Here Awaits You An Immersive Music Gala
LED
Power Display
ENC & DNS
Noise Reduction
Effective Game Mode
470mAh
Large Battery
13mm
Dynamic Driver
Wireless
Charging Support
IPX7
Waterproof
High Sensitivity
470mAh Large Battery
Indulge in Music without Battery Anxiety
Earphone heavy users? AirBuds 7 can satisfy you all with a larger 470mAh battery that provides up to 6 hours of music playback on a single full charge. Beyond that, you get nearly a total of 30 hours of endurance with the charging case which offers 4-5 times of charge for the earbuds. Immerse yourself in music all the way.
6 hours
Music Playback at Maximum
Volume on a Single Charge
A Total of
30
hours Music Playback
*The actual battery life varies depending on music type, volume, connected devices, etc.
WIRELESS
Wireless charging for the charging case is supported.
13mm Dynamic Driver
Rich in Details
Pleasing in Every NoteThe 13 mm dynamic driver characterized by PU and TI titanium composite diaphragms reproduces authentic and vivid sound as on site. AirBuds 7 precisely captures audio across a wider field of frequencies to please your ears and mind with more powerful treble, deeper bass and clearer midrange.
ENC& DNS Noise Reduction
Automatically Block out the Unimportant Noise
Incorporating the adaptive dual-mic Environmental Noise Cancellation Technology (ENC) and Dialogue Noise Suppression algorithm (DNS), AirBuds 7 automatically switches on noise cancellation mode to cut out all the unwanted noise during calls whether you are in a crowded subway, a bustling supermarket or near loud traffic.
Effective Game Mode
Low Latency, High Synchronization
Press the right earbud for 2s to turn on the Game Mode designed to minimize audio latency during gaming. Keep visuals and audio in lockstep to ensure thrilling gaming experiences.
High Sensitivity
Greater Details
Upgraded Sound
AirBuds 7 delivers better sensitivity than its predecessor in terms of the drivers, producing music much faster and more efficiently.
IPX7 Waterproof
Splashes. Sweat. Raindrops? Not a Problem.
AirBuds 7 is tougher than you would expect. With IPX7 water-resistance, you will be fond of the company of AirBuds 7 whether in heavy rain or intensive workout in the gym.
Automatic Connection
Paired Once and for All
When you open the charging case and take out the earbuds, the duo will automatically activate themselves. After first-time pairing with your smartphone, the earbuds will resume automatic connection with your phones. Only pair once and you are free from the trifle of connection.
First-time Pairing Guide
Step 1:
Open the charging case and take out the earbuds.
Step 2:
Open the Bluetooth on your smartphone and search for “AirBuds 7”.
Step 3:
Click to connect.
Modern & Trendy Design
An Innovative Look to Set the Trend
The classy inky charging case stands out from the crowd with refreshing rounded rectangle-shaped design. Feel its streamlined curves and comfortable matte finish in your palms with giddy delight. A smart LED screen on the front indicating the battery level of the case or earbuds sweeps away your battery anxiety once and for all.
55.8*48.8*29.5mm
33.5g
33.5g
Half In-ear Design
Intended for Optimized Audio Pleasure
After massive tests to improve the experience of wearing AirBuds 7 on thousands of users, the earbuds are engineered to fit snugly and seamlessly in the ears with minimal pressure and maximal comfort regardless of various ear contours.
33*17.5*19mm
3.7g each
Smart Touch to Operate
Light Tap, Intelligent Control
AirBuds 7 delivers intuitive control over itself with easy-to-operate tapping steps. No need to take out your smartphone from your pocket or bag because only simple light taps on the earbuds can do so much more for you.
For the Left Earbud
Volume-
Tap once
Previous Song
Tap thrice
For the Right Earbud
Volume +
Tap once
Next Song
Tap thrice
Turn on/off Game Mode
Tap and hold for 2s
For the Either Earbud
Answer/End a call
Tap twice
Reject a call
Tap and hold for 2s
Answer a third-party call
Tap twice ;
Tap and hold for 2s
to switch between 2 callsEnd a third-party call
Tap and hold for 2s
More Compatibility
Compatible With Android &
iOS and HarmonyOS
AirBuds 7 meets the needs of Android & iOS and HarmonyOS users, delivering uninterrupted music indulgence between various smart devices.
HarmonyOS
Android
iOS
Blackview AirBuds 7
Model
AirBuds 7
Weight
33.5g(charging case) / 3.7g*2 (earbuds)
Color
Midnight Black
Driver
13mm dynamic driver
Frequency response range
20 ~20KHZ
Audio codec
SBC
Battery capacity
470mAh
Music play time (single full charge)
6 hours(100% volume)
Charging time
75 min (earbuds) / 2.5h(charging case)
Charging port
Type-C
Water resistance
IPX7
