003e\n                                \u003cspan class=\"text_50\"\u003e2m for 30mins\u003c\/span\u003e\n                                \u003cdiv class=\"text-wrapper_19\"\u003e\n                                    \u003cspan class=\"paragraph_21\"\u003e [Industry’s Only] \u003cbr\u003e \u003c\/span\u003e\n                                    \u003cspan class=\"text_51\"\u003e 1.5m Death-broke Drop-proofness \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cspan class=\"text_52\"\u003e2m for 30mins\u003c\/span\u003e\n                            \u003cdiv class=\"text-wrapper_20 flex-row\"\u003e\n                                \u003cspan class=\"text_53\"\u003ePeers\u003c\/span\u003e\n                                \u003cspan class=\"text_54\"\u003e1.5m for 30mins\u003c\/span\u003e\n                                \u003cspan class=\"text_55\"\u003ePeers\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_8 flex-row justify-between\"\u003e\n                                \u003cdiv class=\"image-text_1 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_12\"\u003e 33% Deeper Water Resistance \u003c\/span\u003e\n                                    \u003cimg class=\"label_1 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a3fb84d6ee886e769ffd5ef498119628.webp\"\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"image-text_2 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_13\"\u003e 25% Higher Drop Resistance \u003c\/span\u003e\n                                    \u003cimg class=\"label_2 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/84a156bcbc9caca10b55d0358ddea584.webp\"\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cspan class=\"paragraph_22\"\u003e *All data from Blackview Lab. \u003cbr\u003e Please note that real-world performance\n                  may vary. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_7 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"block_8 flex-col\"\u003e\n                                \u003cspan class=\"text_43\"\u003eGlove Mode 2.0\u003c\/span\u003e\n                                \u003cdiv class=\"block_9 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text_44\"\u003e8%\u003c\/span\u003e\n                                    \u003cimg class=\"image_2 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/704864291b6136f8011eabafc7f78c24.webp\"\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"paragraph_8\"\u003e Increased \u003cbr\u003e Touch \u003cbr\u003e Sensitivity \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_6 flex-col\"\u003e\n                                \u003cspan class=\"text_45\"\u003eUnderwater Camera\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_7 flex-col\"\u003e\n                            \u003cspan class=\"text_46\"\u003e All-round Defense, All-round Toughness \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_9\"\u003e 360° Water-, Dust-, and Drop-resistance, \u003cbr\u003e Every Chosen Material, Rigorously\n                Tested and Proven, \u003cbr\u003e Fearless of Any Challenge \u003c\/span\u003e\n                        \u003cdiv class=\"block_10 flex-row\"\u003e\n                            \u003cdiv class=\"text-wrapper_8 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_10\"\u003e Finely woven, small- \u003cbr\u003e aperture earpiece mesh \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_2 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_11 flex-col justify-\"\u003e\n                                    \u003cspan class=\"text_47\"\u003e[Industry's Only]\u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_11\"\u003e Dual-Layer Sealed USB Port \u003cbr\u003e Waterproof Even Without the Plug \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_9 flex-col\"\u003e\n                                \u003cspan class=\"text_48\"\u003eRaised Impact Corner\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_11 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_10 flex-col\"\u003e\n                  \u003cspan class=\"paragraph_12\"\u003e High-quality silicone waterproof rings for \u003cbr\u003e camera and side buttons\n                  \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_11 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_13\"\u003e Corning® Gorilla Glass® \u003cbr\u003e 5 Screen \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_12 flex-row\"\u003e\n                            \u003cdiv class=\"text-wrapper_12 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_14\"\u003e Partial Aerospace-grade \u003cbr\u003e Aluminum Alloy Shell \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_13 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_15\"\u003e 6m Free-fall Drop, \u003cbr\u003e Unscratched \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_14 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_16\"\u003e Withstand up to \u003cbr\u003e 500kg of Pressure \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_13 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_15 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_17\"\u003e Tumble Test \u003cbr\u003e 5000+ Times \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_16 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_18\"\u003e Mini Drop Test \u003cbr\u003e 10,000+ Times \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_3 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_17\"\u003e\n                                    \u003cspan class=\"paragraph_19\"\u003e Multi-angle Drop Test \u003cbr\u003e \u003c\/span\u003e\n                                    \u003cspan class=\"text_49\"\u003e1000+ Times\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_18 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_20\"\u003e HB Flame Retardant \u003cbr\u003e Certification \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"group_9 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_14 flex-col justify-between\"\u003e\n                            \u003cspan class=\"paragraph_23\"\u003e Super-bright \u003cbr\u003e Dual LED Flashlights \u003c\/span\u003e\n                            \u003cspan class=\"text_56\"\u003e Light up Your Way, Stay Safer All the Way \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_24\"\u003e Provide an expansive beam, lighting up your way ahead when you need most to\n                redefine clarity and safety in the toughest environments, from night field work or hikes to outdoor\n                emergencies and \u003cbr\u003e rescues in the deep dark. \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"group_10 flex-col\"\u003e\n                        \u003cdiv class=\"box_4 flex-row\"\u003e\n                            \u003cdiv class=\"text-wrapper_21 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_57\"\u003e170-lumen\u003c\/span\u003e\n                                \u003cspan class=\"text_58\"\u003eMax Brightness\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_15 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_59\"\u003eUp to 18 Meters\u003c\/span\u003e\n                                \u003cspan class=\"text_60\"\u003eMax Beam Range\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_16 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_61\"\u003eUp to 45hrs\u003c\/span\u003e\n                                \u003cspan class=\"text_62\"\u003eProlonged Runtime\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_22 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_63\"\u003eSOS Mode\u003c\/span\u003e\n                                \u003cspan class=\"text_64\"\u003eIncreased Safety↑\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"grid_1 flex-row\"\u003e\n                            \u003cdiv class=\"list-items_1-0 flex-col\"\u003e\n                                \u003cimg class=\"image_3-0 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/1b1222980e611b2e022db2c577cd6f85.webp\"\u003e\n                                \u003cspan class=\"text_66-0\"\u003e Detect Dangerous Creatures in Advance \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-1 flex-col\"\u003e\n                                \u003cimg class=\"image_3-1 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/70c455b42d8c0a3292879c197d30281f.webp\"\u003e\n                                \u003cspan class=\"text_66-1\"\u003e Avoid Stepping into Pits and Traps \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-2 flex-col\"\u003e\n                                \u003cimg class=\"image_3-2 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/d3ece386251a7a7b37cd893b6a6f0479.webp\"\u003e\n                                \u003cspan class=\"text_65-2\"\u003e Use SOS Mode in \u003cbr\u003e Emergencies to Get Yourself Spotted \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-3 flex-col\"\u003e\n                                \u003cimg class=\"image_3-3 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/56f55753cb3144b146294015508b6560.webp\"\u003e\n                                \u003cspan class=\"text_65-3\"\u003e Help Night-shift \u003cbr\u003e Workers Perform Tasks More Accurately \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n        \u003c\/section\u003e\n        \u003csection id=\"section-3\" class=\"se\"\u003e\n            \u003cdiv class=\"page flex-col\"\u003e\n                \u003cdiv class=\"box_1 flex-col\"\u003e\n                    \u003cdiv class=\"section_1 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_1 flex-col\"\u003e\n                            \u003cspan class=\"text_1\"\u003e New Benchmark in All-in-One Control \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_2\"\u003e Advanced Infrared Remote Control \u003c\/span\u003e\n                        \u003cspan class=\"text_3\"\u003e Your Phone, Your Universal Remote \u003c\/span\u003e\n                        \u003cspan class=\"text_4\"\u003e With an advanced Infrared Remote Control feature built-in, XPLORE 1 Pro transforms\n                into your pocket universal remote, allowing you to command everything while bringing endless convenience\n                to your adventures and daily life. \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_22 flex-col\"\u003e\n              \u003cspan class=\"paragraph_20\"\u003e All-in-one remote for almost any \u003cbr\u003e device that uses an IR remote, including\n              \u003c\/span\u003e\n                        \u003cdiv class=\"grid_3 flex-row\"\u003e\n                            \u003cdiv class=\"list-items_1-0 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-0 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/5f6932b66af5fa8b5958f3b0e4cde6b0.webp\"\u003e\n                                \u003cspan class=\"text_71-0\"\u003eTV\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-1 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-1 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/24f92fa143f7fe45f27b66b67cb170c3.webp\"\u003e\n                                \u003cspan class=\"text_71-1\"\u003eAir conditioner\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-2 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-2 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/cf4ed16e03d5b5849cc3099bc70ab325.webp\"\u003e\n                                \u003cspan class=\"text_71-2\"\u003eSet-top box\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-3 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-3 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/fcc66323dd1354fbd2d9b146619980ba.webp\"\u003e\n                                \u003cspan class=\"text_71-3\"\u003eDVD player\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-4 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-4 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/0b6108b3ac7d721a75ef4e3eba7a3a12.webp\"\u003e\n                                \u003cspan class=\"text_71-4\"\u003eProjector\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-5 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-5 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/42aa72aed08b0dfe03498763790be1f6.webp\"\u003e\n                                \u003cspan class=\"text_71-5\"\u003eFan\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-6 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-6 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/ed3ec626c618d9625c6f2535a7828a52.webp\"\u003e\n                                \u003cspan class=\"text_71-6\"\u003eIR-controlled lighting\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_1-7 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_9-7 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/e5b0037ddbff3486fa94a19f2a415964.webp\"\u003e\n                                \u003cspan class=\"text_71-7\"\u003eOthers\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_24 flex-col\"\u003e\n                \u003cspan class=\"paragraph_21\"\u003e 6.78-inch 2.4K 120Hz Eye-care Display, \u003cbr\u003e Immersive Visual Experience from\n                  Every Detail \u003c\/span\u003e\n                            \u003cspan class=\"text_72\"\u003e Dual Screens, Doubled Efficiency \u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_2 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_2 flex-col\"\u003e\n                            \u003cspan class=\"text_5\"\u003eKing of Immersive Visuals\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_1 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_6\"\u003e 6.78-inch 2.4K 120Hz Immersive Display \u003c\/span\u003e\n                            \u003cspan class=\"text_7\"\u003e Crystal-clear Detail, Boundless Vision \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_8\"\u003e The 6.78-inch 2.4K 120Hz screen on XPLORE 1 Pro offers you a large visual space\n                where details pop and colors come alive. Movies or games, fully immerse yourself in the content with\n                unparalleled clarity. \u003c\/span\u003e\n                        \u003cdiv class=\"grid_1 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_2-0 flex-col\"\u003e\n                                \u003cspan class=\"text_9-0\"\u003e1080*2460\u003c\/span\u003e\n                                \u003cspan class=\"text_10-0\"\u003eResolution\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_2-1 flex-col\"\u003e\n                                \u003cspan class=\"text_9-1\"\u003e86%\u003c\/span\u003e\n                                \u003cspan class=\"text_10-1\"\u003eScreen-to-body Ratio\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_2-2 flex-col\"\u003e\n                                \u003cspan class=\"text_9-2\"\u003e120Hz\u003c\/span\u003e\n                                \u003cspan class=\"text_10-2\"\u003eDynamic Refresh Rate\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_2-3 flex-col\"\u003e\n                                \u003cspan class=\"text_9-3\"\u003e700 Nits\u003c\/span\u003e\n                                \u003cspan class=\"text_10-3\"\u003eBrightness\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_2-4 flex-col\"\u003e\n                                \u003cspan class=\"text_9-4\"\u003eFHD+ IPS\u003c\/span\u003e\n                                \u003cspan class=\"text_10-4\"\u003ePanel Type\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_2-5 flex-col\"\u003e\n                                \u003cspan class=\"text_9-5\"\u003e240Hz\u003c\/span\u003e\n                                \u003cspan class=\"text_10-5\"\u003eTouch Sampling Rate\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_3 flex-col\"\u003e\n                        \u003cdiv class=\"group_1 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_3 flex-col\"\u003e\n                                \u003cspan class=\"text_11\"\u003e Authoritatively Certified, Better Eye Comfort \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cspan class=\"text_12\"\u003e TÜV SÜD Low Blue Light Certification \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_2 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"section_4 flex-col\"\u003e\n                                \u003cdiv class=\"section_5 flex-row\"\u003e\n                                    \u003cdiv class=\"text-wrapper_4 flex-col\"\u003e\n                                        \u003cspan class=\"text_13\"\u003ePeers\u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"section_6 flex-row\"\u003e\n                                    \u003cdiv class=\"image-text_1 flex-row justify-between\"\u003e\n                                        \u003cspan class=\"text-group_3\"\u003e1.5x Clearer\u003c\/span\u003e\n                                        \u003cimg class=\"image_1 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/5c99545471f81af269ddabba610ce98c.webp\"\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"section_7 flex-row\"\u003e\n                                \u003cdiv class=\"image-text_2 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_4\"\u003e More Silk-smooth Scrolling \u003c\/span\u003e\n                                    \u003cdiv class=\"group_3 flex-col\"\u003e\u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_8 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_5 flex-col\"\u003e\n                            \u003cspan class=\"text_14\"\u003e Industry's Premier Tool for Multi-Tasking \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_15\"\u003eSeamless Split Screen\u003c\/span\u003e\n                        \u003cspan class=\"text_16\"\u003e Double the Apps, Double the Productivity \u003c\/span\u003e\n                        \u003cspan class=\"text_17\"\u003e Stop switching back and forth between apps. Watch videos while chatting, compare\n                notes while browsing—Split Screen keeps you productive and entertained without missing a beat. \u003c\/span\u003e\n                        \u003cimg class=\"image_2 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/72ebc87c44de9cb773d6a31a9d023c96.webp\"\u003e\n                        \u003cimg class=\"image_3 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/146e4c4a0f182fb37ddda818bf01f349.webp\"\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_9 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_6 flex-col\"\u003e\n                            \u003cspan class=\"text_18\"\u003e Industry’s Pioneer in Sub-Screen \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_19\"\u003e Multi-functional 2.01-inch Sub-screen \u003c\/span\u003e\n                        \u003cspan class=\"text_20\"\u003e All You Need, At a Glance \u003c\/span\u003e\n                        \u003cspan class=\"paragraph_1\"\u003e With a secondary screen on the rear of XPLORE 1 Pro, you can acquire key\n                information and notifications without having to access the main screen. Besides, there are multiple\n                watch faces for you to personalize your style. \u003c\/span\u003e\n                        \u003cdiv class=\"group_4 flex-col\"\u003e\n                            \u003cdiv class=\"list_1 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_5-0 flex-col\"\u003e\n                                    \u003cspan class=\"text_21-0\"\u003e2.01-inch\u003c\/span\u003e\n                                    \u003cspan class=\"text_22-0\"\u003eSize\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-group_5-1 flex-col\"\u003e\n                                    \u003cspan class=\"text_21-1\"\u003e240*296\u003c\/span\u003e\n                                    \u003cspan class=\"text_22-1\"\u003eResolution\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-group_5-2 flex-col\"\u003e\n                                    \u003cspan class=\"text_21-2\"\u003ePanda Glass\u003c\/span\u003e\n                                    \u003cspan class=\"text_22-2\"\u003eMaterial\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_2\"\u003e Stay Covered, Stay Connected \u003cbr\u003e Everything You Need, Right on Your Sub-screen\n              \u003c\/span\u003e\n                        \u003cdiv class=\"group_5 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_7 flex-col\"\u003e\n                                \u003cspan class=\"text_23\"\u003eCheck the Time\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_8 flex-col\"\u003e\n                                \u003cspan class=\"text_24\"\u003ePlay\/Pause\/Skip Tracks\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_9 flex-col\"\u003e\n                                \u003cspan class=\"text_25\"\u003eAccept\/Decline Calls\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_6 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_10 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_3\"\u003e Check Notifications \u003cbr\u003e \u0026amp; Alerts \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_11 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_4\"\u003e Quickly Check the \u003cbr\u003e Weather \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_12 flex-col\"\u003e\n                                \u003cspan class=\"text_26\"\u003eMonitor Your Steps\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_7 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_13 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_5\"\u003e Find Way with the \u003cbr\u003e Compass \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_14 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_6\"\u003e Quicker \u003cbr\u003e and Easier Selfies \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_15 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_7\"\u003e Personalize \u003cbr\u003e Your Watch Faces \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_4 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a4bc167ee1d92efc8815dfbc52434ffb.webp\"\u003e\n                        \u003cimg class=\"image_5 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/459462f561553e976f1112a41409dad7.webp\"\u003e\n                        \u003cimg class=\"image_6 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/f3e091fe142b5910cab404a2baad7c20.webp\"\u003e\n                        \u003cimg class=\"image_7 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/82397b9b5d8d6f0b2a0b74bf85290cd8.webp\"\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_10 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_6 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_27\"\u003eSmart-K Box Speaker\u003c\/span\u003e\n                            \u003cspan class=\"text_28\"\u003e Immerse in Sound, Ignite Your Senses \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_29\"\u003e The Smart-K Box speaker on XPLORE 1 Pro allows you to feel the rhythm, feel the\n                power, and dive into a world where every beat and melody comes alive with unparalleled clarity and\n                intensity. \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"text-wrapper_16 flex-col\"\u003e\n              \u003cspan class=\"paragraph_8\"\u003e 20,000mAh Battery Beast, Robust \u003cbr\u003e for Any Adventure Power Beyond Limits,\n                \u003cbr\u003e Charge Quicker than Ever \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_23 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_25 flex-col\"\u003e\n                            \u003cspan class=\"text_73\"\u003eIndustry’s Power Peak\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_13 flex-col\"\u003e\n                            \u003cspan class=\"text_74\"\u003e20,000mAh Battery Beast\u003c\/span\u003e\n                            \u003cspan class=\"text_75\"\u003e Power Reigns, Go Further, Conquer All \u003c\/span\u003e\n                            \u003cspan class=\"text_76\"\u003e Keep you connected, powered up, and ready for anything, no matter where life\n                  takes you. Once fully charged, you can enjoy 1008 hours on standby. Power never runs out, and your\n                  adventurous expeditions will never cease. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_9 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_14 flex-col justify-between\"\u003e\n                                \u003cspan class=\"text_77\"\u003e1=4\u003c\/span\u003e\n                                \u003cspan class=\"paragraph_22\"\u003e 20,000mAh mega battery \u003cbr\u003e ≈ 4x mobiles of regular battery capacity\n                  \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_11 flex-col\"\u003e\n                        \u003cdiv class=\"box_2 flex-col\"\u003e\n                            \u003cdiv class=\"list_2 flex-row\"\u003e\n                                \u003cdiv class=\"text-wrapper_17-0 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_30-0\"\u003eVideo\u003c\/span\u003e\n                                    \u003cspan class=\"text_31-0\"\u003e23hrs\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_17-1 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_30-1\"\u003eGame\u003c\/span\u003e\n                                    \u003cspan class=\"text_31-1\"\u003e20hrs\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_17-2 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_30-2\"\u003eWeb\u003c\/span\u003e\n                                    \u003cspan class=\"text_31-2\"\u003e38hrs\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_17-3 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_30-3\"\u003eMusic\u003c\/span\u003e\n                                    \u003cspan class=\"text_31-3\"\u003e58hrs\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_17-4 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_30-4\"\u003eCalling\u003c\/span\u003e\n                                    \u003cspan class=\"text_31-4\"\u003e84hrs\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_17-5 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_30-5\"\u003eStandby\u003c\/span\u003e\n                                    \u003cspan class=\"text_31-5\"\u003e1008hrs\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_32\"\u003e *Data tested by Blackview Lab. Actual use may vary depending on usage and\n                environmental conditions. \u003c\/span\u003e\n                        \u003cdiv class=\"grid_2 flex-row\"\u003e\n                            \u003cdiv class=\"text-wrapper_18 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_9\"\u003e Focus \u003cbr\u003e Computing 2.0 \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"section_12 flex-col\"\u003e\n                                \u003cspan class=\"text_33\"\u003ePerformance Mode\u003c\/span\u003e\n                                \u003cdiv class=\"block_1 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text_34\"\u003e10%\u003c\/span\u003e\n                                    \u003cdiv class=\"box_3 flex-col\"\u003e\u003c\/div\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"text_35\"\u003eBetter CPU Performance\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"section_13 flex-col\"\u003e\n                                \u003cspan class=\"text_36\"\u003ePower Saving Mode\u003c\/span\u003e\n                                \u003cdiv class=\"group_8 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text_37\"\u003e4hrs\u003c\/span\u003e\n                                    \u003cdiv class=\"block_2 flex-col\"\u003e\u003c\/div\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"text_38\"\u003eLonger Daily Use\u003c\/span\u003e\n                                \u003cspan class=\"text_39\"\u003e AI Super Power-Saving Algorithm \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"section_14 flex-col\"\u003e\n                                \u003cdiv class=\"image-text_3 flex-col justify-between\"\u003e\n                                    \u003cdiv class=\"text-group_7 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"paragraph_10\"\u003e Intelligent Charging \u003cbr\u003e Protection \u003c\/span\u003e\n                                        \u003cspan class=\"text_40\"\u003eExtended Battery Life\u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                    \u003cdiv class=\"section_15 flex-col\"\u003e\u003c\/div\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"paragraph_11\"\u003e AI Smart Charging \u003cbr\u003e Protection Algorithm \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_24 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_15 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_78\"\u003e55W Fast Charging\u003c\/span\u003e\n                            \u003cspan class=\"text_79\"\u003e No More Waiting, Power up Faster \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_80\"\u003e Go from empty to full in less time with XPLORE 1 Pro’s 55W fast charging. Whether\n                it’s a quick lunch break, a brief rest, or a transition between tasks, just a few moments of charging\n                inject massive power into your ultra-large battery. \u003c\/span\u003e\n                        \u003cspan class=\"paragraph_23\"\u003e * The charging dock isn’t included. Opt for the charging dock for \u003cbr\u003e a\n                seamless power-up experience. \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_16 flex-col\"\u003e\n                        \u003cdiv class=\"box_4 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_19 flex-col\"\u003e\n                                \u003cspan class=\"text_41\"\u003e55W\u003c\/span\u003e\n                                \u003cspan class=\"paragraph_12\"\u003e Wired Fast \u003cbr\u003e Charging \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_20 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_13\"\u003e Class-Leading Speed \u003cbr\u003e Dock Charging \u003c\/span\u003e\n                                \u003cspan class=\"text_42\"\u003e45W\u003c\/span\u003e\n                                \u003cspan class=\"paragraph_14\"\u003e Wireless \u003cbr\u003e Charging Dock \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_17 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_8 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_43\"\u003e5W Reverse Charging\u003c\/span\u003e\n                            \u003cspan class=\"text_44\"\u003e Share Power, Always Ready \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_15\"\u003e XPLORE 1 Pro is more than a rugged phone; it’s a portable power bank as well,\n                ready to recharge your other devices, from earbuds to smartwatches, ensuring you stay connected and\n                entertained on and on. \u003c\/span\u003e\n                        \u003cdiv class=\"group_9 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_21 flex-row\"\u003e\n                                \u003cspan class=\"text_45\"\u003eTWS Earphone\u003c\/span\u003e\n                                \u003cspan class=\"text_46\"\u003eIQOS\u003c\/span\u003e\n                                \u003cspan class=\"text_47\"\u003eMobile Phone\u003c\/span\u003e\n                                \u003cspan class=\"text_48\"\u003eDigital Camera\u003c\/span\u003e\n                                \u003cspan class=\"text_49\"\u003eSmart Watch\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_22 flex-row\"\u003e\n                                \u003cspan class=\"text_50\"\u003eSwitch\u003c\/span\u003e\n                                \u003cspan class=\"text_51\"\u003eTablet\u003c\/span\u003e\n                                \u003cspan class=\"text_52\"\u003eMini Speaker\u003c\/span\u003e\n                                \u003cspan class=\"text_53\"\u003eUSB Fan\u003c\/span\u003e\n                                \u003cspan class=\"text_54\"\u003eCamping Light\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"text-wrapper_26 flex-col\"\u003e\n              \u003cspan class=\"paragraph_24\"\u003e Peak Speed with 6nm 5G Dimensity 7050 AI Soc, \u003cbr\u003e Ready for Everything You Do\n                \u003cbr\u003e Power Through Tasks, Speed Through Games \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_25 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_27 flex-col\"\u003e\n                            \u003cspan class=\"text_81\"\u003e The Performance Iron Triangle \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_16 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_82\"\u003e 6nm 5G MediaTek Dimensity 7050 \u003c\/span\u003e\n                            \u003cspan class=\"text_83\"\u003eSmoother, Faster, Stronger\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_84\"\u003e Featuring the octa-core 5G MediaTek Dimensity 7050, XPLORE 1 Pro unleashes\n                lightning-fast speeds. From seamless multitasking, instant app launches, and breathtaking graphics, all\n                in the palm of your hand. \u003c\/span\u003e\n                        \u003cdiv class=\"group_11 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_28 flex-row\"\u003e\n                                \u003cspan class=\"text_85\"\u003e6nm EUV Process\u003c\/span\u003e\n                                \u003cspan class=\"text_86\"\u003e 5G Dual Carrier Aggregation \u003c\/span\u003e\n                                \u003cspan class=\"paragraph_25\"\u003e MediaTek NPU 550 AI \u003cbr\u003e Accelerator \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_12 flex-row\"\u003e\n                                \u003cdiv class=\"image-text_4 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_17\"\u003e More Powerful Computing \u0026amp; \u003cbr\u003e Higher Efficiency \u003c\/span\u003e\n                                    \u003cimg class=\"image_10 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a476e0673379c12f99b9651b06192cfa.webp\"\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"image-text_5 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_18\"\u003e Faster Network Speeds \u003cbr\u003e \u0026amp; Wider Coverage \u003c\/span\u003e\n                                    \u003cimg class=\"image_11 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/38d880bc85d9e26ebe1eb38300e1f600.webp\"\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"image-text_6 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_19\"\u003e Faster and More \u003cbr\u003e Energy-saving AI Features \u003c\/span\u003e\n                                    \u003cimg class=\"image_12 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/4c976c3b6c1b95f072b25cc352c36813.webp\"\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_29 flex-row\"\u003e\n                                \u003cspan class=\"paragraph_26\"\u003e 2*A78@2.4GHz+ \u003cbr\u003e 6*A55@2.0GHz \u003c\/span\u003e\n                                \u003cspan class=\"text_87\"\u003e UP to 2.4GHz Clock Speed \u003c\/span\u003e\n                                \u003cspan class=\"text_88\"\u003eARM Mali-G68 MC4\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_18 flex-col\"\u003e\n                        \u003cdiv class=\"box_5 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_23 flex-col\"\u003e\n                                \u003cspan class=\"text_55\"\u003eHyperEngine Tech 2.0\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_6 flex-col justify-between\"\u003e\n                                \u003cdiv class=\"block_3 flex-col\"\u003e\n                                    \u003cspan class=\"paragraph_16\"\u003e 2.4+5GHz \u003cbr\u003e Dual-band \u003cbr\u003e WiFi 6 \u003c\/span\u003e\n                                    \u003cdiv class=\"box_7 flex-row justify-\"\u003e\n                                        \u003cspan class=\"text_56\"\u003e3x\u003c\/span\u003e\n                                        \u003cdiv class=\"box_8 flex-col\"\u003e\u003c\/div\u003e\n                                    \u003c\/div\u003e\n                                    \u003cspan class=\"paragraph_17\"\u003e Faster than \u003cbr\u003e WiFi 5 Tech \u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"block_4 flex-col\"\u003e\n                                    \u003cspan class=\"text_57\"\u003eAnTuTu Benchmark\u003c\/span\u003e\n                                    \u003cdiv class=\"text-group_9 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"text_58\"\u003e601,430+\u003c\/span\u003e\n                                        \u003cspan class=\"text_59\"\u003e(V10.5.1）\u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_19 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_10 flex-col justify-between\"\u003e\n                            \u003cspan class=\"paragraph_18\"\u003e Up to 48GB RAM+512GB ROM + \u003cbr\u003e Up to 2TB TF Expansion \u003c\/span\u003e\n                            \u003cspan class=\"text_60\"\u003e Power Through Anything, Store Everything \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_19\"\u003e Experience unparalleled speed with up to 48GB RAM, enabling you to juggle\n                countless apps, heavy games, and demanding tasks without a hitch. Coupled with a massive 512GB ROM and\n                2TB TF expansion, you’ll have ample room for all your photos, videos, files, and more. \u003c\/span\u003e\n                        \u003cdiv class=\"section_20 flex-col\"\u003e\n                            \u003cspan class=\"text_61\"\u003eAtomized Memory 2.0\u003c\/span\u003e\n                            \u003cdiv class=\"group_10 flex-row justify-between\"\u003e\n                                \u003cspan class=\"text_62\"\u003e9%\u003c\/span\u003e\n                                \u003cimg class=\"image_8 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/62650a3fa1eae61561befb7b1d627622.webp\"\u003e\n                            \u003c\/div\u003e\n                            \u003cspan class=\"text_63\"\u003eMore RAM Available\u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_26 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_30 flex-col\"\u003e\n                            \u003cspan class=\"text_89\"\u003eLPDDR5 + UFS4.0\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_90\"\u003e1TB More TF Expansion\u003c\/span\u003e\n                        \u003cdiv class=\"list_3 flex-row\"\u003e\n                            \u003cdiv class=\"list-items_2-0 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_31-0 flex-col\"\u003e\n                                    \u003cspan class=\"text_91-0\"\u003e≈221.6K+\u003c\/span\u003e\n                                    \u003cspan class=\"text_92-0\"\u003eMore Photos\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_2-1 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_31-1 flex-col\"\u003e\n                                    \u003cspan class=\"text_91-1\"\u003e≈26.4K+\u003c\/span\u003e\n                                    \u003cspan class=\"text_92-1\"\u003eMore Short Videos\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list-items_2-2 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_31-2 flex-col\"\u003e\n                                    \u003cspan class=\"text_91-2\"\u003e ≈400K+ \u003cbr\u003e \u003c\/span\u003e\n                                    \u003cspan class=\"text_92-2\"\u003eMore Songs\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_20 flex-col\"\u003e\n                            \u003cspan class=\"text_93\"\u003e 5,480mm² Integrated Cooling System \u003c\/span\u003e\n                            \u003cspan class=\"text_94\"\u003eStay Cool, Stay Ahead\u003c\/span\u003e\n                            \u003cspan class=\"text_95\"\u003e Boasting a 5,480mm² heat dissipation area, XPLORE 1 Pro can stay cool and\n                  maintain optimal performance, even during marathon sessions. No more overheating, just pure\n                  performance. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_13 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_32\"\u003e\n                                \u003cspan class=\"paragraph_27\"\u003e Up to 48GB RAM= \u003cbr\u003e \u003c\/span\u003e\n                                \u003cspan class=\"text_96\"\u003e 16GB RAM + 32GB Expansion \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"block_5 flex-row\"\u003e\n                                \u003cspan class=\"text_97\"\u003e35%\u003c\/span\u003e\n                                \u003cimg class=\"image_13 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/499f2e2ef639b4b1b07607238bcdabcc.webp\"\u003e\n                                \u003cspan class=\"text_98\"\u003eFaster Response Speed\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"section_21 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_11 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_64\"\u003eCopper Foil\u003c\/span\u003e\n                            \u003cspan class=\"text_65\"\u003e900mm²\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_12 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_66\"\u003eGraphite Sheet\u003c\/span\u003e\n                            \u003cspan class=\"text_67\"\u003e4,400mm²\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_68\"\u003eThermal Silicone\u003c\/span\u003e\n                        \u003cspan class=\"text_69\"\u003e180mm²\u003c\/span\u003e\n                        \u003cspan class=\"text_70\"\u003e Peak Temperature at 38℃ under CPU-intensive Games \u003c\/span\u003e\n                    \u003c\/div\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n        \u003c\/section\u003e\n        \u003csection id=\"section-4\" class=\"se\"\u003e\n            \u003cdiv class=\"page flex-col\"\u003e\n                \u003cdiv class=\"group_1 flex-col\"\u003e\n                    \u003cdiv class=\"text-wrapper_27 flex-col\"\u003e\n              \u003cspan class=\"paragraph_17\"\u003e 64MP Main \u0026amp; 50MP Selfie \u0026amp; Clearest Thermal Camera \u003cbr\u003e Every Moment,\n                Vividly Captured \u003c\/span\u003e\n                        \u003cspan class=\"text_52\"\u003e From True Color to True Heat \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_1 flex-col\"\u003e\n                        \u003cdiv class=\"group_2 flex-row\"\u003e\n                            \u003cdiv class=\"text-wrapper_1 flex-col\"\u003e\n                                \u003cspan class=\"text_1\"\u003eFlagship Imaging System\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_2 flex-row\"\u003e\n                            \u003cspan class=\"paragraph_1\"\u003e Triple-camera Setup \u003cbr\u003e All Scenes, All Mastered \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_3 flex-row\"\u003e\n                            \u003cspan class=\"text_2\"\u003eMain Camera\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_4 flex-row\"\u003e\n                            \u003cspan class=\"paragraph_2\"\u003e 64MP \u003cbr\u003e (f\/1.79)1\/2″ \u003cbr\u003e 6P \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_5 flex-row\"\u003e\n                            \u003cspan class=\"text_3\"\u003eThermal Camera\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_6 flex-row\"\u003e\n                            \u003cspan class=\"text_4\"\u003eFront Camera\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_7 flex-row\"\u003e\n                            \u003cspan class=\"paragraph_3\"\u003e 50MP \u003cbr\u003e Samsung® JN1 \u003cbr\u003e (f\/1.8)1\/2.76″ \u003cbr\u003e 5P \u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_2 flex-col\"\u003e\n                        \u003cspan class=\"text_5\"\u003e64MP Main Camera\u003c\/span\u003e\n                        \u003cspan class=\"text_6\"\u003e Day or Night, Shine So Bright \u003c\/span\u003e\n                        \u003cspan class=\"paragraph_4\"\u003e The 64MP main camera on XPLORE 1 Pro can capture every epic moment, day or\n                night, transforming every shot into a masterpiece, regardless of the conditions. Each photo, seemingly\n                still, is vividly alive. \u003cbr\u003e \u003c\/span\u003e\n                        \u003cdiv class=\"list_1 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_1-0 flex-col\"\u003e\n                                \u003cspan class=\"text_7-0\"\u003e4-in-1 to 1.4μm\u003c\/span\u003e\n                                \u003cspan class=\"text_9-0\"\u003eSuper Pixels\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_1-1 flex-col\"\u003e\n                                \u003cspan class=\"text_8-1\"\u003e1\/2\"\u003c\/span\u003e\n                                \u003cspan class=\"text_9-1\"\u003ePixel Sensor Size\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_1-2 flex-col\"\u003e\n                                \u003cspan class=\"text_8-2\"\u003e6P\u003c\/span\u003e\n                                \u003cspan class=\"text_9-2\"\u003eUltra Clear Lens\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_1-3 flex-col\"\u003e\n                                \u003cspan class=\"text_8-3\"\u003ef\/1.79\u003c\/span\u003e\n                                \u003cspan class=\"text_9-3\"\u003eLarge Aperture\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_8 flex-col\"\u003e\n                            \u003cspan class=\"text_10\"\u003eClass -Only\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_9\"\u003e\n                            \u003cspan class=\"text_11\"\u003e8x\u003c\/span\u003e\n                            \u003cspan class=\"text_12\"\u003e Optical Zoom\u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_3 flex-col\"\u003e\n                        \u003cdiv class=\"image-wrapper_1 flex-row justify-between\"\u003e\n                            \u003cimg class=\"image_1 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/0cbf8f20d902784441a0f57fcd687c9e.webp\"\u003e\n                            \u003cimg class=\"image_2 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/aceab4cb6aaf1f7ce4828d4da13c6f87.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_13\"\u003e Capture Every Detail, Near or Far \u003c\/span\u003e\n                        \u003cimg class=\"image_3 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/eef30e7b4ae52b4a45aa0b54655f5ae8.webp\"\u003e\n                        \u003cdiv class=\"block_1 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"box_4 flex-col\"\u003e\n                                \u003cspan class=\"text_14\"\u003eQuad-Bayer Output\u003c\/span\u003e\n                                \u003cdiv class=\"image-text_1 flex-row justify-between\"\u003e\n                    \u003cspan class=\"text-group_2\"\u003e 4-in-1 to 1.4μm \u003cbr\u003e super pixel to enhance \u003cbr\u003e light sensitivity\n                    \u003c\/span\u003e\n                                    \u003cimg class=\"image_4 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/4fa860a5bd67091c581c9caf1829456e.webp\"\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_5 flex-col\"\u003e\n                                \u003cspan class=\"text_15\"\u003eColor Filter Array\u003c\/span\u003e\n                                \u003cdiv class=\"image-text_2 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_3\"\u003e Better Capture \u003cbr\u003e of Light and Color \u003cbr\u003e Information \u003c\/span\u003e\n                                    \u003cimg class=\"image_5 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/cfc64b52f1d17ee8bc23834eec87d684.webp\"\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_2 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"box_6 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_10 flex-row\"\u003e\n                                    \u003cspan class=\"text_16\"\u003ePDAF Tech\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"box_7 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"paragraph_5\"\u003e Faster and \u003cbr\u003e More Accurate \u003cbr\u003e Autofocus \u003c\/span\u003e\n                                    \u003cimg class=\"image_6 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/b35665312f2988c9d5a3580c04080dc7.webp\"\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_8 flex-row\"\u003e\n                                \u003cdiv class=\"image-text_3 flex-row justify-between\"\u003e\n                    \u003cspan class=\"text-group_4\"\u003e Smooth Exposure \u003cbr\u003e Control \u003cbr\u003e Seamless Brightness \u003cbr\u003e Transition\n                    \u003c\/span\u003e\n                                    \u003cimg class=\"image_7 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/d968830a4386d9efa68816b5a3e1d14a.webp\"\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_8 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/239ddad80143ea9a93b00d054232ad5c.webp\"\u003e\n                        \u003cimg class=\"image_9 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/426fbc5adc776f7799ab6f50adbfdbd9.webp\"\u003e\n                        \u003cdiv class=\"block_3 flex-col\"\u003e\n                            \u003cspan class=\"text_17\"\u003eOptical Zoom\u003c\/span\u003e\n                            \u003cdiv class=\"text-wrapper_11 flex-col\"\u003e\n                                \u003cspan class=\"text_18\"\u003eSharp and Clear\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_4 flex-col\"\u003e\n                            \u003cspan class=\"text_19\"\u003eDigital Zoom\u003c\/span\u003e\n                            \u003cdiv class=\"text-wrapper_12 flex-col\"\u003e\n                                \u003cspan class=\"text_20\"\u003ePixelated and Blurry\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_10 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/8b93ff13f2216985c668cad3e5aea2f7.webp\"\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_9 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_5 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_21\"\u003e 50MP Samsung® JN1 Selfie Shooter \u003c\/span\u003e\n                            \u003cspan class=\"text_22\"\u003e Every Detail, Frame Your Brilliance \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_6\"\u003e Equipped with a stunning 50MP front camera, XPLORE 1 Pro delivers sharper,\n                clearer selfies and crystal-clear video calls. From vlogging on the go to spontaneous video chats,\n                always \u003cbr\u003e present your best self with unparalleled clarity. \u003c\/span\u003e\n                        \u003cdiv class=\"box_10 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"box_11 flex-row justify-between\"\u003e\n                                \u003cdiv class=\"text-group_6 flex-col\"\u003e\n                                    \u003cspan class=\"text_23\"\u003eF\/1.8\u003c\/span\u003e\n                                    \u003cspan class=\"text_24\"\u003eLarge Aperture\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_13 flex-col\"\u003e\n                                    \u003cspan class=\"text_25\"\u003e5P\u003c\/span\u003e\n                                    \u003cspan class=\"text_26\"\u003eHigh Light Transmission\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-group_7 flex-col\"\u003e\n                                    \u003cspan class=\"text_27\"\u003e1\/2.76\"\u003c\/span\u003e\n                                    \u003cspan class=\"text_28\"\u003ePixel Sensor Size\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_12 flex-col\"\u003e\n                                \u003cdiv class=\"section_1 flex-row justify-center\"\u003e\n                                    \u003cspan class=\"text_29\"\u003e2x\u003c\/span\u003e\n                                    \u003cdiv class=\"section_2 flex-col\"\u003e\u003c\/div\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"text_30\"\u003eClearer Selfies\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_31\"\u003e 4K Crystal-clear Video Recording \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_24 flex-col\"\u003e\n                        \u003cspan class=\"text_53\"\u003e Relive Every Moment, In Lifelike Detail \u003c\/span\u003e\n                        \u003cspan class=\"paragraph_18\"\u003e Bring every laugh, every vibrant sunset, and every intricate detail of your\n                story to life in vivid 4K at 30fps, ensuring you can relive them with unparalleled clarity and realism,\n                just as they unfolded. \u003c\/span\u003e\n                        \u003cdiv class=\"block_5 flex-col\"\u003e\n                            \u003cdiv class=\"box_25 flex-row\"\u003e\n                                \u003cdiv class=\"text-wrapper_28 flex-col\"\u003e\n                                    \u003cspan class=\"text_54\"\u003ePeers\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_29 flex-row\"\u003e\n                                \u003cspan class=\"text_55\"\u003e2K\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_26 flex-row\"\u003e\n                                \u003cspan class=\"text_56\"\u003e4x Clearer\u003c\/span\u003e\n                                \u003cimg class=\"image_13 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/00589236887b9f005bc5a67d017ef121.webp\"\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_30 flex-col\"\u003e\n                            \u003cspan class=\"paragraph_19\"\u003e Smart Stabilization. \u003cbr\u003e Effortless Clarity \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_13 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_57\"\u003eTrue-Chroma Image 2.0\u003c\/span\u003e\n                            \u003cspan class=\"text_58\"\u003eSee True, Capture True\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_20\"\u003e Bring your photos to life with incredible color accuracy and richer details,\n                ensuring what you capture is as vivid and true-to-life as what you see, perfect for photography\n                enthusiasts and everyday users alike. \u003c\/span\u003e\n                        \u003cimg class=\"image_14 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/9ea69039cecec9bb6a6f4129b852f826.webp\"\u003e\n                        \u003cspan class=\"paragraph_21\"\u003e Smart Shooting Assistance \u003cbr\u003e Perfect Shoots, Easy Control \u003c\/span\u003e\n                        \u003cdiv class=\"text-wrapper_31 flex-col\"\u003e\n                            \u003cspan class=\"text_59\"\u003e Level Tool \u0026amp; Center Marker \u003c\/span\u003e\n                            \u003cspan class=\"text_60\"\u003e Steady Shots, Precise Focus \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"block_6 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_32 flex-col\"\u003e\n                                \u003cspan class=\"text_61\"\u003e3x3 Grid Lines\u003c\/span\u003e\n                                \u003cspan class=\"text_62\"\u003e Grid your way to perfect photos \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_33 flex-col\"\u003e\n                                \u003cspan class=\"text_63\"\u003eVibration Feedback\u003c\/span\u003e\n                                \u003cspan class=\"text_64\"\u003e Responsive Touch, Perfect Control \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_34 flex-col\"\u003e\n                \u003cspan class=\"paragraph_22\"\u003e Blackview x Doke AI 2.0, Speak to Control, \u003cbr\u003e Smarter to Operate Powered\n                  by DeepSeek-R1, \u003cbr\u003e ChatGPT, Gemini AI 2.0 Flash \u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_13 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_8 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_32\"\u003eUpgraded Doke AI\u003c\/span\u003e\n                            \u003cspan class=\"text_33\"\u003eHand-free Anytime, Anywhere\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_7\"\u003e Simply speak to wake XPLORE 1 Pro, keeping you effortlessly connected, in\n                control, and one step ahead. It’s your hands-free helper, instantly understanding and seamlessly\n                responding across all apps, screens, and situations. \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_14 flex-col\"\u003e\n                        \u003cdiv class=\"box_15 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_14 flex-col\"\u003e\n                                \u003cspan class=\"text_34\"\u003eAI Voice Wake-up\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_15 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_8\"\u003e AI Full-screen Smart \u003cbr\u003e Assistance \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_16 flex-col\"\u003e\n                            \u003cspan class=\"text_35\"\u003eAI Smart Global Control\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_16 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_17 flex-col\"\u003e\n                                \u003cspan class=\"text_36\"\u003e AI Smart Voice Interaction \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_18 flex-col\"\u003e\n                                \u003cspan class=\"text_37\"\u003eAI Real-time Conversation\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_17 flex-col\"\u003e\n                            \u003cspan class=\"text_38\"\u003eHi Doki APP\u003c\/span\u003e\n                            \u003cdiv class=\"text-group_9 flex-col justify-between\"\u003e\n                                \u003cspan class=\"paragraph_9\"\u003e Voice to Vision, \u003cbr\u003e Ideas Unleashed \u003c\/span\u003e\n                                \u003cspan class=\"paragraph_10\"\u003e Experience lightning-fast, \u003cbr\u003e deep-thinking AI search, effortless \u003cbr\u003e\n                    document analysis, and smart writing assistance, unlocking smarter insights and boundless creation.\n                  \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_18 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_19 flex-col\"\u003e\n                                \u003cspan class=\"text_39\"\u003eAI Text to Image\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_20 flex-col\"\u003e\n                                \u003cspan class=\"text_40\"\u003eAI Image to Image\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_19 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_21 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_11\"\u003e AI Music \u003cbr\u003e Composition \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_22 flex-col\"\u003e\n                                \u003cspan class=\"text_41\"\u003eAI Online Search\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_23 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_12\"\u003e AI Document \u003cbr\u003e Parsing \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"list_2 flex-row\"\u003e\n                            \u003cdiv class=\"text-wrapper_24-0 flex-col\"\u003e\n                                \u003cspan class=\"text_42-0\"\u003e Smart Q\u0026amp;A with \u003cbr\u003e DeepSeek-R1 \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_24-1 flex-col\"\u003e\n                                \u003cspan class=\"text_42-1\"\u003e AI Tutoring \u003cbr\u003e Assistant \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_24-2 flex-col\"\u003e\n                                \u003cspan class=\"text_42-2\"\u003eAI Role Chat\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_20 flex-col\"\u003e\n                            \u003cspan class=\"text_43\"\u003eImageX App\u003c\/span\u003e\n                            \u003cdiv class=\"text-group_10 flex-col justify-between\"\u003e\n                                \u003cspan class=\"paragraph_13\"\u003e From Novice to Pro, \u003cbr\u003e Make Every Post Go Viral \u003c\/span\u003e\n                                \u003cspan class=\"text_44\"\u003e Boasting up to 18 powerful AI editing tools, it allows you to easily edit your\n                    photos and make every post of yours shine with new life and instantly go viral! \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_11 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/6e67e8fe42eac57f554bef175ddbd741.webp\"\u003e\n                        \u003cspan class=\"text_45\"\u003e Up to 18 Powerful Image Editing Tools \u003c\/span\u003e\n                        \u003cdiv class=\"box_21 flex-col\"\u003e\n                            \u003cspan class=\"text_46\"\u003eVidGen App\u003c\/span\u003e\n                            \u003cdiv class=\"text-group_11 flex-col justify-between\"\u003e\n                                \u003cspan class=\"paragraph_14\"\u003e Bring Your Stories to Life, \u003cbr\u003e Create Video in a Click \u003c\/span\u003e\n                                \u003cspan class=\"paragraph_15\"\u003e From daily v-logs, creative shorts, or exciting moments, it can revitalize\n                    your videos with intelligent AI tech! Simply input text or images, and watch as AI generates\n                    stunning videos, turning your words and pictures into an unforgettable visual feast. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_22 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_25 flex-col\"\u003e\n                                \u003cspan class=\"text_47\"\u003eAI Text-to-Video\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_26 flex-col\"\u003e\n                                \u003cspan class=\"text_48\"\u003eAI Image-to-Video\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_23 flex-col\"\u003e\n                            \u003cspan class=\"text_49\"\u003eSoundle App\u003c\/span\u003e\n                            \u003cspan class=\"text_50\"\u003eYour BGM, Your Way\u003c\/span\u003e\n                            \u003cdiv class=\"text-group_12 flex-col justify-between\"\u003e\n                  \u003cspan class=\"paragraph_16\"\u003e Freely adjust the style, mood, instruments, and rhythm, and even write\n                    your own lyrics, making each BGM unique. From spark to symphony, your music, your way. \u003c\/span\u003e\n                                \u003cspan class=\"text_51\"\u003e *All Doke apps above offer a 30-day free trial to let users fully experience\n                    the convenience and excitement. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_12 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/c3c899bfbf0c74b5a3b2f6d7b8daf156.webp\"\u003e\n                    \u003c\/div\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n        \u003c\/section\u003e\n        \u003csection id=\"section-5\" class=\"se\"\u003e\n            \u003cdiv class=\"page flex-col\"\u003e\n                \u003cdiv class=\"box_1 flex-col\"\u003e\n                    \u003cdiv class=\"text-wrapper_1 flex-col\"\u003e\n                        \u003cspan class=\"paragraph_1\"\u003e Industry’s Only Self-Developed DokeOS 5.0 \u003cbr\u003e Based on Android 15 \u003c\/span\u003e\n                        \u003cspan class=\"text_1\"\u003e Customization↑ Convenience↑ Fluency↑Privacy↑ \u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_2 flex-col\"\u003e\n                        \u003cdiv class=\"text-wrapper_2 flex-col\"\u003e\n                            \u003cspan class=\"text_2\"\u003eSimply the Smartest\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_3\"\u003e Blackview’s Next-Gen DokeOS 5.0 \u003c\/span\u003e\n                        \u003cspan class=\"text_4\"\u003e Fully Upgraded, Hardcore Ready \u003c\/span\u003e\n                        \u003cspan class=\"paragraph_2\"\u003e Fully upgraded from DokeOS 4.2 (Android 15) to OS 5.0 (Android 15), XPLORE 1\n                Pro delivers ultra-smooth performance, smarter power optimization, and effortless convenience—bringing\n                faster operations, longer battery life, and a truly intelligent everyday experience. \u003c\/span\u003e\n                        \u003cimg class=\"image_1 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/b3f80d751d3d7771e3675615f69bdc47.webp\"\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_27 flex-row\"\u003e\n                        \u003cdiv class=\"text-group_32 flex-col justify-\"\u003e\n                            \u003cspan class=\"text_84\"\u003e Convenience at Your Fingertips \u003c\/span\u003e\n                            \u003cspan class=\"paragraph_45\"\u003e XPLORE 1 Pro delivers a more convenient experience with a series of upgrades\n                  like streamlined desktop, smarter system manager, and efficient camera—everything works faster and\n                  smoother. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_3 flex-col\"\u003e\n                        \u003cspan class=\"text_5\"\u003e Smarter Desktop, Faster Flow \u003c\/span\u003e\n                        \u003cdiv class=\"box_4 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"group_1 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_1 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_6\"\u003eOrganized App Drawer\u003c\/span\u003e\n                                    \u003cspan class=\"text_7\"\u003e Sort by Letter, Usage, or Category \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_2 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_2 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_8\"\u003eAccessible Large Folders\u003c\/span\u003e\n                                    \u003cspan class=\"text_9\"\u003e One-tap Access to Key Apps \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_3 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_3 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_10\"\u003eSecure Desktop Edit\u003c\/span\u003e\n                                    \u003cspan class=\"text_11\"\u003e New Uninstall Confirmation Popup \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_12\"\u003e Streamlined Interface, Smoother Experience \u003c\/span\u003e\n                        \u003cdiv class=\"box_5 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"box_6 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_4 flex-col justify-\"\u003e\n                                    \u003cspan class=\"paragraph_3\"\u003e Notification\/ \u003cbr\u003e Control Center \u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_4\"\u003e Side by Side, \u003cbr\u003e More Efficient \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_7 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_5 flex-col justify-\"\u003e\n                                    \u003cspan class=\"paragraph_5\"\u003e Lock Screen \u003cbr\u003e Shortcuts \u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_6\"\u003e Add Third-Party \u003cbr\u003e Apps Freely \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_8 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_6 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_13\"\u003e One Tap to Clean. One Breath to Free \u003c\/span\u003e\n                            \u003cspan class=\"text_14\"\u003eUpgraded System Manager\u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_15\"\u003e From files to apps, fully optimize your storage for a lighter, smoother phone\n                experience. \u003c\/span\u003e\n                        \u003cdiv class=\"grid_1 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_7-0 flex-col\"\u003e\n                                \u003cspan class=\"text_16-0\"\u003eOne-Tap Clean\u003c\/span\u003e\n                                \u003cspan class=\"text_17-0\"\u003e Instantly clear junk and \u003cbr\u003e free space \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_7-1 flex-col\"\u003e\n                                \u003cspan class=\"text_16-1\"\u003eCategory Cleanup\u003c\/span\u003e\n                                \u003cspan class=\"text_17-1\"\u003e Clean videos, photos, \u003cbr\u003e docs—your way \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_7-2 flex-col\"\u003e\n                                \u003cspan class=\"text_16-2\"\u003eApp Deep Clean\u003c\/span\u003e\n                                \u003cspan class=\"text_17-2\"\u003e Wipe app caches, \u003cbr\u003e run like new \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_7-3 flex-col\"\u003e\n                                \u003cspan class=\"text_16-3\"\u003eIdle App Detection\u003c\/span\u003e\n                                \u003cspan class=\"text_17-3\"\u003e Spot unused apps, \u003cbr\u003e uninstall freely \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_7-4 flex-col\"\u003e\n                                \u003cspan class=\"text_16-4\"\u003eSystem App Uninstall\u003c\/span\u003e\n                                \u003cspan class=\"text_17-4\"\u003e Remove preloads, \u003cbr\u003e keep it pure \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_7-5 flex-col\"\u003e\n                                \u003cspan class=\"text_16-5\"\u003eEasy Reinstall\u003c\/span\u003e\n                                \u003cspan class=\"text_17-5\"\u003e Restore deleted apps \u003cbr\u003e with one tap \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_9 flex-col\"\u003e\n                        \u003cdiv class=\"text-group_8 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_18\"\u003e Camera: A Complete Upgrade from Daily to Pro \u003c\/span\u003e\n                            \u003cspan class=\"text_19\"\u003e From casual snaps to pro shots, the camera adds versatile features for faster,\n                  freer, and more precise photography. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_2 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/730256ea237f097f14fc0ecfaca77582.webp\"\u003e\n                        \u003cdiv class=\"list_1 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_9-0 flex-col\"\u003e\n                                \u003cspan class=\"text_20-0\"\u003eRich Filters\u003c\/span\u003e\n                                \u003cspan class=\"text_21-0\"\u003e One tap to \u003cbr\u003e create cinematic vibes \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_9-1 flex-col\"\u003e\n                                \u003cspan class=\"text_20-1\"\u003eQuick Access Tools\u003c\/span\u003e\n                                \u003cspan class=\"text_21-1\"\u003e Grid, watermark, \u003cbr\u003e leveler,haptic feedback—all \u003cbr\u003e within reach \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_9-2 flex-col\"\u003e\n                                \u003cspan class=\"text_20-2\"\u003e Center Mark \u0026amp; Leveler \u003c\/span\u003e\n                                \u003cspan class=\"text_21-2\"\u003e Sharper composition, \u003cbr\u003e steadier frames \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_9-3 flex-col\"\u003e\n                                \u003cspan class=\"text_20-3\"\u003eEnhanced Pro Mode\u003c\/span\u003e\n                                \u003cspan class=\"text_21-3\"\u003e Adjust color temperature \u003cbr\u003e \u0026amp; choose from \u003cbr\u003e 3 metering modes \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_10 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_22\"\u003e Next-Level Notebook, Smarter Organization \u003c\/span\u003e\n                            \u003cspan class=\"text_23\"\u003e Now smarter than ever, the Notebook app is fully upgraded with faster search,\n                  intuitive organization, secure saving, diverse ways to capture ideas, and timely reminders. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_3 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/532f7e4945b97e9c7cf623b09bc05892.webp\"\u003e\n                        \u003cdiv class=\"group_4 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_3 flex-col\"\u003e\n                                \u003cspan class=\"text_24\"\u003eFind Faster\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"list_2 flex-row\"\u003e\n                                \u003cdiv class=\"text-wrapper_4-0 flex-col\"\u003e\n                                    \u003cspan class=\"text_25-0\"\u003eUniversal Search\u003c\/span\u003e\n                                    \u003cspan class=\"text_27-0\"\u003e Notes, To-Dos, Voice Recordings— \u003cbr\u003e All in One Search \u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_4-1 flex-col\"\u003e\n                                    \u003cspan class=\"text_25-1\"\u003eFlexible Folders\u003c\/span\u003e\n                                    \u003cspan class=\"text_27-1\"\u003e Create Folders in Notebook and \u003cbr\u003e Move Notes freely to Folders \u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_4-2 flex-col\"\u003e\n                                    \u003cspan class=\"text_26-2\"\u003eSmart Sorting\u003c\/span\u003e\n                                    \u003cspan class=\"text_27-2\"\u003e Sort by Creation Date or \u003cbr\u003e Update Date \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_5 flex-col\"\u003e\n                            \u003cdiv class=\"text-wrapper_5 flex-col\"\u003e\n                                \u003cspan class=\"text_28\"\u003eManage Better\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"box_10 flex-row\"\u003e\n                                \u003cdiv class=\"text-wrapper_6 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_29\"\u003eBulk Actions\u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_7\"\u003e Pin, Encrypt, Delete, Move, \u003cbr\u003e and Export. \u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-group_11 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_30\"\u003eSafe Deletion\u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_8\"\u003e Delete Confirmation, Restore \u003cbr\u003e from Recycle Bin \u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-group_12 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_31\"\u003eFlexible Export Formats\u003c\/span\u003e\n                                    \u003cspan class=\"text_32\"\u003e Supports Word and TXT \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_6 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"group_7 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_7 flex-col\"\u003e\n                                    \u003cspan class=\"text_33\"\u003eWrite More\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"block_1 flex-row justify-between\"\u003e\n                                    \u003cdiv class=\"text-wrapper_8 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"text_34\"\u003eRich Text Effects\u003c\/span\u003e\n                                        \u003cspan class=\"paragraph_9\"\u003e Highlight, Strike-Through, \u003cbr\u003e Listing Icons, and Custom \u003cbr\u003e Text\n                        Colors. \u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                    \u003cdiv class=\"text-group_13 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"text_35\"\u003eDoodles\u003c\/span\u003e\n                                        \u003cspan class=\"paragraph_10\"\u003e Diverse Brushes, Erasers, \u003cbr\u003e and Colors. \u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_8 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_9 flex-col\"\u003e\n                                    \u003cspan class=\"text_36\"\u003eNever Forget\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"text_37\"\u003eReminders\u003c\/span\u003e\n                                \u003cspan class=\"paragraph_11\"\u003e Alerts with Repeat \u0026amp; \u003cbr\u003e Priority options \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_28 flex-row\"\u003e\n                        \u003cdiv class=\"text-group_33 flex-col justify-\"\u003e\n                            \u003cspan class=\"text_85\"\u003e Upgraded Game Mode, Higher Performance \u003c\/span\u003e\n                            \u003cspan class=\"text_86\"\u003e From zero interruptions to sharper control and highlight recording, Game Mode\n                  optimizes every match for focus and flow. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_29 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_34 flex-col justify-\"\u003e\n                                \u003cspan class=\"text_87\"\u003eNo Interruptions\u003c\/span\u003e\n                                \u003cspan class=\"text_88\"\u003e Block Notifications and Calls \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-wrapper_29 flex-col\"\u003e\n                            \u003cspan class=\"text_89\"\u003eAnti-Mistouch\u003c\/span\u003e\n                            \u003cspan class=\"text_90\"\u003e Precise Control, Every Tap Counts \u003c\/span\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_11 flex-col\"\u003e\n                        \u003cdiv class=\"box_12 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"group_9 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_14 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_38\"\u003eSmart Modes\u003c\/span\u003e\n                                    \u003cspan class=\"text_39\"\u003e Three Performance Modes for Any Game Intensity \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_10 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_15 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_40\"\u003eCapture Highlights\u003c\/span\u003e\n                                    \u003cspan class=\"text_41\"\u003e One-Tap Recording and Screenshots \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_13 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"block_2 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_12\"\u003e Upgraded Search Center, \u003cbr\u003e Find Everything \u003c\/span\u003e\n                                \u003cdiv class=\"box_14 flex-row justify-between\"\u003e\n                                    \u003cdiv class=\"group_11 flex-row\"\u003e\n                                        \u003cdiv class=\"text-group_16 flex-col justify-between\"\u003e\n                                            \u003cspan class=\"text_42\"\u003eNews Hub\u003c\/span\u003e\n                                            \u003cspan class=\"text_43\"\u003e Hot topics from all sources \u003c\/span\u003e\n                                        \u003c\/div\u003e\n                                    \u003c\/div\u003e\n                                    \u003cdiv class=\"group_12 flex-row\"\u003e\n                                        \u003cdiv class=\"text-group_17 flex-col justify-between\"\u003e\n                                            \u003cspan class=\"text_44\"\u003eOne-Tap Access\u003c\/span\u003e\n                                            \u003cspan class=\"paragraph_13\"\u003e Instant Search, \u003cbr\u003e Directly Reach the Answer \u003c\/span\u003e\n                                        \u003c\/div\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"block_3 flex-col\"\u003e\n                                \u003cspan class=\"paragraph_14\"\u003e Smarter Weather Forecast, \u003cbr\u003e Instant Insights \u003c\/span\u003e\n                                \u003cdiv class=\"box_15 flex-row justify-between\"\u003e\n                                    \u003cdiv class=\"group_13 flex-row\"\u003e\n                                        \u003cdiv class=\"text-group_18 flex-col justify-between\"\u003e\n                                            \u003cspan class=\"text_45\"\u003eLive Scenes\u003c\/span\u003e\n                                            \u003cspan class=\"text_46\"\u003e Sun, Rain, Snow in Motion \u003c\/span\u003e\n                                        \u003c\/div\u003e\n                                    \u003c\/div\u003e\n                                    \u003cdiv class=\"group_14 flex-row\"\u003e\n                                        \u003cdiv class=\"text-group_19 flex-col justify-\"\u003e\n                                            \u003cspan class=\"text_47\"\u003ePractical Tips\u003c\/span\u003e\n                                            \u003cspan class=\"paragraph_15\"\u003e Outfit, Travel, \u003cbr\u003e and Activity Suggestions \u003c\/span\u003e\n                                        \u003c\/div\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_17 flex-col\"\u003e\n                            \u003cspan class=\"text_54\"\u003e Smoother Interactions, Seamless Flow \u003c\/span\u003e\n                            \u003cdiv class=\"box_18 flex-row justify-between\"\u003e\n                                \u003cdiv class=\"box_19 flex-row\"\u003e\n                                    \u003cdiv class=\"text-group_23 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"text_55\"\u003eScreen on\/off\u003c\/span\u003e\n                                        \u003cspan class=\"text_56\"\u003eFluid and Instant\u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"box_20 flex-row\"\u003e\n                                    \u003cdiv class=\"text-group_24 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"text_57\"\u003eScreen Unlock\u003c\/span\u003e\n                                        \u003cspan class=\"paragraph_21\"\u003e Natural Transitions, \u003cbr\u003e Multiple Effects \u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_48\"\u003e More Convenience For You to Explore \u003c\/span\u003e\n                        \u003cdiv class=\"box_16 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"block_4 flex-col justify-between\"\u003e\n                                \u003cdiv class=\"group_15 flex-row\"\u003e\n                                    \u003cdiv class=\"text-group_20 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"text_49\"\u003eEasyShare App\u003c\/span\u003e\n                                        \u003cspan class=\"paragraph_16\"\u003e 77x Faster than \u003cbr\u003e Wireless BT \u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"group_16 flex-row\"\u003e\n                                    \u003cdiv class=\"text-group_21 flex-col justify-between\"\u003e\n                                        \u003cspan class=\"text_50\"\u003eWorkspace App\u003c\/span\u003e\n                                        \u003cspan class=\"paragraph_17\"\u003e Balance Your Life \u003cbr\u003e and Work \u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_10 flex-col\"\u003e\n                                \u003cspan class=\"text_51\"\u003eFocus Mode\u003c\/span\u003e\n                                \u003cspan class=\"text_52\"\u003e Your Space for Deep Work \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"block_5 flex-col justify-between\"\u003e\n                                \u003cdiv class=\"text-wrapper_11 flex-col\"\u003e\n                                    \u003cspan class=\"text_53\"\u003eSurfline APP\u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_18\"\u003e Your Ultimate \u003cbr\u003e Surf Companion \u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"group_17 flex-row\"\u003e\n                                    \u003cdiv class=\"text-group_22 flex-col justify-\"\u003e\n                                        \u003cspan class=\"paragraph_19\"\u003e Data Migration \u003cbr\u003e Assistant \u003c\/span\u003e\n                                        \u003cspan class=\"paragraph_20\"\u003e Move Everything, \u003cbr\u003e Hassle-Free \u003c\/span\u003e\n                                    \u003c\/div\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cimg class=\"image_4 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/102182fca181e9957821feb3de44b94f.webp\"\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_21 flex-col\"\u003e\n                        \u003cdiv class=\"box_22 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"block_6 flex-col justify-between\"\u003e\n                                \u003cimg class=\"image_5 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/089d3d0c3e1e897fe4b6ce1d127c0af8.webp\"\u003e\n                                \u003cdiv class=\"text-group_25 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"paragraph_22\"\u003e Infinite Personalization, \u003cbr\u003e Make it Uniquely Yours \u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_23\"\u003e For a more vibrant and unified look, \u003cbr\u003e XPLORE 1 Pro brings richer\n                      wallpapers, themes, and colors for refreshed interfaces. \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cimg class=\"image_6 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/744cd1479249b8c6aa64d5bc0e38c99d.webp\"\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"grid_2 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_26-0 flex-col\"\u003e\n                                \u003cspan class=\"text_58-0\"\u003eExpanded Wallpaper Center\u003c\/span\u003e\n                                \u003cspan class=\"text_60-0\"\u003e A Rich Collection Including Rugged Style, \u003cbr\u003e Live and Textured Wallpaper\n                  \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_26-1 flex-col\"\u003e\n                                \u003cspan class=\"text_58-1\"\u003eMore Diverse Themes\u003c\/span\u003e\n                                \u003cspan class=\"text_60-1\"\u003e Multiple Theme Styles to Match Your Taste \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_26-2 flex-col\"\u003e\n                                \u003cspan class=\"text_58-2\"\u003eRefined Color Styles\u003c\/span\u003e\n                                \u003cspan class=\"text_60-2\"\u003e Versatile Color Schemes for \u003cbr\u003e Easy Interface Customization \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_26-3 flex-col\"\u003e\n                                \u003cspan class=\"text_58-3\"\u003eApp Interface Refresh\u003c\/span\u003e\n                                \u003cspan class=\"text_60-3\"\u003e Core Apps Fully Updated With \u003cbr\u003e a More Unified Look \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_26-4 flex-col\"\u003e\n                                \u003cspan class=\"text_58-4\"\u003eUpgraded Magnifier\u003c\/span\u003e\n                                \u003cspan class=\"text_60-4\"\u003eSee Clearly, Effortlessly\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_26-5 flex-col\"\u003e\n                                \u003cspan class=\"text_58-5\"\u003e Display Size and \u003cbr\u003e Text Customization \u003c\/span\u003e\n                                \u003cspan class=\"text_59-5\"\u003e Tailored Readability, Just for You \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_23 flex-col\"\u003e\n                        \u003cspan class=\"paragraph_24\"\u003e Advanced Storage Optimization, \u003cbr\u003e Faster Performance \u003c\/span\u003e\n                        \u003cdiv class=\"group_18 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"text-wrapper_12 flex-col\"\u003e\n                                \u003cspan class=\"text_61\"\u003eCold Room App\u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_13 flex-col\"\u003e\n                                \u003cspan class=\"text_62\"\u003eAtomized Memory 2.0\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"text-group_27 flex-col justify-between\"\u003e\n                            \u003cspan class=\"text_63\"\u003eSafe, Private, Always\u003c\/span\u003e\n                            \u003cspan class=\"paragraph_25\"\u003e Designed for peace of mind, XPLORE 1 Pro keeps you safe and in control,\n                  giving you the freedom to enjoy your digital life without compromise. \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_19 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"block_7 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_28 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"paragraph_26\"\u003e Enhanced \u003cbr\u003e Media Permissions \u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_27\"\u003e Customize App Access to \u003cbr\u003e Your Media Files \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"block_8 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_29 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_64\"\u003ePrivate Space\u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_28\"\u003e Establish a Secure Zone to \u003cbr\u003e Store Sensitive Files \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_14 flex-col\"\u003e\n                                \u003cspan class=\"text_65\"\u003eChild Mode\u003c\/span\u003e\n                                \u003cspan class=\"paragraph_29\"\u003e A Safe and Simplified \u003cbr\u003e Interface for Kids \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"block_9 flex-row\"\u003e\n                                \u003cdiv class=\"text-group_30 flex-col justify-between\"\u003e\n                                    \u003cspan class=\"text_66\"\u003eApp Lock\u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_30\"\u003e Robust Protection for Your \u003cbr\u003e Apps And Sensitive Data \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"paragraph_31\"\u003e Useful Features to Explore, \u003cbr\u003e More Seamless and Effortless Every Day\n              \u003c\/span\u003e\n                        \u003cdiv class=\"text-wrapper_15 flex-col\"\u003e\n                            \u003cspan class=\"text_67\"\u003e Face \u0026amp; Fingerprint Unlock \u003c\/span\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_20 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"group_21 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_16\"\u003e\n                                    \u003cspan class=\"paragraph_32\"\u003e L1+L5 \u003cbr\u003e \u003c\/span\u003e\n                                    \u003cspan class=\"paragraph_33\"\u003e Dual-band GPS+Beidou+ \u003cbr\u003e Glonass+Galileo+QZSS \u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"image-text_1 flex-row justify-between\"\u003e\n                                    \u003cspan class=\"text-group_31\"\u003e≤5 Meters\u003c\/span\u003e\n                                    \u003cimg class=\"image_7 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/286daae862e826ecbfd74e0ec9060eb7.webp\"\u003e\n                                \u003c\/div\u003e\n                                \u003cspan class=\"text_68\"\u003e More Accurate Pinpoint Precision \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"group_22 flex-col justify-between\"\u003e\n                                \u003cdiv class=\"text-wrapper_17 flex-col\"\u003e\n                                    \u003cspan class=\"text_69\"\u003eMultifunctional NFC\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_18 flex-col\"\u003e\n                                    \u003cspan class=\"text_70\"\u003ePrecision Gyroscope\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_23 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"block_10 flex-col\"\u003e\n                                \u003cdiv class=\"text-wrapper_19 flex-col\"\u003e\n                                    \u003cspan class=\"text_71\"\u003eDual-SIM Slot\u003c\/span\u003e\n                                    \u003cspan class=\"text_72\"\u003e Dual 5G SIM Dual Standby \u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-wrapper_20 flex-col\"\u003e\n                                \u003cspan class=\"text_73\"\u003eGlobal Connectivity\u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"group_24 flex-row justify-between\"\u003e\n                            \u003cdiv class=\"section_1 flex-col\"\u003e\n                                \u003cspan class=\"text_74\"\u003eCustomized Shortcut Button\u003c\/span\u003e\n                                \u003cdiv class=\"text-wrapper_21 flex-col\"\u003e\n                                    \u003cspan class=\"text_75\"\u003eStart Soundrecording\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_22 flex-col\"\u003e\n                                    \u003cspan class=\"text_76\"\u003eOpen flashlight\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_23 flex-col\"\u003e\n                                    \u003cspan class=\"text_77\"\u003eScreenshots\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_24 flex-col\"\u003e\n                                    \u003cspan class=\"text_78\"\u003eOpen UnderWater Camera\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_25 flex-col\"\u003e\n                                    \u003cspan class=\"text_79\"\u003eOpen PTT\u003c\/span\u003e\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"text-wrapper_26 flex-col\"\u003e\n                                    \u003cspan class=\"text_80\"\u003eOpen SOS\u003c\/span\u003e\n                                \u003c\/div\u003e\n                            \u003c\/div\u003e\n                            \u003cimg class=\"image_8 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/eac76e29c94b27e811adb4e36c2575c6.webp\"\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_30 flex-col\"\u003e\n              \u003cspan class=\"paragraph_46\"\u003e Comprehensive Offline \u0026amp; Online After-Sales Care Quick, Professional, and\n                Always Here for you \u003c\/span\u003e\n                        \u003cdiv class=\"list_3 flex-row\"\u003e\n                            \u003cdiv class=\"text-group_35-0 flex-col\"\u003e\n                                \u003cspan class=\"text_91-0\"\u003e 24\/7 \u003cbr\u003e Online Support \u003c\/span\u003e\n                                \u003cspan class=\"text_92-0\"\u003e Get help anytime, \u003cbr\u003e anywhere. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_35-1 flex-col\"\u003e\n                                \u003cspan class=\"text_91-1\"\u003e Offline \u003cbr\u003e Repair Centers \u003c\/span\u003e\n                                \u003cspan class=\"text_92-1\"\u003e Expert technicians, \u003cbr\u003e genuine parts. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_35-2 flex-col\"\u003e\n                                \u003cspan class=\"text_91-2\"\u003e 3 Years of \u003cbr\u003e Android Updates \u003c\/span\u003e\n                                \u003cspan class=\"text_92-2\"\u003e Always fresh, secure, \u003cbr\u003e and up to date. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"text-group_35-3 flex-col\"\u003e\n                                \u003cspan class=\"text_91-3\"\u003e 2-Year Extended \u003cbr\u003e Warranty \u003c\/span\u003e\n                                \u003cspan class=\"text_92-3\"\u003e Peace of mind for the \u003cbr\u003e long haul. \u003c\/span\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cdiv class=\"box_31 flex-row\"\u003e\n                            \u003cspan class=\"text_93\"\u003eLearn More\u003c\/span\u003e\n                            \u003cimg class=\"image_30 lazyload\" referrerpolicy=\"no-referrer\" data-src=\"https:\/\/d2kbvjszk9d5ln.cloudfront.net\/yshop\/xplore1pro_img\/a35842abbb60806cbfc812b6ea458afa.webp\"\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_24 flex-row\"\u003e\n                        \u003cdiv class=\"section_2 flex-col\"\u003e\n                            \u003cdiv class=\"box_25 flex-col\"\u003e\u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_81\"\u003eOrange\u003c\/span\u003e\n                        \u003cdiv class=\"section_3 flex-col\"\u003e\n                            \u003cdiv class=\"group_25 flex-col\"\u003e\u003c\/div\u003e\n                        \u003c\/div\u003e\n                        \u003cspan class=\"text_82\"\u003eBlack\u003c\/span\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"box_26 flex-col\"\u003e\n                        \u003cspan class=\"text_83\"\u003e Blackview XPLORE 1 Pro Specifications \u003c\/span\u003e\n                        \u003cul\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Model\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    XPLORE 1 Pro\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Color\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    Black, Orange\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Dimension\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    184*83*29.5mm\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Weight\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    640g\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    OS\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    DokeOS 5.0 Based on Android 15\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Display\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    6.78-inch 2.4K FHD+IPS, 1080*2460 Resolution,\n                                    \u003cbr\u003e Corning® Gorilla® Glass 5,\n                                    \u003cbr\u003e 120Hz Refresh Rate,\n                                    \u003cbr\u003e Secondary Screen: 2.01-inch, 240*296 Resolution\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    CPU\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    Octa-core 5G MediaTek Dimensity 7050, 6nm, Up to 2.4GHz\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    RAM \u0026amp; ROM\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    12GB RAM \u0026amp; 256GB ROM, LPDDR5+UFS3.1\n                                    \u003cbr\u003e 16GB RAM \u0026amp; 512GB ROM, LPDDR5+UFS4.0\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    TF Expansion\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    Up to 2TB Expansion\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Battery\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    20,000mAh; 55W Fast Charging\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Front Camera\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    50MP (Samsung® ISOCELL JN1)\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Rear Camera\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    64MP\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Speaker\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    1PC 1134 Smart-K BOX Speaker\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Rugged Rating\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    IP68 \u0026amp;IP69K\u0026amp; MIL-STD-810H\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Navigation\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    GPS\/GLONASS\/BeiDou\/Galileo\/QZSS（ L1、L5）\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Glove Mode\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    Support\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    NFC\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    Support\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Dual 5G VoLTE\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    Support\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Wi-Fi\u0026amp;Bluetooth\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    IEEE802.11a\/b\/g\/n\/ac\/ax (2.4GHz\/5GHz); BT 5.2\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                            \u003cli\u003e\n                                \u003cdiv class=\"left\"\u003e\n                                    Network Connectivity\n                                \u003c\/div\u003e\n                                \u003cdiv class=\"right\"\u003e\n                                    3G Band:\n                                    \u003cbr\u003e WCDMA: B1\/B2\/B4\/B5\/B6\/B8\/B19,\n                                    \u003cbr\u003e CDMA: BC0\/BC1\/BC10\n                                    \u003cbr\u003e 4G Band:\n                                    \u003cbr\u003e TDD: B34\/B38\/B39\/B40\/B41\n                                    \u003cbr\u003e FDD: B1\/2\/3\/4\/5\/7\/8\/12\/13\/17\/18\/19\/20\/25\/26\/28A\/28B\/30\/66\n                                    \u003cbr\u003e 5G Band: N1\/3\/5\/7\/8\/20\/28\/38\/40\/41\/77\/78\n                                \u003c\/div\u003e\n                            \u003c\/li\u003e\n                        \u003c\/ul\u003e\n                    \u003c\/div\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n        \u003c\/section\u003e\n    \u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv style=\"color: #888;\"\u003e\n    \u003cbr\u003eRelated Product:\u003cbr\u003e#\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/night-vision-phones\"\u003enight vision phones\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/ip69k-phone\"\u003eIP69 phone\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/cheap-tough-phones\"\u003echeap rugged phones\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/thermal-imaging-phones\"\u003ethermal camera phone\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/cheap-waterproof-phones\"\u003echeap waterproof phones\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/slim-rugged-phone\"\u003eslim rugged phone\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/australia-tough-mobile\"\u003etough phones Australia\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/heavy-duty-cell-phones\"\u003eheavy duty cell phones\u003c\/a\u003e, #\u003ca style=\"color: #888;\" href=\"https:\/\/store.blackview.hk\/blogs\/news\/best-hiking-phone\"\u003ebest phone for hiking\u003c\/a\u003e\n\u003c\/div\u003e\n\u003cscript src=\"https:\/\/store.blackview.hk\/cdn\/shop\/t\/22\/assets\/jquery-3.3.1.min-20201130021002922.js\"\u003e\u003c\/script\u003e\n\u003cscript src=\"https:\/\/store.blackview.hk\/cdn\/shop\/t\/22\/assets\/lazysizes.min-20201204070627489.js\"\u003e\u003c\/script\u003e\n\u003cscript\u003e\n    $(function () {\n        function scaleFn(dom, size, total) {\n            let pages = $(dom)\n            for (const key in pages) {\n                if (pages.eq(key).height()) {\n                    pages.eq(key).parent('section').css({\n                        'transform': 'scale(' + size \/ total + ')',\n                        'height': (pages.eq(key).height()) * (size \/ total),\n                        'transform-origin': '0 0'\n                    })\n                }\n            }\n        }\n        let cw = null\n        init()\n        window.addEventListener('resize', function () {\n            init()\n        })\n        window.addEventListener('scroll', function () {\n            init()\n        })\n\n        function init() {\n            cw = document.body.offsetWidth\n            if (cw \u003e 1200) {\n                scaleFn('.xplore1pro-pc .page', 1200, 1903)\n            }else if(cw \u003c 768) {\n\n                scaleFn('.xplore1pro-pc .page',(cw-32),1903)\n            } else {\n                scaleFn('.xplore1pro-pc .page', cw, 1903)\n            }\n        }\n    })\n\u003c\/script\u003e","vendor":"Blackview","product_type":"Phone\/Rugged Phone","created_at":"2025-11-12T16:14:51+08:00","handle":"xplore-1-pro-price","updated_at":"2026-10-07T03:04:06+08:00","published_at":"2025-11-12T19:17:01+08:00","template_suffix":"liu-phone","published_scope":"global","tags":"5G, Charging Dock, Flashlight, Thermal Imaging","variants":[{"id":48788392804577,"product_id":9189840257249,"title":"Thermal Imaging \/ 12GB+256GB \/ Black \/ UK Plug","price":"354.00","sku":"25010110285_XPLORE1Pro-12+256-BLACK-UK","position":2,"compare_at_price":"467.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"12GB+256GB","option3":"Black","created_at":"2026-07-24T13:33:54+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49385977676001,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]},{"id":48175725609185,"product_id":9189840257249,"title":"Thermal Imaging \/ 12GB+256GB \/ Black \/ EU Plug","price":"354.00","sku":"15270103897_XPLORE1Pro-12+256-BLACK-EU","position":3,"compare_at_price":"467.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"12GB+256GB","option3":"Black","created_at":"2026-04-03T17:16:00+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49385977676001,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]},{"id":48788392837345,"product_id":9189840257249,"title":"Thermal Imaging \/ 12GB+256GB \/ Orange \/ UK Plug","price":"354.00","sku":"25010110286_XPLORE1Pro-12+256-ORANGE-UK","position":6,"compare_at_price":"467.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"12GB+256GB","option3":"Orange","created_at":"2026-07-24T13:33:54+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49660053618913,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]},{"id":48175725641953,"product_id":9189840257249,"title":"Thermal Imaging \/ 12GB+256GB \/ Orange \/ EU Plug","price":"354.00","sku":"15270103898_XPLORE1Pro-12+256-ORANGE-EU","position":7,"compare_at_price":"467.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"12GB+256GB","option3":"Orange","created_at":"2026-04-03T17:16:00+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49660053618913,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]},{"id":48788392870113,"product_id":9189840257249,"title":"Thermal Imaging \/ 16GB+512GB \/ Black \/ UK Plug","price":"438.00","sku":"25010110273_XPLORE1Pro-16+512-BLACK-UK","position":10,"compare_at_price":"467.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"16GB+512GB","option3":"Black","created_at":"2026-07-24T13:33:54+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49385977676001,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]},{"id":48175725674721,"product_id":9189840257249,"title":"Thermal Imaging \/ 16GB+512GB \/ Black \/ EU Plug","price":"438.00","sku":"15270103895_XPLORE1Pro-16+512-BLACK-EU","position":11,"compare_at_price":"603.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"16GB+512GB","option3":"Black","created_at":"2026-04-03T17:16:00+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49385977676001,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]},{"id":48788392902881,"product_id":9189840257249,"title":"Thermal Imaging \/ 16GB+512GB \/ Orange \/ UK Plug","price":"438.00","sku":"25010110274_XPLORE1Pro-16+512-ORANGE-UK","position":14,"compare_at_price":"467.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"16GB+512GB","option3":"Orange","created_at":"2026-07-24T13:33:54+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49660053618913,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]},{"id":48175725707489,"product_id":9189840257249,"title":"Thermal Imaging \/ 16GB+512GB \/ Orange \/ EU Plug","price":"438.00","sku":"15270103896_XPLORE1Pro-16+512-ORANGE-EU","position":15,"compare_at_price":"603.00","fulfillment_service":"manual","inventory_management":"shopify","option1":"Thermal Imaging","option2":"16GB+512GB","option3":"Orange","created_at":"2026-04-03T17:16:00+08:00","updated_at":"2026-10-07T03:04:06+08:00","taxable":false,"barcode":null,"grams":1100,"image_id":49660053618913,"weight":1.1,"weight_unit":"kg","requires_shipping":true,"quantity_rule":{"min":1,"max":null,"increment":1},"price_currency":"GBP","compare_at_price_currency":"GBP","quantity_price_breaks":[]}],"options":[{"id":12099472163041,"product_id":9189840257249,"name":"Version","position":1,"values":["Standard","Thermal Imaging","Walkie Talkie"]},{"id":11548506783969,"product_id":9189840257249,"name":"Capacity","position":2,"values":["12GB+256GB","16GB+512GB"]},{"id":11548506816737,"product_id":9189840257249,"name":"Color","position":3,"values":["Orange","Black"]},{"id":11825910481121,"product_id":9189840257249,"name":"Plug","position":4,"values":["UK Plug","EU Plug"]}],"images":[{"id":49385977676001,"product_id":9189840257249,"position":1,"created_at":"2026-07-17T15:44:47+08:00","updated_at":"2026-07-17T15:44:49+08:00","alt":"Back and front of the black Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLEASE_1_Pro_Black.jpg?v=1784274289","variant_ids":[48175725609185,48175725674721,48788392804577,48788392870113]},{"id":47321329205473,"product_id":9189840257249,"position":2,"created_at":"2025-11-12T14:23:52+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Front view of the black Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Black_02.jpg?v=1763021731","variant_ids":[]},{"id":47321329402081,"product_id":9189840257249,"position":3,"created_at":"2025-11-12T14:23:53+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Back of the black Blackview XPLORE 1 Pro rugged thermal imaging phone","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Black_03.jpg?v=1763021731","variant_ids":[]},{"id":47321329434849,"product_id":9189840257249,"position":4,"created_at":"2025-11-12T14:23:53+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Front right side of the black Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Black_04.jpg?v=1763021731","variant_ids":[]},{"id":47321329369313,"product_id":9189840257249,"position":5,"created_at":"2025-11-12T14:23:53+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Front left side of the black Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Black_05.jpg?v=1763021731","variant_ids":[]},{"id":47321329303777,"product_id":9189840257249,"position":6,"created_at":"2025-11-12T14:23:53+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"The right side of the back of the black Blackview XPLORE 1 Pro thermal imaging rugged phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Black_06.jpg?v=1763021731","variant_ids":[]},{"id":47321329533153,"product_id":9189840257249,"position":7,"created_at":"2025-11-12T14:23:53+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Left side of the back of the black Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Black_07.jpg?v=1763021731","variant_ids":[]},{"id":49660053618913,"product_id":9189840257249,"position":8,"created_at":"2026-08-04T13:44:58+08:00","updated_at":"2026-08-04T13:45:00+08:00","alt":null,"width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/Blackview_XPLORE_1_Pro_Orange_Thermal_Imaging_1.jpg?v=1785822300","variant_ids":[48175725641953,48175725707489,48788392837345,48788392902881]},{"id":47321325568225,"product_id":9189840257249,"position":9,"created_at":"2025-11-12T14:23:36+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Front view of the orange Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Orange_02.jpg?v=1763021731","variant_ids":[]},{"id":47321325600993,"product_id":9189840257249,"position":10,"created_at":"2025-11-12T14:23:36+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Back of the orange Blackview XPLORE 1 Pro rugged thermal imaging phone","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Orange_03.jpg?v=1763021731","variant_ids":[]},{"id":47321325633761,"product_id":9189840257249,"position":11,"created_at":"2025-11-12T14:23:36+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Front-right view of the orange Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Orange_04.jpg?v=1763021731","variant_ids":[]},{"id":47321325666529,"product_id":9189840257249,"position":12,"created_at":"2025-11-12T14:23:36+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Front-left view of the orange Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Orange_05.jpg?v=1763021731","variant_ids":[]},{"id":47321325699297,"product_id":9189840257249,"position":13,"created_at":"2025-11-12T14:23:36+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Rear right view of the orange Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Orange_06.jpg?v=1763021731","variant_ids":[]},{"id":47321325732065,"product_id":9189840257249,"position":14,"created_at":"2025-11-12T14:23:36+08:00","updated_at":"2025-11-13T16:15:31+08:00","alt":"Rear left view of the orange Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLORE1Pro-Orange_07.jpg?v=1763021731","variant_ids":[]}],"image":{"id":49385977676001,"product_id":9189840257249,"position":1,"created_at":"2026-07-17T15:44:47+08:00","updated_at":"2026-07-17T15:44:49+08:00","alt":"Back and front of the black Blackview XPLORE 1 Pro rugged thermal imaging phone.","width":1200,"height":1200,"src":"https:\/\/cdn.shopify.com\/s\/files\/1\/0564\/9652\/1403\/files\/XPLEASE_1_Pro_Black.jpg?v=1784274289","variant_ids":[48175725609185,48175725674721,48788392804577,48788392870113]}}}
