Blackview Tab 10 4G Tablet PC - Blackview Official Store
Blackview Tab 10 Slim Tablet 4GB+64GB 10.1-inch Tab10 4G Tablet
$199.99 $189.99
✔Octa-core MTK8768 processor
✔7480mAh Battery
✔4G+WiFi
Capacity: 4GB+64GB
4GB+64GB
Color: Silver
Gray
Silver
Add to Wishlist
paypalvisamastermaestrojcbamerican expressdiners clubdiscover
Description
Note:
This tablet's 4G network connection can only work in Europe and Asia area, please pay attention before purchasing or consult us.
Blackview Tab 10 64GB Tablet
A budget tablet that does more
  • Doke
    OS_P 1.0
  • Latest
    Android 11
  • 7480mAh
    Battery
  • Octa-core
    Processor
Be Powerful
7480mAh High-capacity Battery
Nothing should get in the way of your entertainment. Tab 10 delivers remarkable lasting battery life.
  • 7.5hrs Web
  • 6hrs HD video
  • 5.5hrs Game
  • 30hrs Music
  • 25hrs Calling
  • 600hrs Standby
*Battery life will vary based on device settings, usage, and other factors.
Big enough battery
Smoother Experience
Octa-core Processor
Blackview Tab 10 is powered by an octa-core MTK8768 processor, which is designed for highly mobile and capable devices. Paired with 4GB RAM and 64G ROM, and up to 128GB of expandable storage, Blackview Tab 10 offers high performance.
  • 4GB RAM
  • 64GB ROM
  • 128GB Expandable Storage
Slim. Sleek. Stylish
Experience fine craftsmanshipand aestheticswith the 8.8mm slim body. Feel the beauty atyour fingertips and the elegance in depth.
Get Immersed in a Splendid World
The 10.1 inch FHD+display presents a feast to your eyes. With the narrow bezel bringing more screen space, Blackview Tab 10 is designed to deliver an immersive experience.
Good viewing experience
Designed by Blackview
Tell Your Story as You Wish
8MP front camera+13MP rear camera. Blackview Tab 10 delivers various camera mode. Take your Pick.
8MP
Front Camera
13MP
Rear Camera
Professional mode
All black and white
Blackview OS
Doke OS_P 1.0
Blackview Tab 10 runs the latest Android 11 to give you powerful device controls. From first glance to full immersion, excellence is embodied in every detail.
Gaussian Blur for Visual Comfort
Overall gaussian blur creates a soft blur effect. Useful information stands out more clearly. User-focused layout and interaction design deliver a captivating experience.
split view for Easier Multitasking
ln a split screen view, you are allowed run two apps side by side without compromise.This is a feature that extremely please productivity enthusiasts.
  • split view for Easier Multitasking
  • Gesture Navigation
    Gesture navigation is easier to use than ever with improved details. Every step of the operation closely follows the finger.
  • Exquisite lcons,pleasing to Your Eyes
    Exquisite app icons come with gradient color, a level of transparency,and mildly stereoscopic effect forexceptional aesthetics.
  • Dark Mode
    Dark Mode, which has light text ona dark background , reduces thelight emitted by device screenswhile maintaining the minimumcolor contrast ratios.The result isreducing eyes strain in dim light.
  • Freeze Unused Applications
    This function can smart clean background processes, stop stealthy running apps and boost performance.Applications in frozen state can berestored anytime.
All-in-one Solution for Smarter Control
As a user-friendly all-in-one solution, System Manager plays multiple roles.
  • Tab 10 features
    Free up More Space
    Cleanup frees your disk space by removing junk files, offering extremely high performance.
  • Game Speedup
    Optimize your system performance.Enable you one stepahead when gaming.
  • Blackview OS features on Tab 10
    Smart Power Saving
    Power Saving mode helps to reduce battery drain andget more running time by reducing background activity and disabling some features.
  • Tab 10 APP control
    App Management
    Blackview Tab 10 offers complete control over apps. For example, itlets you know about what kind of information eachapplication is accessing, so you can make best decision weather they should be used or removed.
Stay Connected
Wherever You Take It
Supporting dual SIM cards, Blackview tab 10 enables you to stay connected wherever you take it. Enjoy your spare time or get your work done with 4G speed .
Specification
Design
Product Tab 10
OS Android 11.0
Color Gray, Gold, Silver
Weight 523g
Dimensions 243*162*8.4mm
Screen
IC HX8279-D01QPD200
Panel Type IPS
Display Resolution FHD+
Screen Size 10.1 inch
Screen Resolution 1200*1920
Viewing angle (H/V) Full angle
Glass Rainbow Glass
Connectivity
2G GSM:B2/B3/B5/B8
3G WCDMA:B1/B8
4G FDD:B1/B3/B7/B8/B20/B40
WIFI IEEE802.11 a/b/g/n/ac
Bluetooth V5.0
Hardware
CPU MTK8768 Octa core
CPU Clock Cortex -A53 MPCore:2.0Ghz
GPU IMG GE8320
RAM 4GB
RAM Type LPDDR3
ROM 64GB
ROM Type EMMC
TF Card Slot Support
Max TF Card Capacity 128GB
USB TYPE-C
Camera
Front Camera 8.0MP
Front Camera Sensor IMX219
Front Camera Aperture f2.2
Rear Camera 13.0MP
Rear Camera Sensor IMX258
Rear Camera Aperture f2.2
Rear Flash Yes
Video 1080p@30fps
Power
Battery Capacity 7480mAh
Max Charging Current 9v 2A
Multi-media
Video mp4\3Gp\mov\mkv…
Audio flac\ape\ac….
Image jpeg\png\gif\bmp
Features
Navigation GPS+GLONASS+GALILEO+BEIDOU
Motor Cylinder motor
Sensors G-sensor
Gyroscope Yes
Magnetic NO
Air pressure sensor NO
Hall NO
Compass NO
Fingerprint NO
RGB Yes
NFC NO
Hotkont NO
Coulomb Counter NO
Wireless Charging NO
Sim-Card Type Two nano card
FM YES
OTG YES
Earphones Jack Type TYPE-C
Total standby time 25 days
Accessories
User Manual x1
Power Adaptor x1
USB Cable x1
NOTE
Reviews
Customer Reviews
Based on 1 review Write a review
