-21%
Blackview AirBuds 3 Bluetooth 5.1 True Wireless Stereo Earbuds
$49.99 $39.99
In StockIn StockOut of stock
Shipping calculated at checkout.
✔Bluetooth 5.1 TWS Earphones
✔Active Noise Cancelling
✔Touch Control Headphone With Microphone
Color: White
  • White
Will not ship until [19041994]
Out of stock
HURRY! ONLY LEFT IN STOCK.
Accepted payment methods:
paypalvisamastermaestro
airbuds3
AirBuds 3
Smart Day with Affordable AirBuds 3
  • Bluetooth 5.1
  • Master- slave switch
  • Up to 15 hrs of battery life
  • Clear sound & deep bass
  • IPX7 waterproof
  • Voice assisstant
  • touch to control
  • Fit comfortably
  • Less weight. More comfort
    AirBuds 3 only weigh 3g each, 40% lighter than average, for maximum comfort. The half in-ear design fits snugly in your ear, delivers super air permeability, and never falls out. You won't feel your earbuds, but only your music.
Uninterrupted listening time on the go
time on the go
Blackview AirBuds 3 deliver an industry-leading 5 hours of listening time on a single charge.
And it's easy to refill with a pocket-friendly charging case. Keep the fun going whatever you do.
Upgrade from Bluetooth 5.0 to 5.1
5.0 to 5.1
Connection is key to TWS earphones. The leap from Bluetooth 5.0 to 5.1 delivers 30% faster connectivity and transmission speed, longer connection distance, and lower power consumption. Thus, it guarantees an improved listening experience.
faster connectivity and transmission speed.
Longer connection distance, and lower power consumption.
  • 30% faster connectivity
  • Longer connection distance
  • Lower power consumption
Clear sound & rich bass
AirBuds 3 push to the limit by integrating a Φ13mm large size speaker drive into the small earbud to produce rich bass and clear sound with a bunch of texture and details. Coupled with DSP noise cancellation technology, it delivers crystal clear phone calls.
Φ13mm speaker drive
Main mic
Capture human voice
airbuds3
airbuds3
Hall switch,pick up to use.
Either left or right earbud connects to the device indepandently
Master-slave switch
Pick up to use
The AirBuds 3 case adopts advanced Hall switch - either left or right earbud connects to the device independently and immediately it’s taken out from the case. After a simple one-tap setup, Blackview AirBuds 3 are automatically on. Using them is just as easy.
IPX7 waterproof
AirBuds 3 are resistant to sweat, water.
You can use them while you go for a jog or participate in an intense training session and don't have to worry about sweat interfering with the sound quality or running the earbuds.
Voice assistant
  • Quick access to the
    voice assistant
    The voice assistant can be activated by simply touching either earbud for 2 seconds. Then your voice assistant is ready whenever you call, letting you control your phone without lifting a finger. Play the music or manage the call while on the move.
Touch to control
Operations such as play/pause music, answer/end a call can be performed by simply touching the earbuds. Easy control without operating the device.
  • Play / pause music
    Touch either earbud twice
  • Next song
    Touch rught/left earbud thrice
  • Activate voice assistant
    Touch either earbud for 2 seconds
  • Reject a call
  • Answer / end a call
  • Next song
Design
Product AirBuds 3
Color White
Weight Earphones - 6.0g, Charging Case - 23.7g
Earphone Dimensions 32.9*16.5*17.8mm
Charging Case Dimensions 51.7*46.7*21.7mm
Hardware
Bluetooth version V 5.1
Audio codec format AAC SBC
Power
Standby time 50 Hours
Playtime 5 Hours
Battery type Lithium polymer battery
Battery capacity 30mAh x 2 (airbuds); 220mAh (charging case)
Charging port POGO PIN (airbuds); USB TYPE-C (charging case)
Charging time 1.5 Hours (airbuds); 2 Hour(charging case)
Package List
AirBuds 3 Earphone 1 Pair
Type-c Cable x1
Charging case x1
User Manual x1
Customer Reviews
Based on 1 review Write a review
Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday
January,February,March,April,May,June,July,August,September,October,November,December
Not enough items available. Only [max] left.
Add to WishlistBrowse WishlistRemove Wishlist
Shopping cart
Your cart is empty.
Return To Shop
Add Order Note Edit Order Note
Estimate Shipping
Add A Coupon
Estimate Shipping
Add A Coupon
Coupon code will work on checkout page
$49.99 $39.99
